2008 Spark plugs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Becual, Nov 13, 2010.
  1. Becual
    Becual New Member
    Leesburg V.A
    Hey does any one know if I should change my spark plugs I just turn 60,000 mile mark. The dealer want $480.00 for the seviced check at 60,000 I think that really high any thought's?:confused:
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I have not seen your spark plugs, but in general Toyota thinks they will last 120,000 miles. (I am using a 2009 Guide, as that is what I own)
    60,000 miles or 72 months
    Replace cabin air filter
    Replace engine air filter
    Replace engine oil and filter
    Rotate tires
    Inspect the following:
    __ Automatic transmission fluid
    __ Ball joints and dust covers
    __ Brake lines and hoses
    __ Brake linings/drums and brake pads/discs
    __ Drive belts
    __ Drive shaft boots
    __ Engine valve clearance
    __ Engine/Inverter coolant
    __ Exhaust pipes and mountings
    __ Front differential oil
    __ Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
    __ Fuel tank cap gasket
    __ Radiator, condenser and/or intercooler
    __ Steering gear box
    __ Steering linkage and boots
    Additional Maintenance Items for Special Operating Conditions
    Driving on dirt roads or dusty roads:
    Tighten nuts and bolts on chassis and body
    (Even at Dealer prices, I would expect this to cost around $100 unless something they inspected actually needed replacing)
    120,000 miles or 144 months
    Replace spark plugs
    Rotate tires
    __ Drive belts
    (Even at Dealer prices, I would expect this to cost around $150 unless something they inspected actually needed replacing)
  3. bisco
    51,558
    should be about a hundred fifty bucks. plugs not necessary.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    That looks more like the maintenance guide for my FJ Cruiser.
    There is nothing to grease on a Prius. The cvt fluid is 4 qts and easy enough to diy.
    The spark plugs should be good to at least 100,000 in a Prius. Once you unbolt and swing that relay box out of the way, very easy to diy. The FJ uses regular spark plugs that need to be changed much more often, but also an easy diy
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    60,000 is way too early for iridium tipped plugs. $480 is way too high for any level of preventative maintenance!
    I recently changed out plugs in my '04 RAV4 for the first time, at 150,000 miles. Only one plug looked truly worthy of replacement, though I did not yet have any problem with misfires. Replaced with Denso Iridium IK20 plugs, grand total of $34.44 for four plugs from Amazon.
  6. jreed
    jreed Member
    84
    71
    North Carolina
    I changed the spark plugs on my 2006 Prius at 101.7k miles yesterday. It took about 90 minutes. I used NGK IFR5T11 to replace the NGK IFR5A11 's that were in the car. I got the parts at Advanced Auto, where they come up under code 4996 and cost $7 each. According to the manual, the relay box bolt torque spec is 6.1 ft-lbs and the coil bolts are 6.6 ft-lbs. The spark plugs torque to 13 ft-lbs. Good luck! :)
    davisnc and Becual like this.
  7. Rest
    Rest Active Member
    1,210
    CA
    Are "Stealerships" out of their minds?
  8. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    The only things I would recommend beyond the manufacturer's list above would be to change the transaxle oil, and especially if you DIY, to remove and reinstall the spark plugs with anti-seize. I have 160k on my 08, when I changed the plugs at 120k, they were very difficult to remove, and required much care to avoid stripping the threads.
    If you are going to use a dealership, make sure you do not buy one of those "packages". Tell them exactly what you want done based on the manual, and get a price quote before the repairs.
    Good luck with your Prius!
  9. jreed
    jreed Member
    84
    71
    North Carolina
    +1 on the anti-sieze recommendation. I originally removed my plugs at ~65K back in 2008, and cleaned them up and applied antiseize, and then put them back in. They were very rough and difficult to remove at 65K. This past Saturday, when I removed them at 101.7K, they came out much more smoothly than they had come out at 65K. This time I replaced the plugs with new ones. I put a little fresh antisieze on the new NGK's ( just a little dab smaller than a pea that I smeared around into the threads).
  10. Hassan
    Hassan New Member
    Fredericksburg, VA
    Can anybody help me on how to change spark plugs on 08 model ?
    Thanks
    Hassan
  11. Patrick Wong
    18,200
    6,500
    What help do you need? Post #6 provides tightening torque and one suggested source for the correct replacement iridium spark plugs. The normal replacement interval is at 120K miles.
    The overall process is to remove the relay box mounted to the cowl, to improve your access to the spark igniters. Then disconnect the wiring harness connectors attached to the spark igniters, and then remove the igniters. Inspect the igniters, looking at the terminals for corrosion and the plastic body for any cracking or burn marks. If you see any problem, replace the igniter.
    Remove the old spark plugs and examine them, looking at the porcelain insulator at the tip to see what combustion deposits have formed. A very thin layer of deposits is normal.
    Then while observing the tightening torques listed in post #6, install the new spark plugs, replace the igniters, reconnect the wiring harness connectors (making sure that each one is locked in place, you can hear a little click as the connector engages) and then replace the relay box. Then make the Prius READY and take for a short test drive. Good luck.
    priusvid likes this.
  12. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Every time I see this subject line the first thing I think is... wow, 2008 plugs would be enough plugs to do complete changes to 502 Priuses. Is that just me or do others out there see this? Or maybe you will now?
  13. priusvid
    priusvid Junior Member
    32
    Calgary, Alberta
    going to tackle the plugs next on my 2008 w/ 600,000 km! Helpful post - thanks a lot. Yesterday it was quirkin out red triangle loss of power, today was all good, even got some green bars... Only other concern is the big jerk that happens when the ICE kicks on..
  14. Fartsalot
    Fartsalot Junior Member
    35
    West of the Kansas Speedway
    Look up on utube and you will find how to do the change of plugs it is easy peazy. Don't forget the anti seize on the threads and as a added bit of advice put it on the wheel studs as well the next time you remove a wheel.
