Whirring noise after shut-down
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nc_driver, Dec 16, 2010.
  1. nc_driver
    nc_driver Junior Member
    37
    Raleigh NC
    I remember that my 2005 Prius had a short whirring noise when I shut it off, as some coolant fluid was moved around.
    But my 2010 Prius has been pretty quiet at shut-down, until recently (has it always been there, or now that it's cold weather?) I noticed there's a very faint whirring noise coming from the engine compartment at shut-down. It lasts for quite a while -- almost a minute, then stops.
    Anyone else heard something like this?
  2. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    We both have the same vehicle......I have not heard this noise yet. I have just over 5K on mine
  3. Mendel Leisk
    40,484
    Sorry for butting in: does anyone know the cause of the whirring noise heard when you unlock and open the drivers door? It goes on for maybe 5 seconds. Some sort of fuel pressurizing? I think the same noise happens periodically while driving.
    The Owners Manual lists some noises and explanations, but as far as I can tell makes no mention of this.
  4. qbee42
    3,076
    It's the brake accumulator pump building pressure for the power brakes. The Prius can't use vacuum for brake assist, so it has an electrically powered pump.
  5. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    I hear some clicks, no minute long whirring tho.
  6. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    I've heard some such extended whirring post shutdown coming from what I thought was the underside of the vehicle, not from the engine compartment, though I may have misjudged the source. I have a little over 6K and did not notice this until either Oct. or Nov.
  7. Mendel Leisk
    40,484
    Oh hey (just waking up), to the OP, from page 22 of Owners Manual, maybe this:
    Approximately five hours after the hybrid system is turned off, you may hear
    sound coming from under the vehicle for several minutes. This is the sound
    of a fuel evaporation leakage check and, it does not indicate a malfunction.
    I first heard this when I happened to jack up the rear end, just to have a look-see, had me a little concerned, it was several hours after shutdown. ;)
  8. vinnie97
    1,430
    277
    Somewhere out there
    Definitely not after 5 hours in my case, more like <5 minutes. :p
