Discussion in 'Gen 2 Prius Main Forum' started by crowheart, Feb 17, 2011.
  1. crowheart
    crowheart New Member
    Illinois
    Hello,
    I am a new member of this forum and I am looking to buy a 2009 Prius to replace a 2009 Mazda 3 2.3 L hatch. I know very little about these cars, but I am trying to find out more.
    Is Electronic Stability Control standard on these cars? What does Toyota call their stability control? Mazda calls it DSC. We do over 90% of our driving in the city in heavy traffic. The Mazda 3 just doesn't get enough mpg's for my $.
    Are there any problems inherent with the 2009 Prius that I should be aware of? What about the acceleration issues? Any help would be greatly appreciated.
    Thanks again...
  2. Patrick Wong
    18,200
    6,491
    You should be looking for a Prius with VSC. This is not a standard feature. When you make the car IG-ON so that the instrument panel warning lights appear, you'll see one light with the VSC label, which shows the car has that feature. (From IG-OFF, press the POWER button 2x without depressing the brake pedal, to get to IG-ON.)
    2009 is the last 2G model year, and there are no inherent problems. The acceleration issue is primarily due to driver error. Good luck with your car buying decision.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
  4. bisco
    51,011
    what accelleration issues?
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  6. crowheart
    Illinois
    What about real world MPG's. We do all of our driving in the city in fairly heavy traffic with lots of lights and stop signs. What kind of MPG's could we expect in these kind of conditions?
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    Santa Fe, NM
    40 at a minimum. It is hard to get less. It is possible to do much better but there is a learning curve.
  8. Patrick Wong
    18,200
    6,491
    I suggest that you rent a Prius for a few days and see whether the mpg and the car's other features meet your needs.
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Depends on the driver, route, conditions and trip lengths.
    How long will the trips be in time and distance? Is the terrain hilly at all?
    It's not hard to get mid to upper 30s if the drives are short city drives in cold weather w/hills. I'm living that now.
    If one has ~5 minute city drives or less, it could get as low as 25. The first 5 minutes or so will virtually always yield crappy mileage.
    Agreed.
