12V Battery Monitor
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ccdisce, Feb 28, 2011.
  1. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    2 people like this.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    For gen2 Prius from the OBD port we can get the 12V battery voltage, the HV battery temperature and outside air temperature. The latter two give a rough estimate of the 12V battery temperature. The chip above adds the capability to measure 12V battery current which I don't know whether we can get from the OBD port or not.
    What I do is periodically, maybe twice a month, put the battery under some load by turning on headlights and rear defogger and look at the battery voltage. This establishes a baseline. I posted some data here:
    http://priuschat.com/forums/gen-ii-...-trip-record-fun-early-problem-detection.html
    If I start to see the voltage under load to drop significantly then I know the battery may be sick.
  3. ccdisce
    259
    187
    Stone Mtn GA USA
    What I was hoping for was a package that I would install and forget ...until it sounds a Klaxon warning of impending death of the 12V battery a couple of weeks before the actual event. A day downcount on a LCD counting down the days to battery failure is good.
