Acceleration on ice situation
Discussion in 'Gen 2 Prius Main Forum' started by tnthub, Feb 15, 2011.
  1. tnthub
    tnthub Member
    519
    Brunswick, Maine
    I am aware of some of the limitations of traction control in regards to the Prius and I live in Maine. I have had zero issues with snow and ice while traveling except for one situation and I am looking for a solution...
    My 2007 Prius, when I am at a stop sign and need to enter traffic, simply does not move if there is the slightest slippage under the drive wheels. If I do not quickly remove my foot from the accelerator, the delay is long enough to launch me into oncoming traffic when it is most dangerous.
    I suspect there is a programming fix or work around for this issue since the delay creates a very dangerous situation.
    Can someone please direct me in the proper direction?
    FYI: (edit)... I have fresh set of blizzack snow tires mounted...
    Thank you.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    How else would it work?
    The car can either:
    a) Spin the tires and hope to gain some traction. Probably moving at a snails pace until that traction comes, and by then your window will have passed.
    or
    b) Don't spin the tires, move at an equally slow speed and by the time you get in position your turn will have passed
    There really isn't much that can be done about ice. If you allow for just creeping along on the ice and never give it so much accelerator that the TC kicks in, you will actually go faster.
    So instead of gassing it to the point of the TC kicking in and backing off, just slowly depress it like there is an egg under there. Same method that is used in a manual car when you start in 2nd or 3rd when on ice.
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    On ice you better have a light foot! It is the same with any car! I think I would find a parking lot covered in ice and practice until you can actually drive in ice condition's. Lots of us should just stay home when it freezes or take the bus. Sorry, Hal
  4. tnthub
    tnthub Member
    519
    Brunswick, Maine
    I understand traction (I drag race). What I have a problem with is not knowing when the car will hesitate and when it will not. In standard vehicles I can feel the slip and wait. In the Prius I feel nothing and suddenly it decides to move. For me, that is a viable safety concern.
    I'm 52 and grew up driving all types of vehicles (family construction business) and have had many successful seasons at the drag strip. This lack of response upon putting my foot on the accelerator is scary because I do not know if the car will move or not, and if not, how long it will be prior to actually taking off.
    I'm not stomping on the gas (heck I'm focused on decent gas mileage (currently at 48mpg during the winter), and simply getting into traffic with safety and room to spare from a stop).
  5. qbee42
    3,079
    It's just the way it works. There isn't any software fix or change you can make, other than running studded tires.
  6. Hal W
    Hal W New Member
    872
    53
    Anyone can drag race, but not all of us can drive on ice! Get a grip<grin> Hal
  7. tnthub
    tnthub Member
    519
    Brunswick, Maine
    I get the "grin" but respectfully disagree with anyone can drag race, if you add "and be successful"... :D
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Indeed. Anyone can do it, or track racing, but to be anything other than horrible it takes a little skill.
    Similar to ice. People in the southern states get around when there roads get a fraction of a mm of ice on them, but most end up in a ditch with their car on fire or doing 360's on the interstate playing bumper cars.
    Just depends on how you define "success" I suppose :D
  9. Mark57
    2,945
    2,740
    OK
    Don and Tom (The Snake and The Mongoose) would agree with you.;)
  10. Hal W
    Hal W New Member
    872
    53
    That is true on ice as well, or in anything for that matter. I believe the studded tire is the best solution? Some have disabled the system by removing the sensor wires on the rear wheels. Hal
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You can disable it entirely via software, no need to hack at the wires.
  12. tnthub
    tnthub Member
    519
    Brunswick, Maine
    Yes they would, as well as "Big" who was my first "pen pal" when I was eight years old... ;)
  13. tnthub
    tnthub Member
    519
    Brunswick, Maine
    This is what I am searching for between the months of December through March... I drive like the proverbial grandma on public roads...
  14. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Frankly, I'm surprised by this post. You are not a noob to prius or ice. What is your real question or concern?
  15. tnthub
    tnthub Member
    519
    Brunswick, Maine
    I have read all the "stuff" about traction control, hills, improvements and corrections by Toyota, and ways to disable traction control.
    I am extremely pleased with my 2007 Prius and have diven it for several thousand winter miles with no problem until...
    Once the weather turned damp as well as cold, the launch from a complete stop into traffic (like a "T" intersection) became a problem as the car would sometimes launch and sometimes not. When the car did not launch it would simply wait for maybe 3-4 tenths of a second and then launch, or it might be 5-8 tenths of a second before launching...
    That difference, when turning into traffic, with difficult vision due to huge snowbanks, became in my opinion a significant risk.
    This is the only issue I have with the Prius and I realize in another month or so it will be a non issue until next winter. I am looking for a simple fix for this problem as I am certain it can be corrected in some manner.
  16. Optimus
    Optimus Member
    274
    25
    What's your tire pressure?
  17. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    I had a corvette that did the same thing on dry pavement. Sometimes I hit the gas and the wheels would just spin, causing all types of smoke. Other times it just drove normally.
    Hope you get an answer to your issue.
  18. mthiker
    mthiker New Member
    ma
    The electric motors give a Prius instant maximum torque at zero RPS, hence they can exceed the static friction limit of the tire from rest much easier than a conventional gas engine, this may be why you perceive the Prius to "slip more" than your other cars--you just have to be aware of this and go easy on the pedal from rest on a slippery surface. The real winter solution, for any car, is to use ice/snow tires--after forty years of winter driving I discovered these a couple of years ago, and the difference is like night and day. Tires like Blizzak (sp?) have a special rubber compound that grips ice like studs without the noise and road destruction--such tires have a snowflake logo on them, which indicates "chain" rating.
