Gear shifter light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by baker2gs, Nov 11, 2010.
  1. baker2gs
    baker2gs Junior Member
    40
    Chicago
    Hi this is my first time posting. I've had my Prius for about 6 months now, I've used these boards for a number of resources and reference to learn about my sounds and quirks about this car and I really love it.
    I had a question about the light in the gear box/shifter on the dash. Mine seems to work occasionally. Sometimes when I shift into a D or B it'll pop on. Lately it's stopped, I was thinking maybe I have a short in it or it needs to be replaced.
    Upon searching through the forums it appears I'd have to replace the whole shift mechanism, is this correct?
    If that's the case then it's something I can live with. Just wanted confirmation. Thanks in advance.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    What light on the shifter? To my knowledge there isn't one.
  3. baker2gs
    40
    Chicago
    There's a little light at the base of the shifter in the dash that lights up the entire joystick and the icons at the end R, N, D, and B. I assume yours is probably out too and it's a common thing. If you hold a flashlight right to the base of the shifter you'll see what the light does.
    I did a Google Image Search but I couldn't find a photo of a lit up dash in the dark. If the light miraculously decides to work one day I'll snap a photo.
  4. Patrick Wong
    18,200
    6,500
  5. baker2gs
    40
    Chicago
    Yeah I saw that post, I didn't want to reopen an old thread, it says that the light and wire to it are separate. I assume I have to open the whole dash to get to it, not really what I want to do but it's good to know that I don't have to buy a whole new shifter.
  6. firepa63
    1,761
    208
    Geez, time for new glasses. I had my 04 for 5 years and now have an 09 and I never noticed the light.
  7. baker2gs
    40
    Chicago
    Just a quick update, I followed the directions from Patrick's post on changing the gear shifter. I did not have to detach any harnesses to get to the bulb. I got it out, took off the green rubber cover and it was black so it was clearly burnt out. I should also mention the cover tore off and would be unusable for the new bulb.
    I went to the autoparts store and did my best to match the bulb. I had a few choices, a 1.2 watt and a 3.7 watt so being an energy efficient car I went with the 1.2. On my way back I stopped by Walgreens and got some lime green nail polish to paint the bulb. When I got home I tested the bulb first before painting it and it worked fine. Looking back I think the low wattage bulb alone would have been fine with out the paint/polish. Anyway the shifter is illuminated and I'm a happy camper. Thanks for the help.
  8. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    I recommend replacing all those little horrible bulbs with blue LEDs. They will last forever, be easier to see, and look WAY better!
    The power button, Park button and shifter all originally had bulbs with green silicone filters on them. All of mine are now LEDs. (with series resistors)
    The Steering wheel controls, radio and MFD buttons were all SMD LEDs, but I replaced them with Blue units instead so they match. I also had to do the "Ready" and "A/C Auto" indicators!
    For the steering wheel, I added a small circuit that turns them on high brightness when the ignition is on (daytime) and then dims them to a low setting that's adjustable with the other dash lights at night. The LEDs I used were many times brighter than the originals, so in some cases I changed the series resistors to make them a more reasonable brightness.
    I've also replaced all exterior lights on the car with LEDs except for the Headlights (HID) and the reverse lights. (still incandescent)
    The camera doesn't do the deep blue color justice, it looks way more striking in person!
  9. baker2gs
    40
    Chicago
    Wow, I like the look. I came across some posts on convert to LED's when I was searching for stuff about this light. Maybe one day when I have some time I can do this.
  10. Tideland Prius
    16,542
    Very cool. That's how it should look like. I'm more impressed with the last photo. It looks like a steering wheel from 2010.
  11. pEEf
    720
    579
    Berkeley, CA
    The steering wheel is what started it all. The original LEDs in there were so dim I'm not sure why they bothered. Now they are so bright it actually shows up blue during the day! (and they do dim at night)
    Once I had that done, I had to do the rest. The blue was too cool!
  12. wrexed03
    wrexed03 New Member
    42
    Melbourne Australia
    That looks great. Someone needs to post a how too... In regards to pulling everything apart and replacing the bulbs etc etc... Hint Hint :)
  13. pEEf
    720
    579
    Berkeley, CA
    Disclaimer and Warning:
    I don't recommend anyone attempt this mod unless they are experienced with electronics and in particular SMD rework. All the LEDs used in the existing car are SMD and it takes skill and experience to pull off SMD removal and installation of new LEDs. In my case I also changed many of the series current limiting resistors to get the brightness correct, as the blue LEDs I used were many times brighter than the originals. In the case of the incandescent bulb swap, like in the shifter, park and power buttons, I used a T1-3/4 LED with an added series resistor. It takes understanding of the electrical properties of the various LEDs and application of Ohm's law to determine the correct resistor values.
    Opening up all the various parts and modules was the easy part!
    I also had to build a circuit to control the LEDs in the steering wheel, as by default they come on full brightness and do not dim like the other LEDs. There are spare unused contacts on the "clock spring" connector the connects everything in the wheel. I think Toyota refers to this as a "spiral cable assembly". If someone wants to tackle this job, I am willing to provide a schematic.
    If anyone does attempt this, you are on your own. I am not responsible if you destroy anything in your car! You must be especially careful with the complex assemblies in the Radio, MFD and Instrument display. They are fragile and susceptible to damage from ESD which is a big concern with colder weather.
    That said, I think this mod is definitely worth the effort if you have a spare day!
  14. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    NICE JOB!!!
    +1
    This would be a mod that I can do, would you PM me copy of yor circuit! The photos are very nice especially tha last one, nice!! Where did you get the SMT LEDS from. What are the part numbers?
  15. pEEf
    720
    579
    Berkeley, CA
    Thanks for the compliments, unfortunately when I did this mod I didn't think of documenting it closely. I can probably draw you a schematic of the added circuit I added to make the steering wheel LEDs dim/brighten with the control and come on during the day, but that's all. Anyway, This circuit isn't strictly necessary if you put in ones that aren't as bright as mine were. (which is likely)
    I didn't write down the values of the resistors I changed, they were arrived at after testing each unit and observing that the blue LEDs in most cases were way too bright. (much higher efficiency than the OEM ones!)
    I used LEDs from my existing stock, I didn't have to order any. There were several types used depending on where they were installed. I don't keep part numbers for them unfortunately, but I think most came from Mouser or Digikey. Just look up the sizes and try to match the package style. The forward voltage on blue is usually a little higher, so this can affect the brightness as well, but in most cases I found this not to be true.
    The best way to do this is get online and order an assortment of blue SMD leds of several sizes, and also get a handful of standard T1-3/4 wide-angle ones for the incandescent replacements. This way you only have to take things apart once. LEDs are not that expensive, so anything you can do to save time is usually worth it.
  16. pEEf
    720
    579
    Berkeley, CA
    Sorry people, I simply don't have the time to help everyone out with this mod. Please do not PM me asking such. I will only answer questions here in the public forum so everyone can benefit.
  17. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    Wow, I never realized there were lights on the steering wheel! I will have to take a closer look.
  18. pEEf
    720
    579
    Berkeley, CA
    Yeah, they are so dim, I'm not sure why they even bothered!
  19. KK6PD
    4,003
    946
    118
    Yeah, that Blue is nice, how did you pop the covers on the stereing wheel? Are they screwed down, or did they just pop up???
    I need to get serious about this and figure out the LED size and order a mods worth!
  20. pEEf
    720
    579
    Berkeley, CA
    There are 2 little plates on the sides of the wheel. One is around the cruise control stalk. Pop these off, then you will see a T-40 (IIRC) Torx screw on each side. Loosen this fully, but be warned it will not come out. Then the airbag assembly should slide out from the center. Once this is away, you can grab each button module and pull straight out from the wheel and it will come free. There is a connector that you can disconnect.
