Replace regular headlight to LED
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Hy-Bird, Dec 6, 2010.
  1. Hy-Bird
    Hy-Bird Junior Member
    69
    Have anyone change the regular headlamps to LED? I'm thinking of doing mine but before I do, I want to make sure is it easy as putting on xenon lights? On my previous car I had xenon lights and it was easy to install.
    Also, if you have already install LED headlights (except original pkg 5) can you post some pictures of your lights and let me know where you got them?
    Thanks :D
  2. 02semiata
    02semiata New Member
    New York
    You are not changing the bulb I would think you would need to go to toyota and ask for LED headlights and pay a ton
  3. BocaChaser
    BocaChaser New Member
    35
    Boca
    Do you mean switching out the headlight bulb for a led ones? like this: (not too sure what you mean)
    As far as the Prius V lights go....you cannot simply buy and install them. They are self leveling and require a comp. to control them I am pretty sure. And it would be extremely expensive
  4. Hy-Bird
    69
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Seen this picture a while back. Didn't this guy spend ages making these himself?
  6. pEEf
    pEEf Engineer - EV nut
    720
    580
    Berkeley, CA
    Note these are not LED headlights, they are LED accents. Big difference.
    I don't think aftermarket systems exist yet to replace headlights, the thermal, electrical, and optical challenges are substantial! I recommend a good HID kit, much brighter than any LED system you are likely to end up with.
    Your only option if you simply must have them is to buy the OEM LED headlight units from Toyota along with their power supplies and wiring harnesses. It's going to cost a LOT though!
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    FYI,
    In Japan, Modellista offers "LED head lamp kit"
    Modellista LED head lamp kit"
    It costs 236,250yen (US$2813) plus 2.5 hours labor.
    Please note that it is for RHD Prius.
    Ken@Japan
