22,500 service?
Discussion in 'Gen 3 Prius Main Forum' started by chesterff, Nov 10, 2010.
  1. chesterff
    chesterff New Member
    TN
    I am a little off-sync with the recommended maintenance schedule -- I last brought my prius in for the 15k service at around 16k, and I just brought it in for oil change at >22.5k. The dealer's service department told me I missed the 22.5k service, involving the fuel system (~$300, 3 hours). Is this a thing? I'm confused, it isn't listed in the manual as far as I can tell (which recommends service at 5k intervals).
    I said no but want to be sure I didn't miss something. I am admittedly naive and I generally just want to go by the book since I don't know much about car care. Appreciate your advice if I'm missing something or if I'm being recommended unnecessary service.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    That service also includes the flux capacitor. :D
    The dealer is trying to play you. Why don't you post their name so other can avoid them?
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    What do they think this is a BMW M3? Only a highly-tuned performance vehicle or a POS deserves to have $300 spent on it at that mileage for the fuel system.
    As always, go with the manual. Also, I'm pretty sure that the official Toyota-sanctioned oil change interval is now 10,000--not the 5,000 in the manual that you may see. I think...I hope so or I've already voided my warranty :)
    Anyway AFAIK and I've never heard differently at all on any car forum is that to maintain your warranty you need do what's in the manual. I'd be very, very sparing about doing anything beyond that since nine times out of ten it's just money in the toilet.
    When you compare the manual to the "dealer recommended" you see a huge divergence. Guess which one costs you more?
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Just bring it in every 10k. mi for an oil change, if your not at all a 'do it urself guy" the only thing extra you should have them do is a check on the airfilter and every year the cabin air filter. Since the Prius now uses synthetic oil yopu shouldn't be paying more than $60 for an oil change and even that is generous. Remeber if you do go to a dealer check their web site for coupons and don't let them push you around, let them know you know what your car needs and doesn't need.
  5. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Read and follow your manual. Don't take this the wrong way but it will save you hundreds maybe thousands of dollars to see what Toyota recomends on your car. It only takes 10 or so minutes to read the section on maintance.
  6. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    This is just another example of a scumbag dealer. The 99% of the bad ones make the 1% of the good ones look bad.
