Left side door won't open from the inside
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jkash, Oct 25, 2005.
  1. jkash
    jkash Member
    889
    West Hills, CA
    I have a problem with my left side rear door. It can no longer be opened from the inside, even when unlocked. Anyone else had this problem? And if you did, what was the fix?
    Thanks.
  2. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Check Your Child Lock
    It should be in the "up" position.
  3. jkash
    jkash Member
    889
    West Hills, CA
    I'm sorry, I don't know what the lid lock is. Can you explain?
    Thanks.
    Was this post edited to now indicate child lock? Oh well, maybe I misread it the first time. The child lock button is in the up position. All the other doors open, just not the left rear. I think the cable may be broken. It doesn't feel like anything is attached to it when you pull on it.
  4. taaustin
    taaustin New Member
    112
    1 gallon north of Austin, TX
    it's dark or I'd go out and look but I'm certain it's there...
    Open that door (from the outside) look at the edge/back of the door, not the outside, not the inside - the EDGE, where it would fit against the body when the door is closed. Child lock switch should be there, flip it to the other position and all should be back the way it was. Pretty much any four door car built in the last ten years has these. Unless you have kids you don't have any particular reason to know, but they are there.
    easy fix, nothing broken.
    DashingDave and Sheryl222 like this.
  5. jkash
    jkash Member
    889
    West Hills, CA
    Thank you very much Delta T. That indeed was the problem. I have no idea how it happened, but I am very glad it is fixed.
    Thanks again.
    I love this board. Ask a question, get an answer, and it works!
  6. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    My dad used to play practical jokes to friends and family with that, especially when the locks were a new feature.
    They couldn't get out, but my dad would look at them funny and open the door. Sometimes they would try again, and still get stuck.
  7. DashingDave
    DashingDave Junior Member
    39
    Monterey
    Eggs-cellent - clear answer solved my problem easily.
    Thank you !
