Musty sour smell from vents in winter (no A/C)!
Discussion in 'Gen 2 Prius Main Forum' started by Tekdeus, Jan 19, 2011.
  1. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    Hi folks, I just bought a 2004 Prius with 35k miles from my local Toyota dealership. The interior smelled fine for the fist few hundred miles but suddenly there is that super foul sour musty smell coming from the dash vents. I know that using air conditioning condenses water and can cause mold on the evaporator coil; but being winter time, I've kept it off 99% of the time exept once or twice to defog, then turned it off right away.
    I am very diligent about keeping it on the "recirculation" setting most of the time since I can't stand breathing traffic exhaust. It's been raining a lot recently and the inside windows have been fogging up a lot. A couple of times after sitting, I've noticed very heavy condensation in the interior windshield below the front defrost dash air vent. What are the odds there is a water or coolant leak in the dash? Or could this simply be caused by high humidity from rain, leaving it set on "recirc" and running almost no A/C at all??
    I think I will first try cleaning the e-coil with the spray I've read about. Should I use the product the Toyota dealership sells? Or is there a generic version of this sold at auto parts stores that do the same thing? I'm hoping that I can solve this by blasting the e-coil and then being more careful about venting more fresh air, and then leaving it set on fresh air when parking. Opinions? Thanks.
  2. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    Don't keep your vents on recirc. That just makes the moisture buildup in the vents even worse, and causes the smell.
    I got my Prius on ventilation to get that nice dry winter air into the cabin, with the heat turned on. No musty smells in my '07 Prius.
  3. Patrick Wong
    18,200
    6,500
    I think that you are on the right track, per the fourth sentence of your last paragraph. You should allow fresh air to vent into the car as much as possible.
    If you had a heater core leak, the antifreeze would produce a sweetish smell. Also, if you had a leak you would expect to find some dampness in the carpeting.
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    May not be directly related to the problem but it's good idea to check the cabin air filter if you or the dealer haven't done so. Good luck! :)
