Am I hurting my car?
Discussion in 'Gen 2 Prius Main Forum' started by jackmccullough, Feb 7, 2011.
  1. jackmccullough
    jackmccullough Junior Member
    45
    Montpelier, Vt.
    It's a traction control question.
    To get into my road I have a very steep hill that's only about 20-30 feet long. When I try to pull up the hill when it's really slick (snow-covered and greasy, as we say around here) the traction control kicks in and stops the wheels.
    I have had two or three times, though, where if I keep sitting there and accelerating I can inch forward, maybe a foot or two at a time. Forward--spin--stop, forward--spin--stop, then I finally get to where I have more traction and I make it through.
    Is it hurting the car to do this?
    What about the tires?
    TIA.
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It shouldn't harm the car or the tires. You aren't actually spinning the wheels much. If you try to use a little less throttle it should actually work better. Try -slowly- increasing throttle until the car starts moving. Once the wheels loose traction what little traction there is actually decreases. So trying to prevent wheel spin should make it go up the hill a little faster (though it won't help a lot).
    Proper winter tires will help -a lot-. Also, if there is sand or rough ice/snow along the side of the road or in the centre, putting wheels on that can help. But be careful you don't slide off the road due to the camber.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    It's pretty hard to hurt the car. The worst that might happen is triggering a fail safe condition (triangle MIL) if a component begins to overheat.
    You seem like a good candidate for an Autosock.
  4. Jands
    Jands New Member
    88
    UK
    Next time try in in Eco mode...it'll give you finer throttle control.
  5. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Gen II doesn't have eco mode
  6. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Is there any way to get a little bit of a running start at he hill and build up a little momentum?
    Its not going to hurt the car per-se, but its not the most efficient way to deal with the hill no...
  7. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    When you press the gas pedal, just hold it in the position where the wheels start to spin. Don't let up on the pedal. The TC will smooth out and you will move slowly. People make the mistake of letting up on the gas when the wheels spin and then giving it the gas again.
  8. Jands
    Jands New Member
    88
    UK
    Ah my mistake.
  9. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    just don't try to go uphill backwards, the GenII prius only goes backward using battery charge and may not be powerful enough to power up over the hill.
    I wonder what happens if the above situation occurs and an unaware driver tries to back up with the battery at 1 purple bar? I realize the bars don't represent the 0-100% SOC, but still.
  10. jackmccullough
    45
    Montpelier, Vt.
    That's good to know. It's tempting, but the hill is steep enough and the visibility is bad enough out the back that I would be reluctant to do it anyway.
  11. Politburo
    Politburo Active Member
    971
    208
    The electric motors can propel the car to 40 mph.. I'm pretty sure they'll be able to handle any hill at low speed. I live and parallel park on a ~10% grade and have never had a problem (traction considerations aside).
    As far as the scenario, the car would command the engine to run, which would turn MG1 to produce electricity. This electricity would be routed to MG2 to propel the car.
  12. jackmccullough
    45
    Montpelier, Vt.
    Sometimes. I do that if I can, but the visibility is sometimes problematic, especially when there is heavy traffic on the cross street.
  13. David Beale
    5,963
    1,989
    Edmonton Alberta
    I was going to say this, but the manual and other gurus tell me there is NO charging or power supplied to the system when in "N" or "R". I suspect you are correct however, as supplying no power in R would be silly. Unless it's a problem with polarity.
    Remember, in "R" all motive power comes from a "reverse polarity" driving of MG2. So you have a maximum of 40 HP (torque would be adequate except it is limited to protect the battery - battery current limit). I've experienced almost getting stuck in soft wood chips on mud due to the very high torque required to move the car. I did manage to move the needed two car lengths to back out but it was slow and worrisome. ;)
  14. richard schumacher
    7,683
    1,065
    United States
    Indeed, the traction battery isn't charged in R, so one could entirely drain the traction battery by backing up a hill. The battery and motors have enough *power* to do it, but the battery may not have enough *energy*.
  15. ursle
    ursle Gas miser
    1,049
    192
    NH
    Time for new front tires with studs
    If you didn't have a critical situation regular winter tires would be fine but
    your's is a potentially dangerous scenario.
    Put studs on the rear also, you have to go down the hill half the time;)
  16. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    i have experienced the car not able to get up a hill in reverse, family driveway is short and moderately steep.
    the prius will not go up the driveway in reverse, it only makes it about 2/3 of the way.
    i have tried it several times in the last 6 months, often with green bars... still no good.
    it definitely would be a pain if it was a parallel parking space, and couldnt back up to get out.
    luckily theres enough room at the bottom of the driveway to do a 6 point turn and drive up in "D"
    definitely a deficiency in my opinion.
    i am not accustomed to being stuck in a fully operational vehicle due to a design flaw...
  17. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    to the original poster, if you are in that kind of winter weather area, it would be smart to get winter tires, a full 2nd set for the winter months would be a worthwhile investment. you will either use them forever or can eventually sell them to new owner or another prius lover in your area...
    you must be slipping in other places also????
    or at least get a better all season tire next time yours wear out...
    also worth noting while you are sitting there spinning going 2 feet at a time, you are a sitting duck, waiting to get slammed by a SUV jammin up the hill from behind you, or some clown sliding down the hill into you, you know once you are going down hill its very hard to control or avoid a car stuck in the middle...
  18. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    since the traction control stops you from spinning the tires, it's saving them.
    i see prius tire wear in two ways.. 1... it's a fairly light car so use should be ok... till you take in account the electric motor provided 295 ft-lbs of torque at 0... then, any wheel spin is bad since it breaks loose soo quickly.. yet as long as you're not "burning them up" (which again the car doesn't let you do)...
    so.. unless you're turning off traction control.. then you're ok... with traction control off you're damaging tires...
    its rather hard to abuse the engine... i've towed cars.. trailors... concrete loads.. lumbar loads... lots of things you're REALLY not supposed to do with a prius...
    tires are replacable anyways
    on a side note
    on slippery surfaces.. i simply accelerate to get a net effort out of the car.. if you want it to gain traction and get you up that hill while mildly slipping, hold it down 100%.. it won't go crazy.. it just goes crazy.. oh wait.. contradicting myself... it goes hyper... slip grab, slip grab.. much faster (and rougher) till you take off at a speed you want... fast (works on gravel, ice, and mud too... much more so on ice and mud... toyota and lexus cars hate gravel... very floating feeling.. very poor traction usually)
