Why 2011 Prius.. when you can get PHV?
Discussion in 'Gen 3 Prius Main Forum' started by coach81, Dec 20, 2010.
  1. coach81
    coach81 Active Member
    758
    116
    Louisiana
    If you can stand to wait, why would you buy the 2011 Prius, when in June 2012 you can get the "game changer" the Prius PHV?
  2. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Because you don't want to/can't spend the extra $5k? You don't have off road parking? You drive over 100 miles a day? You want to make your own PHEV? Your company car is due for renewal right now? Your profession requires you to carry a spare tyre? Because any of the political motivations you have for buying a Prius won't wait until 2012?
    Plenty of reasons! Just hurry up and buy one already.
  3. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    What would you suggest someone purchase if they needed a car right now (while of course waiting for June 2012)???
  4. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Perfect rationale! I firmly believe that the new PHV technology will be obsolete within 5 years of introduction which is all the more reason to wait. Go ahead and get your Prius Gen III now!
    Happy Motoring,
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I'm waiting to see what else Toyota comes out with between now and then. We already know there'll be the MPV and there are rumors of a smaller Yaris-sized hybrid. I don't need a larger vehicle; if I decide that I don't like the smaller hybrid then I'll probably get the Plug-in.
  6. john1701a
    john1701a Prius Guru
    12,803
    5,287
    57
    What does "obsolete" actually mean?
    Traditional vehicles have been under-par on emissions & efficiency for a decade now, yet they are abundantly available still.
    And 5 years represents 100,000 miles of driving for some of us, a good reason to get the first model PHV.
  7. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    $$$$'s is the main reason and I don't think it's that much of a game changer unless they can extend the EV only range...
    I'd wait if I didn't need a car badly, but I couldn't even wait a couple months for a 2011, much less a 2012 car. (My old car was dying.)
  8. Tideland Prius
    16,499
    Well if you can wait, then by all means. The next few years will be very interesting. There will be a lotta new vehicles available with a few of them (like the Leaf and Volt) available sooner than the Prius PHV.
    However Flanina has posted a couple of good points. If you don't have access to a power outlet (e.g. you're in an apt) or can't make use of the PHV capability, why get one? It's possible that the packages will be different (The prototypes don't have the solar roof b/c they add weight which would decrease the EV range so if you wanted a solar roof, you have to get the standard Prius)
  9. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    The current version of the Prius gets great gas mileage (~50 mpg if you drive it conservatively). A plug-in version may end up costing more per mile to drive on plug-in vs. gasoline. I know that the government bases cost per mile on 11 cents per KWH. However looking at my current electric bill (Pacific Gas & Electric) I see that for most of the electricity that I'm using, the cost is 29 - 40 cents per KWH. Like other people in this region, If I had a plug-in Prius and powered it from P, G & E, the electricity that I'd use for charging the car would cost me 40 cents per KWH (Kilowatt Hour). Therefore unless the price of gas goes up by a factor of 2 to 3, I'd still be better off powering the Prius by gasoline.
    Keith
  10. ETC(SS)
    7,060
    My electric rates are closer to the 11-cent average. I have access to exterior plugs at home and at work. My drive to work is under 10-miles.
    PHEV is a no-brainer for me...right?
    Wrong!
    They'll probably price the PHEV out of my depth band, so when I replace my Sierra, it will probably be with a base model Prius---in a few years. That's where the math is for me...for now.
    AT&T will probably make me drive my current 2010-II model until it has lunar mileage, so I'm probably out of luck there too.
    The GOOD news is that the price of the plain-old (classic?) hybrid will probably fall off somewhat when the 2012's come on line... :D
  11. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Did it ever occur to you that not everyone WANTS a PHEV?
  12. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    'Cause the one is tested, real, and ready, and the other doesn't exist? Or if I wait long enough, can I maybe get a flying car?? I would so ditch the Prius for a flying car.
    :cheer2: <--Me, inspecting my new flying car
  13. john1701a
    12,803
    5,287
    57
    Since 600 PHV are currently being tested by consumers, the matter of existence is somewhat moot.
    Back to just when & price.
  14. Crazytwoknobs
    Crazytwoknobs Junior Member
    Chicago
    Yeah, the magic numbers when discussing $ and MPG are 5, 10, 15, 20, 33, 40, 50, 80 and 100. It's hard to justify spending money on efficiency unless it's a small amount of money, and you're moving from well below one magic number to well above another.
    Think I should post my rant about the magic numbers?
  15. Mendel Leisk
    40,961
    Some reasons I wouldn't purchase the plug-in version (most already dealt with, but...):
    1. More expensive. Up front, and maybe not recouped in gas savings, depending on your mileage, etc.
    2. Heavier vehicle. It's great for the first 12 miles or so, but then you're hauling a fair bit of extra batteries.
    3. New. Just rather wait: price will come down, the technology will become more mainstream, bugs will be worked out, battery power/size ratio will improve.
    4. No spare tire...
    5. Not available yet.
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    No outlets at my apartment or my work....
  17. Ted in Olympia
    Ted in Olympia New Member
    84
    Olympia WA
    The Gen III is a great car. If you find a 2010 you can get an even better deal and they are the same as the 2011. You can drive a new car and let others shake out the bugs in the new technology.
    But it took me ten years to convince me to buy a Prius. Will have to wear out this 2010 before I think about another.
    TED
  18. coach81
    758
    116
    Louisiana
    Thanks for all the comments... great points. I suspect the '11 Prius will be a "down year" for the Prius as I believe many will wait for the PHV.. just my thinking...
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    To save money getting the regular Prius, currently drive ~ 6k miles/year, reg. Prius is fits that more, prefer the flush load floor and under floor tray of reg. Prius.
    will most likely keep the 09 and buy neither. :D
  20. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    It wouldn't be a down year because many will wait for plug-in - it would be down year because the economy is still in the toilet. Many state governments are in huge financial trouble and early next year, aid from the fed is set to expire. Ohio is said to be hugely in debt. CA has 20+ billion deficit. :(
    Regular Prius is a great balalnce of roominess, price and economy.
