Oil changes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lex, Jan 17, 2011.
  1. lex
    lex 2005 Prius, always garaged
    119
    Fresno
    A cursory search on the board didn't turn up answers on this subject, though I'm sure they're here somewhere.
    What's the consensus, if any, on the optimal type of oil and frequency of changes for Gen II, and how may this change with higher mileage?
    Appreciatively,
    Lex
  2. uart
    uart Senior Member
    4,220
    1,210
    Australia
    The best answer usually depends on your driving conditions. Like how many miles do you do per year? Also, do you mostly do short trips or do you have a resonable amount of trips long enough to fully warm up the oil?
    I do about 18000 miles per year and not too many very short trips, so I'm comfortable going 9000 miles (6 months) between changes. I've used both synthetic and synthetic blend oils and had no problems with either.
  3. lex
    119
    Fresno
    I'm about 12K per year, mixed freeway and city, mostly in Southern CA. Most trips are long enough to fully warm the oil.
    9000 miles before changing, even under your conditions, is that not rather long?
    Appreciatively
    Lex
  4. uart
    uart Senior Member
    4,220
    1,210
    Australia
    At 12k miles per year I think 6 months 6000 miles intervals would be a no brainer. I definitely wouldn't do more than two changes per year under those driving conditions.
    Yeah my 9000 mile interval is a little longer than usual. The interesting thing though is that the "official" Toyota recommended OCI varies from country to country even though the engines are the same in each case. In North America it's 5000 miles, in Australia it's 10000 km (6300 miles) and in much of Europe it's 15000 km (9320 miles).
    Also I find the Prius to be really easy on oil for my driving conditions. I think that in a very cold climate and with shorter trips the Prius is not so easy on oil because the engine not running all the time makes it take even longer to warm the oil than a regular car. In a warm climate with longer trips on the other hand this is actually working in your favor and it's easier on the oil than most other cars.
    I started out at the recommended 6300 mile interval, oil always looked in great condition when I changed it out. Went up to 7500 mile intervals and the oil still looked good, so now I'm going 9000. That's enough for me, I just wanted to make 6 month intervals because I like having nice fresh oil for summer and again for winter.
    BTW. I always use a good quality oil with the European ACEA specs (usually ACEA A3/B4) for doing the longer OCI. This is what they use in Europe where the recommended OCI is 15000km so I cant see any problem.
  5. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Hi:
    I change my oil once every year. I use A good synthetic 0-20 weight and only add 4 ltr's. Never over fill as this can hurt your FE. If you tend to drive for good FE then you don't work your car too hard, but if your like most Californian's, I would change 4 times a year! <grin> I would agree with uart, twice a year for you type of driving. Hal
  6. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    With respect to you folks in the USA you seem to have fallen into the trap of changing oil every 5000 miles because that is what your used to, while this does no harm to car it is with modern oils a waist when these lubes are more than able to run to 10,000 miles if your dealer is using crap oil tell him you want the same spec oil that Toyota ship in there cars new, if he has not got it take some with you, if enough people did this they would soon get the message. Its your pocket he is emptying he is not going change the oil he is using without being pushed he is making to much money selling you poor quality oil.
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Use name brand synthetic if you plan on OCI > 5,000 miles. There is no consensus given the great debates but, for example, Gen III spec is 10,000 miles on 0w20.
  8. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Actually, in the USA, you need to change the oil every 5000 to maintain the Toyota USA warranty! Once the car is out of warranty, then longer intervals seems reasonable. (I now do 10,000 miles between changes of Mobil 1.)
  9. uclabruins
    uclabruins Member
    265
    City of Angels, Baby!
    When you say out of warranty, do you mean the 3yrs or 36,000 mile warranty or the longer hybrid system warranty (california is 10yrs or 150k?)?
  10. Patrick Wong
    18,200
    6,500
    Since the gasoline engine is covered by the 5 year / 60K mile powertrain warranty, that is the relevant warranty to consider when thinking about whether to observe Toyota's maintenance schedule or not.
  11. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    I think it's pretty darn unlikely to have an oil related engine wear failure on these cars before 5/60 unless you really abuse it. Used Oil Analysis has shown I could take mine well past 10K without worry, but 10K is where I change it. Amsoil previously, now on Mobile 1.
    I'm doing about 15-20K miles per year so it's nice to halve the change frequency.
    - D
  12. Rest
    Rest Active Member
    1,210
    CA
    That's fine for synthetic oil, but I would change out the oil filter much sooner.
  13. dhancock
    357
    40
    True, BUT I wouldn't want to give Toyota an excuse to wiggle out of a legitimate claim. Hence, 5K changes till one hits 60K.
  14. uart
    uart Senior Member
    4,220
    1,210
    Australia
    Though in much of Europe the "official" oil change interval (oil and filter) is 15,000 km (9300 miles) and I think they still use the same OEM filters.
