change front brake pads at 30000km?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by socratesthecabdriver, Dec 10, 2010.
  1. socratesthecabdriver
    283
    31
    greece
    i just went in for a 30000km(18900miles) service.and the dealer is claiming i have to change my front brake pads! i didn't let him do it.because the brake light hasn't even come on yet !!!!!!!!! from what i have been reading around here is that the brakes should last a lot longer..... what gives? i came across one more prius gen3 owner and asked him and he said he changed his pads around 25000km? is something different with the gen 3 front brakes??????????
    shouldn't the brake light come on when its time for them?
  2. Mendel Leisk
    40,251
    The brake light will come on for various reasons. One I know is if you have the parking brake on. And likely if brake fluid level is too low. But I doubt very much it will come on for brake pad wear, which is likely the reason he wants to change pads.
    30000km is abnormally early for worn out brake pads, in particular with a hybrid with regen braking. If you want to know the state of your front brakes: remove a front wheel and have a look. New brake pads are typically between 10~12mm thick, and typical wear limit is around 2mm. I wouldn't go lower than 3mm personally.
    When checking thickness, be sure to exclude the backing plate, only measure the friction material thickness.
  3. 13Plug
    13Plug Active Member
    581
    104
    2013 Prius Plug-in
    The brake light does not come on when your brakes need to be changed. Traditionally you hear a squealing sound from the brake pads as there is a noisemaker built in.
    I find it hard to believe your brake pads need replacement. They should last way longer. Definitely get a second opinion or check it yourself.
  4. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I have 47,000 miles on my brake pads and they look brand new. I drive alot of highway miles.
    On my last car I got 190,000 miles on the front pads and at 305,000 the rear were never replaced. I sold the car.
    Two things that make the wear fast is constant city driving for overal bad driving.
  5. Tideland Prius
    16,406
    I think he's missing an extra zero. 300,000km is more like it. 30,000 is waaay too short. Even our non-hybrid Camry had it changed at 60,000km with mostly city driving. We have 140,000km on our 2005 on original pads (more than 50% left).
    The brake light won't come on. The warning is a squeal from the brakes.
  6. Mendel Leisk
    40,251
    That squeal is a soft metal tang, typically copper, that protrudes just a mm or so beyond the pad's backing plate. In other words, when your pad gets down to around 1mm it starts contacting the rotor. IMHO, that's too close though.
    You can resolve your question yourself by just pulling a wheel and having a look. Actually, you might even be able to tell through the wheel spokes, with a good light.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yeah, the sound of that squeal means you screwed up but if you are lucky you didn't ruin your rotors yet.:D
    FWIW, the Official Prius repair manual says new pads are 10mm/9.5mm thick front/rear. Both are allowed to go down to 1mm per the manual. What they don't say is that if either pad on a wheel is down to 1mm in any spot that both of them should be replaced.
    In reality you should replace at about 2mm because there isn't enough life left to make it worthwhile postponing.
    I agree that 30k km isn't a reasonable mileage unless he runs full throttle - full brake every block. :eek:
  8. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Replacing your brake pads will be about has
    frequent as replacing your fan belt.
    al
  9. Mendel Leisk
    40,251
    xs650: do you have the Repair Manual, one or more volumes of the set of four? If so could you shed some light: are they all worth getting?
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I have a CD with the 4 volumes on it, (6000+ pages!) that I bought from some long gone guy on eBay for $28. The table of contents feature works but the cross links in the repair sections don't. It actually pretty usable, which unfortunately doesn't help anyone else because the guy is no longer on fleabay.
    I just looked and there is another seller with 2010 Prius manuals:cool:
    If you want to make an inexpensive gamble, there is presently (10 Dec 2010) a guy on ebay selling a 2010 Prius repair manual CD for $34.95. By his description, it sounds better than mine because he claims it is indexed.
    Go to ebay and search for 2010 prius service manual
  11. Mendel Leisk
    40,251
    I've actually had one on order for 2~3 weeks through that establishment. Money has changed hands, but no disc yet... :rolleyes:
    Helm Inc has the paper version at $70 per volume. They are legitimate, but still that's a lot of money. Just wondering if any of the volumes are not that much of interest, say detailed bodywork specs, or nothing but wiring diagrams?
  12. socratesthecabdriver
    283
    31
    greece
    MY REAR break pads look like they haven't even engaged yet!!!!! i average about 5.3 liters per 100km i try to use my regen brakes as much as i can when stoping !!!! mabe its athens trafic!!???
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I just got the $34.95 one from firstratedata on eBay. It arrived 3 days after I ordered it. It seems to be alittle more complete that the earlier one I bought from another sourfce and laods much faster from the CD. The service manual shows 7595 pages and there are also electric and owners manuals on the CD. I couldn't find the advertised full index but the table of contents is quite complete so no big loss.
  14. Nandros
    Nandros Junior Member
    44
    Lechaio Corinth, Greece
    Hi Socrates,
    When the car was delivered to me, the dealer told me that the front brakes pads must be replaced on the 2nd service (30.000 klm or 2 years). I "knew" from this forum that such short time is quite early and told him so. The reply - lame to my opinion - was that the brake pads are "ecological" and softer than the usual ones! I believe is just an opportunity for the dealer to charge for the spares and the service. Anyway on the 2nd service I will demand to see the pads before allow them to be replaced.
  15. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    At 30K miles my brake pads look like new. Before the Prius, I owned a 03 Civic Hybrid and at 45k miles the rear brake shoes had not even completely seated in on their full surface. Regenerative braking does the biggest part of the stopping in both cars.
  16. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Your front pads are probably just fine also. Why don't you get a second opinion? Brake pads are pretty much the same from car to car and you don't need a Toyota dealer to measure, or replace, brake pads. Any competent mechanic can measure the pad thickness and show you how to do it as well.
  17. socratesthecabdriver
    283
    31
    greece
    dude i did i wore them down !!!! i am getting ready to change the second set at 80-90
  18. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That's quite an accomplishment. My 2004 Prius at 213,000 miles still has more life in the original brake pads/shoes.
    JeffD
  19. tumbleweed
    4,067
    690
    Eastern Oregon
    Wow! I thought this was your first set. Maybe you could find some pads that will last longer. I used Akebono ceramic pads on one car I had (not a Prius) and they do last longer but I think they wear the rotors faster than normal pads.
    I don't know if you can order from TireRack or not but they have ceramics for the Gen3 Prius: http://www.tirerack.com/brakes/resu...a&autoModel=Prius&autoYear=2010&autoModClar=V
  20. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I think 30k km is low but I replaced my front pads twice now and am at 63k miles (101k km).
    It appears the European front discs and pads are made of softer material than the US version as apparantly Europeans like their brakes to have more 'bite' at the expense of a shorter service life.
    They still last longer than other non hybrid automatic taxi brakes which last about 18k-20k miles.
    If you wanted you could always install US brake dics and pads and get an extended life.
