AC compressor questions
Discussion in 'Gen 3 Prius Main Forum' started by noyztoyz, Apr 12, 2010.
  1. noyztoyz
    noyztoyz New Member
    Trinidad
    Hello Prius owners!
    Im new to this forum!
    I came here because i need some info.
    I have a 25000 watt audio system in my nissan vehicle and i have found need to remove my ac compressor to install additional alternators,
    and i was thinking about replacing it with an electric compressor relocated where there is space somewhere to preserve the ac function in this hot climate.
    I did some research and discovered Denso invented an electric ac compressor in 2004. This is what i need. Current is not a problem in my car. I can throw 1000a of current all day long. Theres 600lbs of batteries. SO i can power up this day and night.
    So i need to know about this compressor like
    what volts does it operate with?
    and what jacks are on it?
    and if any ac tech guys are on here, i would be glad for advice on this project.
    Thanks in advance guys.
  2. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    It is not that simple. It uses an AC motor, and has an invertor to run it.
  3. noyztoyz
    noyztoyz New Member
    Trinidad
    an invertor to invert what, thats what i need to know,
    im not familiar with electric cars.
    Does it like take a 12v supply and invert it to whatever it needs?
    I think i read somewhere it goes on 240v ac.
    That wont be a problem for me because 12v dc to 240v ac invertors are commercially available.
    But i think i read also that these electric cars work with 42v or somn. And if it needs a 42v supply that would be a problem for me.
    Please clarify
    thanks
  4. Patrick Wong
    18,200
    6,490
    The Prius traction battery produces a nominal voltage of 201.6V. This DC voltage is converted to three-phase AC by an inverter. That inverter is controlled by the hybrid vehicle and air conditioning ECUs.
    25,000 watt audio system? How much heat does that produce? Sounds like you'll need good air conditioning even if your weather wasn't hot.
  5. noyztoyz
    noyztoyz New Member
    Trinidad
    it doesnt produce heat becasue most of the times it plays at 1/40 volume for daily use.
    Thats loud enough.
    i need to know if the compressor works with this ac voltage or the dc voltage and if so what voltage, exact 201.6?
    Can someone unplug their compressor and stick in a meter to see what voltage it is??
    Im willing to pay some1 to help me out with this, i need to know this,
    there isnt other info anywhere a it has never really been done before. And no one here has a Prius!
  6. vertex
    672
    143
    new york
    2018 Prius Prime
    201.6 volts AC
  7. qbee42
    3,076
    It's not that simple. You don't stick a meter into it and measure the voltage. The A/C compressor on the Prius is a variable speed high voltage polyphase AC motor. You need to synthesize polyphase AC for your proposed application, and adjust the drive for starting and desired cooling.
    You might want to subscribe to Toyota's documentation web site for a day and download some schematics.
  8. Snarfty
    Snarfty New Member
    Australia
    Ok I'm going to rehash this topic. NoyzToyz did you ever manage to get this idea off the ground?
    I want to do the same not due to the lack of space in my engine bay due to alternators although I do have a big stereo. But so I can have no-idle aircon. I have a Toyota Hiace van that I have turned into a camper and it gets damn hot inside at night.
    So if anyone can help me with how to achieve this that would be awesome.
  9. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    25000 watts? seriously? That's more power than most radio stations use to transmit. And why would you even consider putting something like that in a car?
    The most powerful amp on Crutchfield is a RF that goes for $1400. It's 2500 watts. Are you telling me that you're going to run 10 of these in a Prius?
    i'm calling shenanigans until I see some pictures/specs of the equipment.
  10. Holmz
    Holmz New Member
    Antipodies
    Tom,
    How do they change the compressor's motor speed?
    Is it AC frequency or voltage? or both?
    The denso (ES14) unit also has inverter built onto the top of it, so I am not sure what needs to go in to alter the cooling action.
    Saw this video that shows the guy checking a fuse (1 so wondering if it is single phase or 3 phase). youtube.com/watchv=1xdauNpKoV
    The plug on the -04 and later looks like a 3-phase unit in here autoshop101.com/forms/Hybrid06.pdf
    Does anyone know where to get the plug for the A/C orange cable to plug into?
    25000W stereo? I have 100w per side at home in tubes, and the room is acoustically better. One would need the cooling with tubes.
  11. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    Santa Fe, NM
    The other end of the plug is physically bolted to terminals inside the inverter case, i.e. you have to take the case apart to get/replace the cable.
  12. qbee42
    3,076
    The drive unit is 3 phase variable frequency. I don't have the specs, but they are available from Toyota's tech web support (for a fee).
