Inconsolable - Need Gen1 Help
Discussion in 'Generation 1 Prius Discussion' started by teachxxi, Jan 30, 2011.
  1. teachxxi
    teachxxi New Member
    Los Angeles
    2003 Prius
    Hi. I am a newbie to this forum, but a long-time Prius owner (2003 with 111,000 miles) who just received some very bad news and I need some advice.
    Friday evening as I was turning around in a driveway, warning lights began flashing and my car died in the middle of the street (thank goodness not in the fast lane of the 5 freeway). I consulted my Owner's Manual: Multi-information display graphic of car with ! take car to Toyota dealer immediately. I had my car towed to the local dealership.
    The next day I received a call that my auxiliary battery was completely dead and needed to be replaced ($248). Service would call back after installed to give me an update.
    About an hour later I received the worst call I think I could've, although I have not read other posts, so maybe someone here has me beat: even after installing the new battery, the Hybrid System Warning Light came back on. Diagnosis: Hybrid Inverter (sp?) Battery is bad and will continue to zap/drain auxiliary battery if not replaced. Cost: $3,759 for part with tax plus $2300 labor for a total of $6,059.
    It goes without saying that I do not have that kind of money to have the part replaced and I am not sure I would even want to considering that my car will be 8 years old in March. Now I am faced with having to buy another car, which I also really cannot afford.
    My Prius is my second Toyota. I consider myself an environmentalist and I care very much about the impact my consumerism has on our Earth. However, I am now scared to replace my Prius with another one if I will face this same issue in the future. I had planned on driving my '03 for at least 10 years before even considering purchasing a new car, which I had hoped would be even more advanced green technology...
    I would really appreciate advice and input. As of right now, my car is sitting at the dealership, but I must either go explore my options for another car or have it towed off of the lot no later than Monday. I looked at the Toyota website and it just makes me really sad to see that if I don't buy another Prius my other options are cars that get less than half the gas mileage of even my older model which was currently giving me 41 mpg.
    Thank you in advance for your comments.
  2. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    Good Lord. Tell them to bill you for 1 hr's diagnosis and put the bad battery back in. They knew damned well that the traction battery was most likely the culprit given the vehicle's age and could have verified it without putting a new battery in and attempting to soak you.
    Search the forums a bit and you will find that the traction batteries for these cars can be obtained refurbished for far less than what the dealer is offering.
    Oh. And :welcome: .
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't know what your financial situation is personally. But I would say, that's about the highest total I've ever seen presented for a traction battery replacement. I think you should be able to discover cheaper options.
    Tough call as to where you want to draw the line, or can draw the line. But I would search this very site...and just get on the phone to other dealerships...$6059 for replacement of the traction battery is about the highest figure I have ever seen presented.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    1) get a second opinion. Either another dealer or an independent who knows hybrids.
    2) If you need a HV battery, I recommend ReInVolt batteries, they use Gen II cells in the Gen I case. Gen I cells are more prone to corrosion. Near $1700 for parts.
    Remanufactured Hybrid Vehicle Battery Packs
    If you feel up to DIY:
    01-03 Toyota Prius Upgraded HV Battery Pack - eBay (item 130479704143 end time Feb-05-11 11:58:28 PST)
    These folks should be 'local' (Culver City) installers of ReInvolt, and may also be a good place for a second opinion.
    Modesti's Car Care Center | Auto Repair Culver City, Playa Vista, Marina Del Rey, Playa Del Rey, Mar Vista, Los Angeles, Westchester, Venice, Santa Monica, Palms, Inglewood, Ladera Heights, Baldwin Hills | Hometown Family Service You Can Trust Since
    It should be much closer to $2500 total. (in addition to the money you have already spent) That is way less than $6000
    You get used cells that may be 'newer' than a Gen I battery off the shelf, and seem to be less corrosion prone. In this one occasion, I am not sure new is better. The warranty is the same.
    There are detractors whose brother's uncle's Friend's Prius had trouble with ReInVolt, but we have never had an actual owner on PriusChat who was unhappy with them.
  5. fuzzy1
    10,409
    It still isn't clear to me whether the problem is the traction battery, an inverter, or both. Several items in the OP suggest to me that the high voltage to 12V inverter went bad.
    This needs to be clarified.
  6. teachxxi
    teachxxi New Member
    Los Angeles
    2003 Prius
    Fuzzy, thank you. As I get deeper into my research on this fabulous site, I realize that I do not have clear information as to the actual issue. The service assistant manager at dealership said "inverter" according to my notes.
    Service is closed today, but I am about to go up to get my car towed off of the lot (regardless of the diagnosis, it seems this dealership is trying to make a lot of money off of my ignorance). I will look at service details and post further information. I'm definitely not doing anything further until I get more input from all of the experts off of this site!
  7. fuzzy1
    10,409
    On Monday be sure to have the dealership tell you all the DTCs (diagnostic trouble codes) that the car produced. That will tell the more experienced mechanics here (not me) quite a bit more about what went wrong.
  8. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    If you can't afford to make repairs, will you buy another car? A $1,000 - 2,000 repair is cheaper than $10-20K for another car. Based on your current mileage and vehicle year (assuming you bought new), I gather you're willing to keep a car for as long as possible. If you repair the car, I'm thinking you'll need to keep the car a couple years to recoup some of the repair investment. Thinking of market value on your car, without the repair, the car is not worth much, if anything. If you make the repair, the car's value increases, at least enough to cover repairs.
    Ultimately, "repair vs. replace" decisions are not always easy, but I'm confident you'll make the right decision for your circumstances.
  9. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I hope things work out for you. Lousy to get a bill like that.
  10. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    What was the warrantee for the hybrid system on a 2003?
    The 2010s have a 150,000 mile warrantee on the hybrid system so if you buy a new one, you'll be covered for a long time.
  11. teachxxi
    teachxxi New Member
    Los Angeles
    2003 Prius
    Hi everyone! I can now clarify the issue with my car. The set code was P3130. The dealership said I need to replace the Inverter (cooling system malfunctioning) and the 12 volt battery. They gave me an estimate of $6405 PLUS tax!!!
  12. teachxxi
    teachxxi New Member
    Los Angeles
    2003 Prius
    Tom, I most definitely want to keep it for at least another 3 years. I am struggling with how much to invest in repairs before it is time to cut my losses and buy a new car. I wish there were some kind of formula!
  13. teachxxi
    teachxxi New Member
    Los Angeles
    2003 Prius
    That's exactly what happened. They took out the new battery and put back my old battery and only charged my $98 to diagnose.
    Thank you for the welcome. This is a really great website! I am so glad that I found it!
  14. hill
    8,794
    I skimmed through this . . . if your inverter (pump?) went south, the Gen II's are on recall. Don't know about the Gen I's though. It's worth inquiring though, none the less, because the cooling pump, the inverter itself, are ALL part of the synergy drive system, which gets the 150,000 mile warranty in CA. Do NOT let them blow smoke up you.
  15. fuzzy1
    10,409
    Check that warranty carefully. I seem to remember past discussions indicating that the 150k warranty began with Gen2, so OP's Gen1 warranty may be expired.
  16. mainerinexile
    403
    73
    Maine
    Even the warranty is expired, at 111,000 miles it is kinda close. I'd appeal your purchasing dealer for at least some help paying for the repair. Parts at cost, for example.
    Toyota is better than most car companies at being reasonable with customers. Look at what they did for owners of Tacomas with frame rust-though (like me). I got 11K of credit for a 12 year old truck with a blue book value of 3K.
  17. Matt's Dad
    Matt's Dad Junior Member
    Greensboro, NC
    I joined these forums just so I could ask...Teachxii, what did you decide to do? I felt awful for you after reading that original post.
  18. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    That labor cost for battery/inverter replacement is insane for a 8 year old Toyota but this is a Prius. Toyota is not a charity and they have to recoup the huge development and R&D costs for the Prius somehow plus all the freebie recalls given to other Prius owners ..
  19. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I've never had a Gen 1, but I'm leaning towards fuzzy1. AFAIK, the Gen 1s weren't AT-PZEV cars and thus shouldn't have a 150K mile warranty on anything inverter or emission related.
    I agree w/JimboPalmer and I think this dealer is trying to ream the OP. $2300 of labor to replace an inverter??? At my wild-guess rate of $150/hour, that means over 15 hours to do the job?
    Was P3130 the only code? Any more data accompanying the code? Can they give you a printout from Techstream?
    Too bad you are too far from Luscious Garage | Hybrid Specialists, but it seems they're knowledgeable. (I have no experience w/them.) Side note: I did stumble across Luscious Garage | Blog | Gen 1 Prius code P3130: Inverter System Cooling Malfunction when digging.
    If you can't get a competent dealer you, it might be cheaper to get it shipped to LG in SF to get it fixed, fly up then drive it back...
  20. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I'm moving this thread to the "Gen1" forum in the hopes that more Gen1 experts will see it. There will be a redirect left behind but it will expire after one week.
    I also added to the title to make it more descriptive and flag the Gen1 experts to look here.
