First Road Trip - Impressions
Discussion in 'Gen 3 Prius Main Forum' started by Dweezil, Feb 28, 2011.
  1. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    I finally had a chance to take my first "road trip" over the weekend. I drove the car from St. Louis to Chicago, and back. The experience has made me appreciate my Prius even more. This is coming from someone who laughed at Prius drivers less than six months ago. I'm not laughing anymore!
    I have the V with the advanced technology package. Here are my impressions/comments.
    1) The radar controled cruise is fantastic. My ONLY complaint is that I tend to get slightly better mileage when it's MY foot controling the vehicle's speed. A couple things I found out while using cruise. First, if someone suddenly cuts in front of you the car alerts you and makes subtle corrections to aid in avoiding a mis-hap. Two, if the weather conditions get too bad (e.g. it begins raining too hard), the cruise control will shut off and alert you that it isn't available in adverse weather conditions.
    2) LKA (Lane Keeper Assistant). At first, I thought this was a silly gimmick. After using it all weekend, I've found that it's extremely useful. As you drift too close to the line on either side of the car, it beeps and makes a very subtle adjustment in the steering. I even noticed that even when it isn't alerting you that you're drifting too close to the line, it very gently assists in the steering of the vehicle...it was easiest to feel this when going around large sweeping turns. There were a few times when I would allow myself to wander toward a line, and without any input from me, the car would slowly bring itself back to the center of the lane. It sounds like this would be a danger...the car making adjustments in the steering...nothing could be further from the truth. Also, I found that LKA will not function if the windshield wipers are on (not counting intermittant). Very cool stuff.
    3) The NAV worked flawlessly. As I don't know my way around Chicago very well, I used NAV the whole time I was there. Not only did it get me where I needed to go with no issue, it alerted me to traffic conditions along my route and displayed the flow of traffic (red/yellow/green)...it was very accurate. My only complaint is that as you're typing in addresses, the keyboard is a little sluggish. After having nav in my last several cars, it's hard for me to remember what it was like driving around a large city via a map. Just think of the number of saved marriages and arguments avoided as a result of modern NAV!
    4) What trip to Chicago is complete without a visit to IKEA? Of course, one cannot step foot into that place without buying a bunch of stuff you never thought you needed until you saw it in the store. As a result I wound up with a few somewhat large items of furniture that I was able to fit inside the Prius with NO problem. They wouldn't have fit in a regular car, and if I were still driving my truck, the stuff would've been in the bed of the truck and gotten soaked on the way home.
    I'm sure most/all of this is described in the owner's manual, but it's really cool to use these tools and actually experience their usefulness.
    So far, the only gimmicky feature provided via the advanced techo package has been the parking assist. I've used it a couple of times just for the sake of using it. I can park my own car in a small fraction of the time it takes for the car to park itself. When I get to the point that I cannot park my own car, you can just take away my keys.
    With temps ranging from around 25 - 45, my grill 100% blocked and tires at 42/41, my gas mileage on the way up was around 46mpg. On the way home it was around 41. This mainly due to weather conditions and temperature...and partly to the rate of speed I was traveling. All in all, I'm very satisfied with how the car functioned throughout the duration of my weekend getaway.
  2. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Hi Dweezil! Since you didn't mention which grill was blocked, just don't block the upper grill 100%. It has to cool off the inverter. Sounds like your having fun in that great car! I can't wait till Spring to do some traveling and mpg will get better with the warm weather.
  3. Tideland Prius
    16,548
    Thanks for the write-up!
  4. Thai
    Thai Prius Neophyte
    1,197
    89
    Good writeup. My DRCC stops working whenever my wipers are on high.
  5. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    As it was pretty cold on the way up to Chicago (and while I was in Chicago), the upper and lower grills were blocked 100%. My temps never went above 202...mostly stayed in the 180-190 range. On the way home, the weather was quite a bit warmer, so I removed the upper blocking, and left the lower grill blocked 100%. Temps stayed in the 170-180 range.
    Are you suggesting that one should never block both the upper AND lower grills 100%, regardless of outside temps? I've heard talk of the inverter getting air, but figured if my temps weren't getting crazy high, that everything was copacetic.
    BTW, gotta love the Scangauge. :thumb:
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Didn't know that, but that's smart of the Prius as CC isn't supposed to be used in the rain nor is it smart to do so.
  7. Tideland Prius
    16,548
    It gives that warning message if the wipers are set to HI.
  8. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Usually driving down I-55 you get worse mileage since winds blow to the northeast 'round here.
  9. Thai
    Thai Prius Neophyte
    1,197
    89
    If i remember correctly, DRCC also shuts down in heavy fog. I believe it happened once for me.
  10. dkelly
    dkelly Member
    118
    Gilbertsville, PA
    I'm in agreement with most of your observations regarding the Advanced Technology Package. I CAN do better with my foot on the accelerator, but using the RCC takes a lot of the stress out of the drive -- I just go along for the ride. Also, from a safety standpoint, there have been times when someone ahead of me started braking suddenly and my Prius has stared braking before I noticed it.
    Yes, the park assist is mostly a toy but if you practice with it enough and learn its quirks it can park me just about as fast as I can do it myself. That being said, it's the only component on my car I've had problems with:mad:. Not due to failing components, but due to deer damage. I got a new bumper a few months back after hitting deer, and the park assist hasn't worked right since. Car is in the shop right now and they claim they finally have it fixed (ultrasonic sensor in the bumper, just like I've told them). Its the third time I've had it in to the body shop and/or service department for this issue (a lot of finger pointing here). The biggest hassle was educating the service folks about how this feature works, what is wrong, and how to fix it. Looks like they finally got the picture. Sorry for my rant!
  11. Tideland Prius
    16,548
    Haven't had dense fog yet so I'll take your word for it.
  12. Thai
    Thai Prius Neophyte
    1,197
    89
    Don't do that just yet...i had pretty good fog this morning...and my DRCC worked perfect. :p But, i swear that it did shut off...but that was a while back...so, nevermind! :D
  13. Tideland Prius
    16,548
    lol ok. Just be careful. Remember what happened at that S-Class demonstration?
  14. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Nice! I need a UHaul every time I go to Ikea!
  15. Thai
    Thai Prius Neophyte
    1,197
    89
    Hmm, i must have missed that...what happened to the S-class?? :eek:
  16. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Great! I didn't know you were monitoring with a Scangauge and in the frozen north. :D
  17. Tideland Prius
    16,548
    It's the Pre-Safe system. I can't find the original video but here's the same video shown on Top Gear
    [ame=http://www.youtube.com/watch?v=BYY7OfQ4-5A]YouTube - Mercedes Auto Brake Fail[/ame]
  18. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    If there is such a thing as karma, those Top Gear lads sure have it coming to them. ;)
