Glass treatment?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ScottY, Oct 28, 2005.
  1. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    I got my Prius since May. Now when it rains at night, it gets a bit hard to see. Mayb due to the fact that I park my car out door.
    So I was thinking getting glass treatment. I saw Rain-X and Aquapel. From this website, and also reviews on Amazon, seems like Rain-X doesn't last too long. I am planning to get Aquapel since they claim it'll last up to 6 months. Anybody else like to share some experience here?
    Thanks in advance.
  2. tag
    tag Senior Member
    2,526
    Chicago
    I can't speak for anyone else but Rain-X has lasted a LOT longer than the time period specified (30 days) on the Aquapel web site. Of course, I would sort of expect that coming from the manufacturer of a competing product.
    The FAQ on the (PPG) Aquapel web site states that ammonia-based cleaners will not affect the durability of the product. On the other hand, I read, on a windshield repair kit distributor's web site, that the best method to remove Aquapel prior to performing a repair was to use their ammonia-based glass cleaner! That same site stated that their ammonia-based cleaner was ineffective for removing Rain-X.
    FWIW...
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    i use rain-x every 6 months and have since i owned my first car.
    it's very effective, even in winter snow and ice, and also makes bug splatter easy to clean up.
    can't say i've even heard of aquapel...
  4. MBranstein
    MBranstein New Member
    288
    Prospect, KY
    I use a product called Invisible Glass http://autozone.com/servlet/UiBroker?UseCa...7ESTO%7C%7Etrue
    Using this on the outside and inside of my windows makes them spotless. It is truly fantastic! Since I have begun using this product, I haven't needed to use Rain-X. My windows come clean with a single swipe of the wipers and the water beads up. The other bonus is that they are always crystal clean!
    It seems that the Invisible Glass leave your windows with a nice coating so that dirt doesn't stick easily. I wonder if a combination of the two products would yield a superior windsheild finish?
  5. galaxee
    9,810
    471
    MD
    indeed it does :D i use the combination myself!
  6. MBranstein
    288
    Prospect, KY
    Fantastic! In what order do you apply?
  7. galaxee
    9,810
    471
    MD
    clean with invisible glass 2-3 times, then apply rain-x twice for a good coat.
    then clean again with invisible glass to remove all remnants of rain-x haze. works like a charm, takes maybe an hour every 6 months.
  8. MBranstein
    288
    Prospect, KY
    Thanks!
    I'm just amazed at the wealth of knowledge I've accumulated over the past month from being on PriusChat.
    And once again, the members don't disappoint.
  9. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    WOW, thanks for the numerous replies. Very helpful! :)
  10. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Looks like local Pepboys is offering Aquapel Glass treatment for $9.99 thru Oct. 31. I might just give it a try and see what the result is.
  11. MBranstein
    288
    Prospect, KY
    No problem. The only down-side to the Invisible Glass product I have found if that it is an aerosol product. I'd be much happier if they made the product in a spray bottle.
  12. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I use the Rain-X windshield washer fluids (bug and de-icer) and get a decent amount of sheeting when the rain is heavy. I'm not sure I'd get a lot of extra benefit from a separate treatment...
  13. tag
    tag Senior Member
    2,526
    Chicago
    Sounds like a service. It says "$9.99 most vehicles*" and then this:
    *Actual price may vary depending on vehicle make and model. A Shop Supply Charge of 5% up to $15 may be applied to certain services. Each individual Work Order will identify any applicable Shop Supply Charge.
    You can buy the product from Tire Rack and apply it yourself, too:
    http://www.tirerack.com/accessories/aquape...essories&make=&
  14. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Tag, I saw it on tire rack too. But after shipping and you'll have to do the work, I think $9.99 is worth it. But then it mention the whatever supply charge up to $15. I'll call tomorrow and find out.
  15. bigdaddy
    bigdaddy Member
    991
    Duluth Georgia
    My local pepboys sells the spray bottle version.
  16. DHonzik
    DHonzik Junior Member
    70
    Oak Creek, Wisconsin
    You can get the spray bottle version at
    Auto Geek,Net
    or its available on ebay 3 for $14.95 plus $6.95 thru AAA Motoring Car Care Products
    AAA-Motoring-Car-Care-Products
  17. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Ok, just to follow up.
    I applied rain-x and invisible glass like galaxee said.
    Two weeks ago, the first time it rained after I applied rain-x, it works so good I was about to show everybody I know. At speed above 40 mph, the rain just runs off without using wipers at all.
    Last night it rained again. Seems like rain-x already wear off. Water didn't run off like before even at speed 50+mph. But water was easier to wipe off than before. Kinda disappointed that rain-x wears off that fast. :angry:
  18. ThunderJon
    ThunderJon New Member
    69
    San Ho, CA
    Thats why u get the rain-x washer fluid, constant reapply
  19. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Any idea where to get them? I looked in my local Autozone and Pepboys, but couldn't find it.
  20. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    <div class='quotetop'>QUOTE(ScottY @ Nov 17 2005, 11:53 AM) [snapback]157034[/snapback]</div>
    This may only be applicable to Canadian Toyota dealerships but today I received the Toyota Gazette, an 8 page glossy flyer which quotes the Aquapel windshield treatment for $29.95 CAD + tax and states it lasts for 6 months. I know this product is discussed briefly in a few above posts in this thread but I'm not convinced yet and wonder if anyone has had the treatment and experienced good or bad results after this past winter driving....does it really last 6 months?
    As an aside we were given a neat little crank up flashlight with the Toyota logo after our service job was completed ....... no big deal just a nice gesture and it's good quality .... 1 min cranking and it lasts 20 min with an efficient light .... don't have to worry if I've kept fresh batteries in my old one.
