Strange locking issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lamboalex, Jan 14, 2011.
  1. Lamboalex
    Lamboalex Hyper-Miler in training
    37
    Mooresville,NC
    This started happening a couple days ago, after turning off the car and attempting to lock the car with the handle button, it will lock (no beep) then unlock- the same way it would if there were keys left inside. The only other set of keys are at my house, so I know that's not the issue.
    Doesn't do it all the time, but enough to be annoying. Same thing happens if I use the remote- lock, no beep, unlocks. The only way I can get it to beep and stay locked is to open the pass side door and lock it with the pass side door button.
    Anyone see anything like this?
  2. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    From what I seen in other post......anything weird happens electrically......check your 12 volt battery.....it could be going bad on you.
  3. M D
    M D No more gas guzzler :D
    66
    DE
    Open all doors, then close them all, then try again.
  4. Patrick Wong
    18,200
    6,499
    Maybe the front passenger door switch is getting flaky and is telling the body ECU that door is open when it is actually closed? Then, when you open and close that door, that activity cleans off the switch temporarily so that the car will lock.
  5. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Does your wife slam the door when leaving the car? H
  6. Lamboalex
    37
    Mooresville,NC
    She's only driven the car 2 or 3 times, and I never slam my doors
  7. Hal W
    Hal W New Member
    872
    53
    I was thinking maybe the passenger door may be is taking some abuse, as you claimed it would be OK after opening and re-closing the door. I only say this as ladies tend to slam door. That is the impression I have gained over the years. It may not cause an issue any way. H
  8. Lamboalex
    37
    Mooresville,NC
    I've noticed something, the driver side door doesn't always lock even if you press the lock button while inside the car, you can see it trying to move to the lock position but stays unlocked while the other doors lock. Maybe the car senses that 1 door isn't locking so it unlocks all the doors when trying to lock from the outside....
  9. Hal W
    Hal W New Member
    872
    53
    Try adjusting that door. Sounds like it may be on the tight side? H
  10. Hal W
    Hal W New Member
    872
    53
    Or maybe lube the latch. May not me latching all the way? H
  11. rpeeples
    rpeeples Experienced Toyota Owner
    109
    America's own third-world country
    I had something very similar happening on my '07 Camry Hybrid. Turns out it was faulty actuator motors on the door locks. I had to have all four replaced, one of which was not under warranty. It cost me almost $200. I would get this checked out and documented asap if the car is under warranty...
  12. Lamboalex
    37
    Mooresville,NC
    I'm gonna give that a try. If not then I'm guessing the little motor that locks the door?
  13. uglymuddah
    uglymuddah Junior Member
    24
    The Netherlands
    How about trying a new battery on your keyfob? Before you start greasing or taking apart your car...? :D
  14. Lamboalex
    37
    Mooresville,NC
    Took the door apart and (finally) got the the lock assembly. What a pain it was to remove...
    Inspected it and noticed that unlocking worked fine, but attempting to lock you can see the lever try to move but unable to. Tried to remove the cover and lubricate but no luck.
    Local dealer wants 320.00 for one, online i found one for 240(lowest price I could find)
    I'm gonna check a local salvage yard and see if I get lucky, if not 240.00 it is...
  15. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    My guess is overcurrent on the lock actuator. You are on the right track. Contact Steve at Autobeyours.com if you can't find a used one in your local yard.
