Bringing in 04 Prius for Battery maint and need advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryanpl, Nov 22, 2010.
  1. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    Hi everyone, I think Whilamenia has a pain in her HV battery and am bringing her into the doctor tomorrow, Bay Ridge Toyota. The patient is a 2004 Prius with approx. 108,000 miles. She is currently exhibiting the following symptoms: low MPS (approx 35 mpg), is not holding a good charge the ICE has been runing more and more often, and all of a sudden there is a sweetish smell coming from the HV rear HV vent and it's smelled throughout the car. Does anyone have any specific questions/diagnostic tests I should have them do on her, hint,hint Patrick :rolleyes:? Luckly she was originally bought in a CARB state, MA, and is not being operated in NYC so there is the 120 month/150k mile warranty. Ryan
  2. Patrick Wong
    18,200
    6,500
    1. The smell is probably from the battery module vent tubes. I'd be surprised if the dealer will take any action regarding their replacement unless you offer to fund that service.
    2. Regarding lower-than-normal mpg and the other driveability symptoms you mentioned, I doubt that the dealer will take action regarding traction battery replacement since your car doesn't have any warning lights on.
    3. You will likely be asked to pay for the tech's inspection of the battery. The Toyota diagnostic laptop should be able to produce a report showing battery module voltage and internal resistance.
    4. If you search eBay Motors you'll see that batteries from relatively new 2G with low odometer readings can be purchased for ~$400-$500 or so, plus shipping. If you can't get the dealer to take any action under warranty, and the low mpg continues, maybe installation of a salvage battery would be reasonable.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Have you verified that it is not the 12V that is going bad?
  4. Ryanpl
    780
    158
    Brooklyn, NY
    Seeing as how I just put in a new Optima Yellow Top I doubt the 12v is bad.
  5. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Let us know how it turns out Ryan. :)
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    At least NY is a CARB emissions state, so the OP should have a 10 year/150K mile warranty on the HV battery.
  7. Ryanpl
    780
    158
    Brooklyn, NY
    From what I understand it's not the state where the car is currently being used that matters but the state where the car was purchased. In my case the car was purchased in Mass which is also a CARB state. Sick as it sounds I'm hoping it's the HV battery cause that would be the cheapest repair since it's under warranty :)
  8. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Not sick......normal.:D
  9. seilerts
    3,326
    1,518
    Santa Fe, NM
    LOL!
    How did your visit go? 108,000 miles seems early for an HV battery failure, but luckily you have the CARB warranty.
  10. Ryanpl
    780
    158
    Brooklyn, NY
    humm well it seems like there was a problem with the 12volt install. The connections were tight enough to power the car but not tight enough... That was the reason for low mpgs. Stealership tightned connections and did some brake work which was needed, front roters were shot and all breaks needed adjustment. Since it's nyc $800 later car is good once again. Stealership labor rate is $96/hr which is actually cheaper than Pepboys which charged $102/hr.
  11. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    "humm well it seems like there was a problem with the 12volt install. The connections were tight enough to power the car but not tight enough... That was the reason for low mpgs. Stealership tightned connections "
    Thanks for the insight. I'll have to remember..tight, tighter, tightest ! :rockon:
  12. Patrick Wong
    18,200
    6,500
    I can believe that your car had a problem with loose 12V battery cables. However I doubt that was the reason for the low mpg. As you drive the car over the next few weeks you'll be able to see whether there in fact is an mpg improvement or not.
  13. Ryanpl
    780
    158
    Brooklyn, NY
    Well in the past couple of days I've seen my MPGs return to what they were before the 12v change.
