I'm Back Baby!
Discussion in 'Gen 2 Prius Main Forum' started by macmaster05, Nov 11, 2010.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I'm back baby! After being banned for a week. (banned from Priuschat? Come on! LOL) I'll admit, not one of my finest moments, but whatever. I feel like Steve McQueen in The Great Escape.
    While I was incapacitated I went ahead and purchased H&R springs for my Prius. It'll take 2-3 weeks to receive/install so stay tuned. I'll do an extensive review to make up for all the schlubs who installed lowering springs but didn't provide help to any others. Oops hope I don't get banned again.
    PEACE.
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Welcome back and good luck with your mode. H
  3. bisco
    51,838
    you can be banned from priuschat?:eek:
  4. qbee42
    3,079
    You bet. All it takes is one cheap comment about Tony.
    :p
  5. dogfriend
    7,512
    1,190
    Carmichael, CA
    Like what? :madgrin:
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Who's Tony?:confused:
  7. qbee42
    3,079
    He's that small ghost you see floating around the forums.
  8. qbee42
    3,079
    See my above post for an example.
  9. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I feel like Oprah: You get a ban and you get a ban and you get a ban...
  10. Tideland Prius
    16,547
    Priapus
  11. bisco
    51,838
    is tony cheap?:confused:
  12. macmaster05
    4,050
    730
    Check out what yo boy just got!
    I won't have them installed until next weekend. There's a mild storm and I don't want to bother going out this weekend. Plus tomorrow I wanna watch football. Will update you again after they're installed.
  13. Tideland Prius
    16,547
    Nice! How much do they lower car? 1"?
  14. macmaster05
    4,050
    730
    Thanks! The drop is 1.4"F/0.7"R. On most stock cars, including the Prius, the front lifts up and the rear sags. At minimum these springs should help correct that issue. Ideally it should give it an aggressive, raked stance.
  15. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    can i get a VW instead?
  16. Tideland Prius
    16,547
    That's not bad.
    Yeah esp. since the Gen 2 doesn't have that upward trending design (at least not as obvious) as the Gen 3.
  17. macmaster05
    4,050
    730
    Hello hello hello!!!
    I'm very excited, because I just got back from lowering my Prius! The install job took 2 hours and costed me $150 at S.W.A.T. Customs in Fremont CA. It was the cheapest place I could find, others quoted me $300-400. George, the owner, was super friendly. He mainly does lift kits on trucks or lowering kits on American muscle cars, so I didn't know what he'd think when I showed up with a Prius. That didn't make a difference -- he was awesome.
    The H&R Sport Springs for Prius (Part#29062-1) I used were never specified for the Touring. Some members with Touring editions had installed them on their car and seemed to have no problems. That's what I went off. After 2 hours the job was finished. George told me that the front 2 springs went on just fine, as I expected. HOWEVER, he said that rear H&R springs weren't made for the Touring. He says they were 1/2" too short. Here's where the problem would be: if I went over a bump really fast so that the back of my car lifted up, there'd be no spring load. That is, the spring is loose. So when the back of the car comes down it could make a loud thud/boom because its landing on the spring again. George was kind enough to explain all this to me, reassuring me that under normal driving conditions and even bumpy roads, this won't make a difference at all. So this doesn't concern me, but I think George might be wrong that "the spring wasn't meant for my car/Touring." Is the length of the strut actually different between a Touring and non-Touring? No I don't think so, and I think a non-touring owner would run into this "issue" as well.
    Anyways, I tested the spring load out in a parking lot with speed bumps. If I was going fast over the speed bumps I would get that "BOOM" from the rear suspension, a result of the "loose" rear springs. If I was slower and careful though, no issue at all.
    In case you're wondering if this mod was worth it even despite the thing George noticed, having driven home, I think it's totally worth it! Here's why:
    Handling: Turns feel solid. There's little to no roll. I feel connected to the ground more. People talk about the chassis brace. HAH! That's nothing. A lower center of gravity is a REAL difference.
    Comfort: Surprisingly, just as wonderful as before. Even over bumpy roads I couldn't tell I was on different springs. And this was huge for me. If I could feel and hear every jitter, bump, squeak, I would probably regret this mod. But this wasn't the case, and I'm so happy!!...
    Looks: (drop = 1.4"F/0.7"R drop) To me, it looks more aggressive, especially a view from the front. Other non-Prius owners probably won't tell. For both of us, however, the drop definitely makes the Prius look "right," proportional, and as it should be. Now every other Gen II Prius looks too tall and awkward. The springs have settled a little more since I drove home, but maybe no more than an eighth of an inch (good springs aren't supposed to settle anyway). I'll have to take/post more pictures of this later.
    For now, thanks for reading!
    Pic 1: Before
    Pic 2: After
    Pic 3: Before - fender gap LF wheel
    Pic 4: After - fender gap LF wheel
    Pic 5: Before - fender gap RR wheel
    Pic 6: After - fender gap RR wheel
    Pic 7: A throwaway
  18. macmaster05
    4,050
    730
    Just got back from my wheel alignment. Camber is in spec, surprisingly I GAINED camber. That's not supposed to happen...oh well I'm not going to complain. Toe was way off (-.25) so they set that to -.01. SAI is out of spec on my RF wheel (13.5) but I'm not worrying about that. Lifetime alignments at Firestone are awesome!!
    I am so enjoying my new lowered Prius.
