Drop in mileage in Mid-west winters
Discussion in 'Gen 3 Prius Fuel Economy' started by alokeprasad, Nov 19, 2010.
  1. alokeprasad
    alokeprasad Member
    162
    Ohio
    How much drop in mileage are folks in the Midwest (Ohio etc) seeing in the winter months?
    Is the drop from 52 to 47 sound reasonable?
    The cold weather and reformulated gasoline sure takes a toll on the fuel economy ...
    51,504
    yes. i've gone from 65 in summer to 60 now and will drop to 55 over the next coupla months. search 'grill blocking'
  3. alokeprasad
    alokeprasad Member
    162
    Ohio
    I suspect that most of the drop is because of the reformulated gasoline. A good cooling system design should be able to maintain the optimal operating temperature by controlling the coolant flow rate ..
  4. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    Harsher winter (further west & north, like MN) does this to efficiency...
    2 people like this.
  5. eaglesight333
    eaglesight333 Senior Member
    6,898
    Northern, IL
    Yep. It sounds about right. It is part gas blend. And part the need for the hybrid battery to work harder at staying warm.
  6. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Everyone sees a drop in mpg's during winter, just more noticeable on the Prius! Grill blocking and an EBH helps alot!
  7. vday
    vday Member
    312
    Israel
    I believe that too be true only in colder climates:)
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It has been in the single digits up here and my current tank shows about 43 - 45 mpg down from 52 this summer. No change in fuel blending. 100% blocking of the lower grill.
  9. Peakbagr
    Peakbagr New Member
    33
    Capital Dist
    Got the Prius in late March 2010 and have been averaging in the mid to low 50's MPGs. About 6 weeks ago, in October (upstate NY), averaging high 40's and can't seem to ever hit 50MPG average.
    Isn't it too early in autumn to have the MPGs drop this quickly? I thought it might be older oil. I had the oil changed at 5k and just took it in for 10k checkup. But the mileage hasn't improved.
  10. alokeprasad
    alokeprasad Member
    162
    Ohio
    In my case, the mileage dropped (by 4 mpg)s uddenly (over 1 fill-up) this time last year and this year. It increased dramatically over 1 fill-up in spring.
    To me, that says that the culprit (for the most part) is the winter reformulation of gasoline.
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    It's more than just winter formula gasoline. See below:
    Why does mileage drop in winter? — Autoblog Green
    Cold Weather Vehicle Fuel Mileage – Why Winter Fuel Economy Drops – Fuel Mileage Drop in Vehicles
    Car Talk
    http://www.startribune.com/cars/11354696.html
  12. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    i have seen a drop from 53 to 46. that started about three tanks ago.
  13. DavidA
    2,342
    1,818
    Chicago western burbs
    45 summer to 33 winter. Lower mileage in my case is due to working only 1.25 miles drive from home.
  14. Snake
    Snake New Member
    89
    I live in Southern California, and I bought my car a couple weeks ago. Of course once I do we get one of the coldest winters in my area. My MPG is around 42 average. I thought I was doing something wrong, but I guess new car plus really cold is the culprit.
  15. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    It should rise as weather warms. What were you expecting and why?
  16. john1701a
    12,802
    5,286
    57
    That begs the question of what MPG you got with your previous vehicle. I remember observing higher RPM in my Taurus during initial warm-up. When it finally dropped to normal, that was my indicator of when heat was available.
  17. CTpriusV
    CTpriusV Junior Member
    70
    Bristol Ct
    Same thing hear in Ct, dropped 4 mpg in one tank and it's not all that cold yet, is the milage going to to get even poorer when the temps drop to the 10 and 20 degree mark?:(
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    For me last winter it seem to bottom out @ 43mpg and it got sub-zero. Of course I also have a garage.
  19. PriusRoadWarrior
    76
    Wisconsin
    Here in Wisconsin, my 2010 dropped from approx. 54 in the summer to 46mpg during the January, February time frame and then went back to normal.
  20. DavidA
    2,342
    1,818
    '94 GMC Safari. Yeah. It was much much worse. :D
