Prius Rear Windshield Wiper Doesn't Quite Cover Enough of the Back Window
Discussion in 'Gen 3 Prius Technical Discussion' started by Rachmaninov, Dec 23, 2010.
  1. Rachmaninov
    Rachmaninov Junior Member
    Mesa, AZ
    I used my rear windshield wiper for the first time today. Has anyone else noticed that the back windshield wiper doesn't clean off the back window close enough to the horizontal bar going across the Prius V hatch? I have about 2-3 inches of dew remaining above the back hatch bar, which 'happens' to be the exact height of my eyes (I'm 6').
    I have my doubts as to this being something configurable, but if it is, please let me know. Fortunately in Arizona there's so little use for windshield wipers (just on a cold morning) that this won't affect me too much. :)
    Thanks,
    Rachmaninov
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    yea it seems like it should be alot bigger.
  3. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
  4. Mendel Leisk
    40,974
    Seems like it could be a lot better: maybe if the hinge was at the top center of glass area? Even better would be if it changed reach as it went through it's sweep (as one of the front wipers does).
    And then of course the glass area below the air foil gets very grubby.
  5. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    The rear wiper has popped up on other threads recently. I wish I could have deleted the rear wiper/washer. For me it's not functional, nor does it provide useable (additional) visibility. I sure hope Toyota fixes this issue for future models.
    Happy Motoring,
  6. Mendel Leisk
    40,974
    Next time ours is running I'm going to check out it's sweep,. Just thinking: if it stops a fair distance short of the air foil, maybe the wiper could be taken off the mounting bolt and then placed back on it rotated one (or two) notches clockwise, for a more complete sweep.
  7. Rachmaninov
    Mesa, AZ
    Just one thing I wanted to clarify... my issue with the sweep isn't the length (amount of rotation) or width of the sweep, it's that the sweep doesn't go down far enough. Next time it rains I'll post a picture with my rear view showing what I am talking about.
    Thanks for the updates everyone.
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I haven't tried it but it looks like you could accomplish what you want by substituting a straight wiper arm for the dog-leg factory arm, then re-clock it on the spline when you install it.
    You could use an adjustable length wiper arm and the longest blade you can fit in. I know a longer blade wasn't your primary objective, but why not do that while you are at it?
    Here is an example of an adjustable length arm. I didn't check to see if it would fit a Prius, but it gives you some idea what to look for.
    http://www.awdirect.com/replacement...length-5-8-drum/truck-equipment-wiper-blades/
  9. Tideland Prius
    16,501
    you only have to deal with dew.
    Try sweeping away snow and having all of the area you just sweeped pile up at the bottom. You couldn't see out the rear window before you wiped and now you can see out but there's a pile of snow an inch or two high that's blocking the view. Guess it only matters if I'm backing up and I can't see the wall or the car I'm reversing into.
  10. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Hi Rachmaninov (nice name, BTW - Rach 3 rocks!) - I am pretty sure there is nothing wrong with your rear windshield wiper.
    The design of it is simply "useless" and for me the design is more for the right-hand drive than the left-hand drive. It clears up a very small patch of the windshield, which is already so steep inclined, that the overall view at the back is far from being perfect.
    Add to that the the lower portion of the back does not get cleaned, gets sprayed with water/dirt when it rains from the wind generated by the car, with no chance of cleaning it - you end up with very bad rear visibility. Including the black bar in the middle.
    They really need to improve the design of this part of the car in future models/revisions.
    But there are other cars out there that have also a bad rear view visibility - to name a few - the Citroen C4, the BMW X6, the BMW 3 series (it does not even have a wiper), etc....
    If I could have a camera showing me in the rearview mirror the back at all times, they could even remove the glass :) - as it is, it's not good... :(
  11. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    I adjusted my rear wiper by removing the entire assembly from the motor shaft (one nut and a light tap on the stud) and then replaced it one spline off from its original placement. Total degree of sweep isn't increased but the affected area cleared can be adjusted for a somewhat, more effective sweep.
  12. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I just put rain-x on my back window Saturday. It rained yesterday (that's always how it works after washing the car), and I had very little water on that back window. The rain-x (you can substitute any similar product) seems to help keep the window clearer due to what it does combined with the wind flow over the window.
  13. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    No advice, but tried my rear wiper for the first time today and was SHOCKED how sucky coverage (or lack there-of) was. You'd think this design oversight wouldn't be possible in such a fab high-techy vehicle.
  14. pakitt
    2,173
    1,313
    Colorado
    J5A - you would be surprised with how many "low-techy" solutions there are in the Prius. But if you drive an X6 from BMW, you would see even less - I have seen one yesterday and considering the buy price, the Prius is not much worse at all - it is actually better.
  15. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Not ready to modify anything *just* yet, but will keep it in mind for later - good to know - thanks!!
  16. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    it is kind of a shock at how poor the coverage is, but guess getting used to the side mirrors is important to get used to for other reasons. the rear view is one of those areas of the Prius that are very "weak".
  17. Tideland Prius
    16,501
    lol... using an X6 is cheating :p You can't use a dune buggy that has poorer rearward visibility as an example.
  18. CynAmun
    CynAmun New Member
    I have a terrible time with the lower (vertical) window. It gets so dirty. Would RainX help?
  19. pakitt
    2,173
    1,313
    Colorado
    I would like to know as well. They sell it in Germany as well and it is quite expensive - a small bottle about 7-9€...!
    And also I would like to know if it can damage/wear the glass, its properties, its color and if it can be easily removed. Considering that the lower part of the back is made of darkened glass, with metal lines to remove moisture...
