Charging the 12v battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by s1njin, Feb 3, 2011.
  1. s1njin
    s1njin New Member
    106
    Sellersville, PA
    Sorry if this is posted somewhere (I DID search, and I even google'd and narrowed the results to just Prius Chat).
    Is there a step by step guide to putting the Prius 12v battery on a trickle charger (something like the Battery Tender Jr. I use to maintain my tractor battery)?
    Hopefully its somewhat easy and doesn't require unplugging the car and ruining the windows, etc.
  2. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Not sure why you'd want to do this - but it is in the manual........
    Access is under the hood in the fuse box - there's a big copper block that you connect '+' to (clearly marked), negative goes to any metal surface under the hood... Pretty simple stuff..
  3. s1njin
    s1njin New Member
    106
    Sellersville, PA
    I just keep reading how folk's batteries are prematurely dying off. I know my car was made in August of 2010 and sat on the dealers lot until I scooped it up on 12/30. Seeing as how my dealer: didn't inflate the tires, didn't fill the washer fluid, and somehow forgot to phone in my insurance I'm going to assume they also didn't check the battery.
    So I figure, charging it overnight w/ a good trickle charger can only be good for it.
    No?
  4. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    12v gets charged everytime you drive the car. Just drive it everyday and you will be fine.
    Mine was a May 2009 built, no dead battery after 35K miles
  5. s1njin
    s1njin New Member
    106
    Sellersville, PA
    I put about 2 - 2 1/2 hours a day on the car, 76 miles round trip 5 days a week.
  6. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Your battery is as charged as it's going to get.
  7. cossie1600
    903
    94
    CT
    You worry too much
  8. s1njin
    s1njin New Member
    106
    Sellersville, PA
    Thanks all !
  9. Mark57
    2,945
    2,740
    OK
    FYI, my car was in the body shop for 7 weeks getting hail damage repaired and the battery was just fine. Note that I was driving it at a minimum of every other day so it was in good charged condition when it went in.
  10. wildbottom
    wildbottom New Member
    99
    JIC, you should know the procedure to check the battery and check it once a month. Especially if you have the battery for more than 3 years. If it's below 12.4V at 60F, you should charge it or. (A fully charged battery should be between (12.7V-13.0V depending on surface charge). It would prolong the life of the battery esp. if you use smart chargers. Charging with the car might not be the optimum for the battery.
    Plus, if you have access to a smart charger, it doesn't hurt to top-off the battery once a year.
    FYI, The OEM 12V Aux Battery has a 2 year warranty. The Replacement battery has 1 year warranty(~$150 or ~$200 installed). The 2nd Gen Aux Battery is similar to the 3rd Gen. So the price shouldn't vary much.
  11. Mendel Leisk
    41,029
    I agree. I've been using a CTEK Multi US 3000, maybe once a month. It has status lights, tells you how the battery's doing, when it's done charging.
    Regarding your dealer's inattention: want to bet your temp spare's got about 40 psi (or less)?
  12. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Which setting do you use, little battery or big battery?
  13. s1njin
    s1njin New Member
    106
    Sellersville, PA
    *groan*
    Time to add it to my list of things to do on Friday. Thanks !
  14. Mendel Leisk
    41,029
    The options are "motorcyle" (picture), "car" and "snowflake". I use "car". Snowflake is slightly more powerful, but I read somewhere it is a bit too much of a fast charge, that "car" symbol was best. It goes through a multi-stage charge, first stage "desulphating", something like that. Ends up with a maintenance charge rate, ie: you can leave it on indefinitely if you want.
    I like also that it shows orange light at the outset, and then when it's satisfied the battery is fully charged, switches to green light.
  15. Old Drum
    Old Drum New Member
    61
    Warrensburg, MO
    I have a dead battery report from a Prius bought in May, 2010 with 17,000 miles. In the middle of January, I left for a three day weekend to Chicago. The car was in the airport parking lot. I came back and the battery was dead.
    Last week, we had a lot of snow and car was not started for five days. Car started without problem.
    It is today days now with temperatures between 0-10 F and the car is in a detached unheated garage. I expect it to start tomorrow.
    Any idea why three days would drain it, but nothing since and temperatures even colder?
  16. cossie1600
    903
    94
    CT
  17. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    One little interior light left on would do it. My kids got me that way once, turned the dome light on in back and left it.
    - D
  18. Old Drum
    Old Drum New Member
    61
    Warrensburg, MO
    I have wondered that too, but I have yet to hit a switch for any light being on.
    So far, no re-occurrence and it has been below 0 F at night.
    Oh, well.
  19. uptownsteve
    uptownsteve New Member
    Vancouver BC
    According to the manual the fuse box location is for jump starting. Does the + connection there go directly to the battery? Where is the starting battery actually located?
  20. unkprius
    unkprius Member
    152
    This thread has made me paranoid about leaving my Pri alone for more than a weekend...the CTEK 3300 is arriving today!
