Prius 2005_which engine oil at 119k/125k km's
Discussion in 'Gen 2 Prius Technical Discussion' started by Agape, Nov 9, 2010.
  1. Agape
    Agape Member
    378
    Ireland/Eire
    Hi All, I am new to this Forum so I wanted say hi.
    I am lucky owner of 2005 Prius and the car has due service in 5k kilometers. My question is what exact specific engine oil is recommended for these engines? Unfortunatelly there were no manuals with the car when I purchase the car and I had to contact dealer to obtain Full service history to date (received 7 invoices - copies from the dealer) When I read invoices it doesnt tell much apart from Synt /Semi Synt oil (-this way the line was entered to the dealers computers system and this way is being printed on dealers sales invoices, so there is no way of reading oil info from these invoices.
    Will I just call dealer to ask what oils were used or will I start using oil reccomended by you guys? Car has 120k km on the odometer and the dealer sticker identifies that the next service is due at 125k kms. Also, are there other important elements apart from specific oil (+ oil filter) that need to be done at this particular 125k kilometers odo?
    thank you and hope you could advise me.
  2. Patrick Wong
    18,200
    6,500
    The major concern is that you should use the correct viscosity oil: 5W-30. Engine oil brands vary depending upon your location. As long as you are using a quality brand, you will be fine.
    Regarding maintenance, I suggest that you look at the engine and cabin air filters and replace if they are dirty. Hold the engine air filter up to the sun. If you don't see light coming through, replace that filter. Regarding the cabin air filter, its replacement depends upon how much dirt you are comfortable breathing through.
    You may wish to visit the Toyota Europe website and look for a scheduled maintenance page. For example, the TMS USA website has this webpage:
    http://toyotaowners.com/Owners/maintenance-guides.do?siteid=tcom_btmnav_owners_scheduledmaintenance
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The OP lives in Ireland, not in the United States or Canada. I actually doubt a 5W-30 was used
    All I can suggest is to continue using the same oil the car has received all along. May I suggest to the OP to simply ask the dealership, where the service history was obtained, what brand and viscosity of oil was used, and to keep using it
  4. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Toyota recommends 0-20 wt. for the Prius. H
  5. Agape
    Agape Member
    378
    Ireland/Eire
    Great thank you for the response, regarding the oil brand, would you have preferences ?
    I tried shortly to visit toyota-tech.eu (link from toyota-europe.com)-the website- it charges €3 for 1 hour subscription or 1 month €240 for Online viewing access.-(I dont mind paying for 1 hour :) just to download the data ) US website appear not to charge, however doesnt allow me to download pdf regarding 2005 Prius Maintenance, maybe due to my location. I wouldnt follow US data strictly as I am based in EU(Ireland) so it might need differerent reccomendations. However was interested to read about US -Mainenace guides/data too, just to know the differences as oppose to EU.Once I get the Maintenance data from EU site I will feel better about Prius.
    Edited:
    hmm, I will contact the dealer option too... I need to figure out whether to call or to visit in person and see if there are large oil barrels or 5 litre plastic oil cans being used for servicing.. I want make sure ... Also I might consider continue servicing at dealer if I dont get the proper data & still worrying on re-sale if not having dealer invoices on hand ( I see it as lesser re-sale value ) - I hope to keep Prius for at least 4 years... BTW I already loved it, I just couldn't get one :) 3 yrs ago I did fall in love on holidays in Spain (airport car rental rented one to me_ prius is lovely to sleep in, in a warm Spanish sole. - I am 3 yrs older now and next hols I think will sleep in a hotel ;)
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    Only for the 2010 and newer Prius. The OP lives in Ireland and recently purchased a 2005 Prius. Only in the Japan Domestic Market did Toyota ever recommend a 0W-20 for a 2005 Prius, and there are temperature limits on its use
    Keep in mind that the EU market Toyota's offer a minimum 12 month or 10,000 mile oil change interval, running ACEA spec motor oils
    BP makes a good oil, Visco 7000, that is intended for severe service. If I recall, BP now has Aral, BP, and Castrol, all are good choices for the EU market
    If you go to the BP global site and click in lubricants, then select Ireland, you will be sent to the Castrol site for your country. You simply enter your vehicle registration number and a recommendation will be made
    I did a general search for Toyota Prius and Castrol recommends their Edge 5W-30. Interestingly enough, Castrol recommends a maximum 36 month or 45,000km interval for the cvt, and they refer you to the dealership for the correct fluid
    Castrol also recommends 10W-30, 15W-40, and 20W-50 depending on ambient operating temperature. Their Edge 5W-30 is made for VW/Audi and +2004 BMW LongLife service fills, which in those cars is 24 months and up to 50,000 km.
    The Edge 0W-30 is also a great choice. This is similar to the Castrol Syntec 0W-30 sold here, which is actually Made in Germany. I have had very good used oil lab analysis results running this oil in the 4 litre V6 that is in my Toyota FJ Cruiser - my FJ is hard on oil, this Syntec holds up
    Keep in mind that motor oil specs here in North America, the API, are complete crap. The bare minimum ACEA spec from 15 years ago is still better than the current API/ILSAC spec
    The current API spec allows cold black sludge, and cold stuck rings. ACEA does NOT allow this. The assumed oil change interval here is 6 months or 5,000 miles.
    Also keep in mind that the ACEA spec in the EU is set by the car makers, and each car maker is also allowed to set their own tough performance specs. Here in North America, the API is primarily represented by oil companies, they are in a conflict of interest as they try to support the oil change industry with frequent oil changes
    So keep that in mind if a forum members expresses horror that you only change the oil once a year in your 2005 Prius, or use a viscosity different from that on the oil fill cap.
    I would recommend you follow your dealership advice for oil quality and servicing interval.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Hi
    My understanding is that the gen2 Prius requires 5w30 oil. Check out the following link to the UK Prius forum which is presently discussing this very issue.
    Prius Gen 2 Oil - Toyota Owners Club - Toyota Forum
    I would add that the www.priuschat.com forum is much more comprehensive though but being a US site, does have a US slant. Hope you're enjoying your new purchase and as others have said, changing the oil and filters is a good way of getting the best out of your new motor.
  8. uart
    uart Senior Member
    4,220
    1,210
    Australia
    Hi Agape. There are plenty of good quality oils to choose from. Give us some more info and I'll make some specific recommendations.
    Questions.
    1. How often (time and or km) do you intend to go each oil change.
    2. What is the lowest temperature you expect to be driving in (especially for cold starts) during the next oil change interval.
    3. How would you describe your typical journeys in terms such as mostly short trips or mostly long trips or mostly rural or mostly city etc.
  9. Agape
    Agape Member
    378
    Ireland/Eire
    Hi All, thank you very much for the time and input.
    @uart:
    1. I think to follow dealers instructions regarding oil change or every 10k kms or 15k kms - not sure on tihs as yet as I need read more about Prius. Note, I didnt get owners manuals handbook with the car and trying to get it from the dealer locally.
    2) Lowest temperature I expect to drive. East Coast is where I live, tempereature here can get in Ireland would be somewhere between minus -5 Celcius / 23F (rarely) ~ 15 Celcius / 59 F - during next oil change interval ( typical Irish Winter)
    Next interval is summer - If summer, then temperature can go up to plus ~28 Celcius / 82.4F (rare) usually colder temp.
    3) Typical journeys: Short trips - trips for shopping to supermarket 4 km or mostly long trips to work 40kms each way.
    80% highway rural & 20% city, plus weekend trips. Whatever distance would be required up to 300-400km however occasionally.
    Agape
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    A "cold" start at -5 C really isn't "cold" compared to Winnipeg and area, which can easily dip to -40 C in winter
    Given the nature of your driving, might as well stay with a xW-30, such as the Castrol Edge product I found. Just curious what oil the dealership uses?
  11. Hal W
    Hal W New Member
    872
    53
    0-20 all year around. Your FE will be better and the ICE will sound great on top of it and run smoother.
  12. uart
    uart Senior Member
    4,220
    1,210
    Australia
    The recommended oil change interval (OCI) varies from country to country. Here in Australia it's 10,000 km and in North America it's 8,000 km (5000 miles). I'm not sure what they recommend in Ireland but I wouldn't exceed 15,000km. I'm sometimes stretching my OCI out to around 13000km without any issues. Consider spending a bit more on oil and using synthetic if you plan to go any further than a 10,000 km interval.
    Ok that's a pretty mild winter, you definitely dont need anything "20" (0W20 or 5W20). You'll be fine with either 5W30 or 10W30 year round, though personally I'd use 5W30 as it will give slightly better fuel economy.
    Not real harsh driving conditions so 10,000 km interval will be no problems. You could stretch it a bit further if you using a very good oil.
  13. uart
    uart Senior Member
    4,220
    1,210
    Australia
    Basically you can choose anything 5W30 from one of the big oil companies (eg Castrol, Valvoline, Shell, Mobil or Havoline). Those guys are big players and you can be sure anything they sell will have been well tested under just about every conceivable condition.
    There's tons of choice but here's some examples (I'll give a lower cost and a higher cost example for each). The lower cost will be ok up to 10,000km but consider the higher cost option if you're stretching it past that or doing any really hard driving. (and in some cases the lower cost options might only be available in 10W30 btw).
    Castrol Magnatec (or FMX) : Lower cost
    Castrol Edge 5W30 : Better/best
    Valvoline "Engine Armour" : Lower cost
    Valvoline Durablend : Better
    Valvoline Synpower : Better/best
    Mobil Super 1000 : Lower cost
    Mobil Super 2000 (may also be called "Synt S") : Better
    Mobil One :Better/best
    Ok they're just some that I use and trust. Shell and Havoline will have a similar range of products. Usually if you choose a brand that's a real high volume seller in your region then you'll get better value for money. Don't bother with expensive "boutique" brands.
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    The OP lives in Ireland and just purchased a used 2005 Prius. Two points
    1. That year Prius, the 0W-20 was only recommended for the Japan Domestic Market, with upper temperature limits
    2. Where in Ireland can you purchase a 0W-20 oil?
    The lightest oil the OP will be able to find will be specialized 0W-30 oils intended for VW LongLife servicing, which is a condition-based oil change interval up to 2 years or 50,000 km
    This specialized 0W-30 oil is actually a "thick" 30 oil. The older formulation is sold here in Canada at Canadian Tire as Castrol Syntec 0W-30, is made in Germany, and meets the BMW, VW, Porsche, Audi, Mercedes specs covering up to about 2004
    The newer specs, such as the BMW one, are 5W-30
  15. Hal W
    Hal W New Member
    872
    53
    Honda dealers have 0-20 and I am sure Toyota dealers do as well. You can purchase 0-20 at any Automotive outlet. I have used it in my HCH2 and garden tractor since 2006. Mobil 1 have had it longer than that. I just purchased Pensoil 0-20 at Canadian Tire. All Toyota dealers have gone away from 5-20 and are now using 0-20. If you want better FE then change. It may suprize
  16. Agape
    Agape Member
    378
    Ireland/Eire
    Hi All, thank you.
    Before i receive responses from Dealer I would like to ask you. I have a feeling that if i was lucky then the oil used was 5W30,this is just guess for this moment, so let's wait for the response to my email sent to Dealer.
    re: (Hal W) post:
    re mileage:
    Would you know if mileage @120,000 kilometers and upgrading from 5W30 to 0W20 would possibly cause a problem to Toyota Prius engine ? - its very important if it may (-is there possibility of some flushing effect at that mileage- i just heard some rumor some time ago...this rumor might be out of date)
    i came across honda website and shortly read about 0w20, then I closed the link and lost it.anyway.. Do you mind me asking you if you, are you using 0w20 on your Prius and if yes at what mileage on the odometer?
    btw, today on way home I went to Halfords (kind of supermarket specializing in car accessories), There were following Engine oils available (I took a look at branded ones) Castrol Magnatec (Fully Synthetic) 5W 30 (A1) (API SL; ILSAC GF-3; ACEA A1/B1, A5/B5) & MOBIL SUPER 3000 Formula FE 5W30 ACEA A1/B1; API SL
    also I did read shop guidance on the Prius oil, there were 3 categories (3 choices for customers):
    1)vehicle manufacturers recommended oil: 5w30 Part Synthetic Oil
    2)ultimate protection: 5w30 Fully Synthetic Oil
    3)Mobil Oil: Mobil Super 3000 Formula FE 5w30
    ...none of above actually stated ACEA or API details...
    please NOTE above 1;2;3 points were only copied from Halfords guidance, thus I cannot confirm the above data to the data from the Toyota Dealer. As soon as i receive response from Dealer i will post update.
    I would love to have 2 Priuses and experiment in one with 0w20 and 2nd prius with 0w30 or 5w30 :)
  17. Hal W
    Hal W New Member
    872
    53
    Agape: I use it year round, I live in a semi arid area, Very hot in summer months. Lots of days over 40+ C. Down to -20c odd day in winter. Also our roads are from sea level to 1400 meters. Lots of up and down. Honda has gone to 0-20 in all their hybrids and I think most other models. I just purchased a 2006 Prius. It had 5-20 in it when I purchased it in Aug. I asked the service manager if it was OK to go 0-20 and he said yes as a mater of fact they just received a directive from Toyota to start using 0-20 in all Hybrid models. You will notice the engine runs quiet and your FE will improve. I use Pensoil Platinum 0-20 synthetic. My Prius only had 19,500 kilometers on it when I purchased it, but I would not hesitate even with the kilometers on your car. H
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    And again, Agape lives in IRELAND which if you look at a map of the United Kingdom, is far far away from here
    Where can you purchase a 0W-20 in Ireland??
    As far as a TSB, I would like to see the exact TSB
    A similar issue came up with 2007 FJ Cruisers, for the rear differential oil. They were shipped from Japan with a straight SAE 90 in the rear end, there were some failures.
    Toyota issued a TSB requiring a specially blended synthetic 75W-85 in the rear end. Evidentally, a lot of dealerships in Canada did not read that TSB, as they still warned customers NOT to use a synthetic 75W-90!
    But the point of 0W-20 is entirely academic as Agape lives in IRELAND. Usually the lightest oil you will find in the EU is a synthetic 5W-30, though VW diesels on the Long LIfe servicing regime (Up to 2 years or 50,000 km) will run a special synthetic Castrol 0W-30
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    I actually did run Mobil 1 0W-20 in my 2004 Prius most of the time I had it. No difference in summer fuel economy, a very minor improvement in winter fuel economy temps down to -40
    I did used oil analysis and had good results with the made in Germany Castrol Syntec 0W-30, Mobil 1 0W-30, and Mobil 1 0W-20.
    You can't get Mobil 1 0W-20 in Ireland. The Mobil 1 0W-30 is the formulation for VW LongLife servicing. The Castrol 0W-30 you can buy in Ireland is also the formulation intended for VW LongLife II servicing - up to 2 year or 50,000km service intervals, based on flexible monitoring onboard.
    You can use a VW oil in your Prius. The VW oil is formulated to hold up under severe turbodiesel demands and also for proper camshaft lubrication.
  20. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Agape I would take Halfords advice with a very large pinch of salt, according to their charts 5W/30 should be used in GEN3 prius witch we all know is wrong it should be 0W/20. I have GEN2 2008 Tspirit with 60,000 miles on the clock and use Mobil1 0W/20 witch gives 1 to 2mpg improvement over 5w/30 under the same weather conditions as you (Hereford UK). Oil change frequency 10,000miles/1year as Toyota specification hope this helps.
