Preparing for a roadtrip
Discussion in 'Gen 2 Prius Main Forum' started by richbrvd1987, Dec 2, 2010.
  1. richbrvd1987
    richbrvd1987 New Member
    26
    West Hollywood
    So the holidays are here and it's time for my east coast turn around. Never done it in a prius before, and though it's much like a normal car I just want to make sure it's in it's best shape before I drive 2,600 miles non stop in the old girl.
    I've got a check list of all the service before I go that I've got an appt to do, and just want to make sure theres nothing else the Prius geniuses here can think of.
    Having the transaxle drained and refilled (at 42,000 miles)
    the customary oil change (Mobil 1)
    had new tires put on it a few hundred miles ago (42/40psi)
    having the HV water pump swapped out and the coolant recovery pump changed (thank you toyota)
    Going to run a tank of fuel with some techron in it through
    Anything else? I've never driven any vehicle non stop for more than 10 or 12 hours so running it for 37 hours has me a tiny bit nervous. Anything to be wary of?
    It's an '07 with 42,000 fantastic miles
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    You should be in good shape. Your right it's just like any other car, make sure the oil and other fluids are at the correct level, make sure you got a clean air filter and your tires are at the proper pressure and you should be good to go. We drove our 05 Prius from Pa. to Ca. and back no problems and during the winter go back and forth to Fl. quite a few times with our 10 Prius, it's a great car for trips.
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Did you say non-stop for 37 hours? By yourself? That's insane. The car will be fine - it's you I'd be worried about.
  4. richbrvd1987
    26
    West Hollywood
    Not by myself, my partner is coming as well so we'll drive in shifts. I would love to not have a non stop drive, but He and I both just got back into the job place so we don't have the extra funds or vacation time to be gone more than 5 days and both our families live in Florida. We had to skip the last 2 holiday visits due to budget restraints and even this time we can't fly (at $800 bucks a seat). With 5 days, we have to drive non-stop to have 2 days in Florida. We're Young, we'll survive. Plus, throw the back seats down, in with a sleeping bag and one can sleep while the other drives.
    As an update, I also cleaned the MAF sensor and the throttle body. I don't think either one needed it, the bulb was amber color but easily seen through and the cleaner didn't change its color any so I assume it was clean. The throttle body had the slightest dirt on one side, but there wasn't even any oil puddles under it so it was really really clean down there.
  5. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I was young and foolish myself not that long ago, but you asked for advice, so...travelling in the car without a seatbelt is *really* not a good idea, and may get you a big fine.
    A third driver could help defray the costs, and make a big difference to the shifts. Stock up on energy drinks, take a huge thermos for coffee, and a big pile of caffeine pills. You'll need them to stay awake for the 48 hours you're in Florida, not just the return trip. ;)
    Any chance you could meet your relatives half way? Maybe invite them to your house? Take the train?
  6. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    and tunes... you need good driving tunes. Some may also go for audio books but I think those are more for solo driving... so..
    TUNES.
  7. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Sleeping in the back..you should know that you will not get the proper sleep that you will need. While your driving...your going to get tired. Be aware of this..don't allow yourself to fall asleep.
    Be careful........give us a full report on your trip....!!!;);)
  8. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Mythbusters demonstrated that it's more dangerous driving tired than driving drunk...my, how much we digress.
  9. fotomoto
    fotomoto Senior Member
    5,639
    3,814
    So. Texas
    I'm assuming you'll be taking I-10 through Texas which is nearly 1,000 miles alone! If so from just east of El Paso to nearly San Antonio, it has an 80mph speed limit baby. Tell us what MPG you get through there. Also along that stretch, cell phone service can be spotty or weak so forget about data intensive apps like google maps and such; they'll time out.
    In the motorcycle world, it's suggested to do major service/maintenance about a month out from leaving. That way if a problem occurs during the service or something else is discovered you'll have time to rectify (part needed is NEVER in stock, etc).
  10. Patrick Wong
    18,210
    6,511
    - Check the windshield wipers and replace if needed.
    - If you are traveling to a cold area, buy windshield washer fluid rated to 0 degrees F, and use that to fill your fluid reservoir. Bring along some extra fluid if you think you'll need it.
    Enjoy your vacation, it's great to log 50 mpg on those long trips!
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Sounds like you could go 100,000 miles no problem.
    I would change the windshield wipers and apply Rainex to the front and back windshield. Crazy weather everywhere right now.
    I have my tires at same pressure too but I would lower the tire pressure a little for this trip.
    Non stop driving tends to heat the tires up real good and excessive pressure is a needless worry. Drive for 6 hours and feel the tires right after you pull off. See how hot there getting. I'm just scared of sidewall blow outs at 80 miles an hour. Been there.
    Rolling down I-75 years ago I was asleep in the front pass seat wife was driving I wake up to her frantic high pitched screaming and the car shaking violently and swerving side to side. All she could do to hold the wheel.
    Front tire sidewall blow out. After we got out I felt the other tires and they were all hot as hell. Florida highways are hot as hell midday and really hard on tires. Keep an eye on them.
    Good Luck.
  12. richbrvd1987
    26
    West Hollywood
    fotomoto,
    I'll be taking whatever route the nav system spits out to me. I'll happily let You know what numbers I get through Texas.
    Patrick,
    I didn't even think about the wiper blades. Coming from Palm Springs and living in LA, I haven't used them in ages. I will definately put on a new set. I don't know about the outside temp of what we're driving through, but it definately won't be freezing in FL. Unfortunately, my resv. is already full of fluid but I'd guess that it's 32+ (green Mr Clean stuff)
    Edthefox,
    I'll let the pressure in the tires down to mid 30's. Something else I would have never thought of but am definately happy You pointed that out. The tires are only a few hundred miles old, and have an expected 60,000 mile tread life so I don't think the Florida heat should damage them to much. I do know how hard hot roads are on tires though. The OE tires that were on there were bad after 27,000 miles driving in the Desert. Those hot roads just eat the tread off the tires!
  13. Patrick Wong
    18,210
    6,511
    I recommend that the OP keep the tire pressure as-is, at 42/40 psi. Use of a higher inflation pressure means the tire sidewalls will flex less, which will result in less heating of the tires as the car is being driven.
  14. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    One other thing, you mentioned getting new tires. Did you get alignment checked and corrected at the same time? An alignment problem undetected before the trip could mess up those brand new tires by the time you reach your destination. I know because I did a cross country trip on brand new tires in my Odyssey. Ruined them.
    Also be very sure that the balance feels good, check it on smooth pavement up to the highest speeds you might hit on the trip. Often new tires aren't balanced perfectly on the first try (100% fail in my case, out of 3 separate new sets on 3 cars) and it's hard to detect below 60-70mph.
    Enjoy the drive!
    - D
  15. richbrvd1987
    26
    West Hollywood
    Don,
    They charged me for the alignment, but one never knows. I'm going to have them re balanced when I go in Monday for all the other work they need to do and have the dealership verify the alignment. I always buy my tires from the same place, with 2 cars they know me well enough and I'm sure they would have done the work.
  16. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Yeah just take like 5 lbs out. There's not many tires out there that 40 psi isn't past max pressure. At say 38 lbs you should not have any sidewall flex as I bet thats the max pressure recommended on the side of the tire. I'm just saying don't exceed tire manufacturer recommended tire pressure on a bonzai road trip driving 80 all day. Its a needless danger as the mpg savings will be like $10 for the entire trip.
    And btw, temp is expected to go to 35 F tonight. We are having a lovely cold spell. The days are just perfect sunny 65 and warm with very cold (to us) nights. Perfect time to come on down!!
  17. GBC_Texas_Prius
    218
    gbc texas
    For the naysayers on the long drive time, I have done that type of vacation driving and got to thinking if I was being dangerous or if I was an OTR type truck driver, would it be illegal. Turns out that the studies show that if you do it as a one shot thing, you aren't being excessively dangerous. It would also be legal for a long haul driver. Where you get in trouble is when you do it weeks on time and that's also where the law kicks in for truck drivers.
  18. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Maximum pressure rating on the tire sidewalls is for when the tires are at ambient temperature. Don't sweat temperature rise while running at higher pressures.
    A long trip in hot weather is the last place you should reduce tire pressure because running hot damages tires and the lower the pressure the hotter the tire runs.
  19. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Being a retired truck driver...it would be excessive for anyone who does not drive at long stretches at a time. They just are not use to that long behind the wheel. Truck drivers must log their hours behind the wheel, they can only spend 10 hours behind the wheel, then must take 8 hours off. Granted..if anyone whats to spend 23 hours behind the wheel driving their car or RV, they can.....it's their life and the life of others that they are playing with.
  20. richbrvd1987
    26
    West Hollywood
    Honestly, I think the max pressure is 42 or 44. I will recheck them tonight. I figured that 36/38 would be a solid and safe setting. In our other car, a coupe, the manufacturer has the pressures set at 39/41. Honestly, this is the only car I've ever owned that had such a low OEM tire pressure. Is it a toyota thing?
