Engine Oil Flush...Any Harm?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron, Dec 2, 2010.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Just curious if doing an engine flush (not coolant) would do any harm. Just open the oil filler cap, pour in the engine flush and let engine run for a few minutes...and bingo...your engine is cleaner. Right?
    I just hit 50K on my 2008. I've been doing Mobil 1 oil changes every 5k since I bought it new.
    Also....will fuel cleaners added every 5K hurt/decay the fuel bladder? I could have swore I read that somewhere on the forum, but I couldn't find it.
  2. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    Don't waste your time or money, and don't risk your engine. If you've been changing every 5k since the car was new with Mobil 1, I guarantee there won't be anything in there to flush out.
    2 people like this.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Well since you asked..... I think it's a complete waste of time. The Prius has the cleanest running engine and oil for any car that I've owned. If your changing your oil at 5k and using Mobile 1 to boot I bet the oil is almost as clean when you drain it as when you put it in. A can of Chevron Techron in your gas every now and then is ok but even that's probably not needed, but I wouldn't screw around with the engine doing a flush....If it ain't broke don't fix it.
  4. richard schumacher
    7,664
    1,046
    United States
    An "oil flush" does no good. Still, everyone needs a hobby.... Fuel treatments are another waste of money. Use E10 regularly and the injectors and valves will get all the cleaning they need.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    No flush in fact extend your change out to 10K with Mobil 1.
    I run the same as you and change every 10K. But I change out just the filter with an oem filter every 5K.
    If you want to be nice to your car change the cvt fluid. Your due.
  6. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I have to change every 5K to keep my 100K warranty. As soon as I reach 100K I'm for sure extending my oil changes.
    How do you figure I'm due for a CVT fluid change? I don't see it in the scheduled maintenance guide. It says just inspect.
    If I do need it...what is a reasonable cost at the dealer? How do I do it myself?
  7. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 is at 187,000 miles and I am still changing syn oil every 5k miles
    I am part of a group that has been doing lab testing of our used Type WS Toyota ATF. Mine has been changed every 60k miles and testing showed that the first batch was used up. The ones at 120k and 180k miles have tested successively cleaner (most likely due to the gears "lapping in"). We now suggest that the best protocol for extending the life of a Prius Tranny is to do a first ATF refresh at 30k miles (although at 50k you are still alright) and then each 60k miles thereafter.
    My dealer in CT charges me $100 for the job.
    There are instructions in an older thread of this discussion group. It is a reasonable DIY job, but you have to go to the dealer for a gallon of type WS ATF and two gaskets for the fill and drain bolts.
    JeffD
  8. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Thanks for the info. I read some threads and I can't for the life of me find the fill cap under the hood. Anyone have a picture? I figure if I can change my own oil I can change the CVT fluid.
  9. Patrick Wong
    18,200
    6,501
    The transaxle ATF fill plug is located on the side of the transaxle that faces the radiator. You will need to raise up the car on jackstands, then put your head under the car so that you can look up in the space between the radiator and the transaxle. Use a trouble light or flashlight if necessary.
    The fill plug requires a 24 mm socket. The drain plug is on the bottom of the transaxle and requires a 10 mm hex key socket. Do not confuse this drain plug with a nearby drain plug which is for the inverter and transaxle coolant. That plug requires a 24 mm socket.
  10. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Thanks Patrick. What diameter hose did you use to fill? I don't have jackstands, can I use ramps? Does it HAVE to be level? Only the front would be raised.
    Also...does the CVT take exactly 4 quarts?
  11. Patrick Wong
    18,200
    6,501
    I have a plastic transmission oil funnel with an add-on flexible hose, for a total length of 3 feet from top of the funnel to bottom of the hose. The outside diameter of the hose might be 1/2" or so, I don't know for sure.
    I suggest that you obtain a similar funnel. If you use an attached hose, it needs to fit snugly to the funnel. I use electrician's tape to hold the hose tightly in place.
    The car does not have to be level, and adding 4 US quarts is good.
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Aaron. Out of all the DIY's you could think of that one would have to be the biggest waste of time and money and more likely to do harm than any good. Absolutely pointless given that you're feeding it Mobil-1 every 5k miles.
    Re the ATF change, that's a much better idea. I just did mine about 2 weeks ago at about 62000 miles. I used info I found on this site (there's a thread somewhere with pictures) to help me locate the correct drain and filler holes and it was definitely a pretty easy job. I guess it took me about an hour in total, but about half of that was preparation.
  13. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I'm reading different opinions on ATF change intervals. 15k?, 30k?
  14. boppo
    boppo Active Member
    799
    139
    Owego, NY
  15. jdenenberg
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The 2001-2003 Prius uses Type IV ATF and needs the shorter interval (sugessted is 15k then each 30k thereafter. The pan needs to be dropped and cleaned in this earlier model.), but from our testing of 2004-2005 Prii, the 30k, 60k, 60k, ... protocol looks good (You can extend the later refills to a somewhat longer interval if desired).
    JeffD
  16. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Ramps work, just recently did mine on ramps. Stick some wedges behind the back tires tho for safety. I felt it might be a little inaccurate to check the fill level with the front lifted but it's probably not an issue. I rolled off the ramps and then stuck my finger up there with the car level just to recheck, wasn't easy!
    Some of us just enjoy doing these things ourselves, but it's not quite as simple as an oil change.
    - D
  17. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Did you find less fluid drained out because it was on ramps? Is it necessary to check the level with a finger if we know it takes 4 quarts?
  18. don_chuwish
    823
    190
    Southern Oregon
    Draining was OK. But when filling, with the fill hole up front, I just had the sense that it would tip the level too low away from the hole. (This is the kind of anal silliness that makes DIYers not want to leave it to the pros!)
    It didn't take the whole 4 quarts in my case, I have about 8oz still in the last bottle.
    - D
  19. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Since it doesn't quite take all 4 quarts, do I fill until it reaches the threads of the fill plug?
  20. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah that's the idea of having the filler hole on the side like that. When it starts draining back out the hole as you're filling then you know it's full.
