Dash beeps after shutdown, then needs jump
Discussion in 'Gen 2 Prius Technical Discussion' started by honoreitiscom, Nov 14, 2010.
  1. honoreitiscom
    honoreitiscom New Member
    OK has anyone experienced this in a Gen II? My 2004 will occasionally beep from the dash after shut down (until I close the door). If I ignore the beep, close the door and walk away, the next morning it will need a jump start!
    My dealer said it was because I was shutting down before putting it in Park. I always thought Park was unnecessary. Anyway, I got in to the habit of putting it in Park every time before shutdown, and still sometimes I get the dash beeping when I open the door.
    To avoid having to jump it, when I hear the beeping I re-start it and park it all over again.
    This seems to happen the most when I do the entire parking process very quickly: come to a stop, immediately turn off the car, immediately unlock the seat belt, immediately open the door, and then beep beep beep. Its like I confused the car.
    Why is it beeping? What is it trying to tell me? What mode is it in after I close the door, and why does that mode drain the battery? Is there a fix so this won't happen any more?
  2. john1701a
    john1701a Prius Guru
    12,794
    5,275
    57
    If you are still using the original 12-volt battery, replacement is overdue. Not being able to hold a charge after 6-7 years of use is typical for both hybrids and traditional vehicles.
  3. richard schumacher
    7,664
    1,042
    United States
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    A dying fob battery will cause a beep at shutdown. It may be that the fob battery needs to be replaced. As John said, if your 12v battery is the original, then it should be replaced also.
  5. qbee42
    3,076
    Your dealer is wrong about shutting down before Park. It makes no difference.
    Almost certainly you have a 12V battery issue. If you haven't replaced it, now is the time. Likewise check the battery wires for corrosion and loose connections.
  6. honoreitiscom
    OMG. What incredibly helpful suggestions! You people rule! Why didn't I post this here earlier? I'll look into both the fob battery and the 12V battery in the back of the Prius and report back...
    Thank you all!
  7. honoreitiscom
    My 12V batt is showing 9.6V in acc mode after a half hour drive. Not good. Should be 12.4V to 12.8V. Looks like I'm overdue for a new one.
    Any recommendations on where to get one? Are the "yellow top" batteries on line any good? I'm comfortable installing it myself.
    Thanks again for the great advice.
  8. qbee42
    3,076
    The yellow top batteries are good, but whether they are worth the extra cost is debatable. If you do buy an Optima, make sure you get the installation kit, as it is required to make it work with the Prius.
    The alternative is to buy an OEM battery from the dealer and install it yourself. Several threads on this site have detailed instructions.
  9. honoreitiscom
    Just put in a new 12V battery from the dealer ($153.96, I did the labor) and now in ACC mode it is reading 12.5 V rather than 9.6 on the old one. Thanks again for the great solution. I'll report back to say if the new battery fixed the beeping after shutdown symptom, which it probably did.
  10. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    The Optima Yellow Top from eLead really isn't materially more costly than the OEM. It is $165 including Free shipping.
    (I realize that the OP did replace his with the OEM Toyota, but wanted to make the point that the Optima isn't much more).
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    I have a 2007 and almost always shut the car off in Park for 3 years and have never heard a beep. Its amazing the stuff you hear at dealers about this car.
    The main reason people kill there batteries on this car is they do not lock the car every single time they leave it especially in the garage.
    Never leave the car unlocked anywhere for any reason.
    If any door or hatch is ajar it will not allow you to fob or door button lock the car. Door or hatch open and light is on killing the battery. The car will beep twice. It has saved me many many times.
    Toyota gave us the tools but so many people do not use them.
    And its easy to replace the FOB battery. The little slide lock button on the top of the FOB if pushed over releases the metal car key. Just pull the key out while holding the slide over. Then with key removed and your thumb on the back side of the remote the one with the Toyota emblem push the cover off towards the slide lock with your thumb while holding the slide lock over in release postion. The cover should slide right off. NO tools needed. Do not pry on it!
    Once that cover is off you will need a tiny phillips screwdriver to get the 4 battery cover screws off and a CR2032 battery found at Home Depot.
    Good Luck.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    This is a little off topic...so I apologize upfront.
    But I think Prius Chat is a fantastic resource for anyone who owns a Prius. Seriously, when I was making my last automotive choice...Prius Chat itself was one of the postives I listed in the "Buy a Prius" column.
    But I'd also think after a year or so of lurking, participation and observation, that Thank God Prius Chat is an available resource...because Toyota seems to have a problem on a dealership service level.
    Not just this case, where the dealer had no idea what was really causing the problem, but too many other threads where Toyota Dealership Service departments seem far too lacking in Hybrid Prius knowledge. (This was something I put in the negative column)
    I mean how many threads where a Prius Owner has a problem...and the dealer gives a totally erroneous answer? IMO too many.
    IMO there it's ridiculous how many times Prius owners have reported dealerships that have overfilled the Prius after an oil change. That's inexcusable.
    Especially if Toyota is expanding Prius into a line of itself...and expanding Hybrids as a whole? They need to get their dealership service training up to speed. Toyota can say "The Prius Family" is growing...but they need to get their service infrastructure improved and growing with it...
    Either that or Prius Chat should be getting a big fat paycheck from Toyota Motors...for providing what their dealerships all too often seem to fail to do, providing the Prius Owner with the correct information...
