New Review: Plug-in Prius in TDD
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by eheath, Feb 22, 2011.
  1. eheath
    eheath Member
    207
    New York
    I'm a long-time Prius owner and new forum member and I just came across a new review of what I believe will be my next Prius, the PHV. The writer spent a whole week with the car so it is an interesting read. Lots of photos and a slideshow, too! Review is online here.
    2012 Toyota Prius PHV First Look, Review, and Road Test
    Happy and Fuel Efficient Motoring!
    Edward
  2. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    First I heard that the plug in has an 11.3 0-60 time. If true, that's really disappointing.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    He got great MPG in the winter with one of the worst snow storms. I wish he reports electricity consumption to avoid Volt Fraud. PHV Prius displays EV to HV ratio so it is open and honest.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
  5. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    The additional 300lbs is the culprit.
  6. eheath
    eheath Member
    207
    New York
    Exactly. That is a downside unfortunately.
  7. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    I guess I'll need to join Weight Watchers before buying one.;)
  8. john1701a
    john1701a Prius Guru
    12,803
    5,287
    57
    When was the last time you dropped the pedal all the way to the floor?
    Remember, the Classic model of Prius 0-60 acceleration was 12.5 seconds, yet that worked just fine.
    Don't forget about the 0-30 acceleration; the electric motor provides quite kick off the line.
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Are you saying the PHV has more punch of the line than regular Prius?
    As for the 11.3 seconds, it will provide more fodder for the naysayers. Pretty sure the Volt is 9 or well under 10, so that will be compared to the moon. Well, it already is actually when they say, 'Volt drives nothing like a hybrid'. But, I do understand it is reallllly difficult to get high torque, power, efficiency and low cost. Can't have it all.
    Hey, the USA invented drag racing (NHRA), so acceleration from a stop has long been a big thing with 'US'.
  10. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    The PHV should certainly accelerate off the line more quickly in EV than the regular Prius but all EV acceleration is likely to be worse due to the small battery. With smaller batteries you simply cannot draw enough power for rapid acceleration at higher speeds.
    As johnboi points out you really want to see separate times in bands. 0-30 (the really important one), 30-45, 45-55, 55-65, 65-75. Just quoting 0-60 is lazy, ignorant or both.
  11. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I'll be sure to keep it away from the race track. As for my daily commute, I can't wait to buy one.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Yep, an 11 odd second 0-60 is fine by me too.
  13. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    And don't carry passengers...
  14. rvsupply
    rvsupply New Member
    Cebu City, Philipines
    Is is true that With a smaller batteries you simply cannot draw enough power for rapid acceleration at higher speeds ? I'm disappointed too...
  15. rvsupply
    rvsupply New Member
    For me this is true because my uncle try With a smaller batteries you simply cannot draw enough power for rapid acceleration at higher speeds....
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Remember, it is a hybrid. It will use both power sources for extreme demand. PHV battery and electric motor are sized for frequently used scenarios. The goal is to "do more with less".
    Gas engine is great for rapid acceleration at high speed but it'll greatly reduce the EV range when powered by the battery.
    Prius PHV will intelligently select the best combination automatically. It can blend gas power and continue to discharge the battery.
  17. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    The difference in acceleration between a Gen III and the plug-in is 0.8 mph per second (difference between 60 mph/11.3 sec versus 60 mph/9.8 sec). It strikes me as the smallest possible "sacrifice" or "disappointment" imaginable to achieve mpgs easily 200 and 300% better than most cars, and apparently, from this test, around 40% better than most Prii. It's an advancement, not a step back.
  18. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    Not sure why using an extension cord would short things out.
  19. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Leaving aside the questionable 20mi drive for groceries, the "EV" portion of the drive was done at local speeds. Highway EV miles will be worse.
  20. Jazz
    Jazz New Member
    Here
    2002 Prius
    A Car With Plug In.... :) Sounds like my Computer
