Can 2010 Climb Ramp Onto Auto Transport Trailer?
Discussion in 'Gen 3 Prius Main Forum' started by web1b, Nov 8, 2010.
  1. web1b
    web1b Active Member
    817
    52
    Does a 2010 Prius have the ground clearance to climb the ramp up to a auto transport trailer? I see you need a special low profile ramp to change oil and the video shows a pretty tall SUV:
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
    Those ramps don't appear to be very steep. I believe they are lower angle than the plastic ramps that I have for changing oil. There are different brands and designs of car trailers, so some probably have steeper ramps than others.
    You can tell by the clearance between the front spoiler and the ramp, so the best way is to carefully pull the car up to the ramp and see if the spoiler will hit before the tire(s) are on the ramp. You should be able to check without causing any damage.
  3. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    I bought my car from a dealer in Boston (I'm located on Long Island) and had it trucked to my house on a transport. It was backed off with no problem, so I have to believe that putting it on was not an issue either. Also, that's how dealers get the cars delivered to them.
  4. Fstr911
    Fstr911 Member
    235
    55
    I used to trailer a (very) lowered sports car that had much less clearance than my Prius. When loading it on the trailer I'd drive over wood 2" X 12"s to assist in the transition.
    The Prius, being very simular in ride height to many other cars, I presume will not have a significant problem. But the wood (as noted, to help with the transition) is always an option.
