Turning off the VSC when using spare tire
Discussion in 'Gen 2 Prius Main Forum' started by jsquareg, Jan 27, 2009.
  1. jsquareg
    jsquareg New Member
    31
    Williamsburg, VA
    As far as I can recall, the manual for every car I have owned suggested the the VSC be turned off when the donut spare was mounted. I can find no mention of this in my Prius manual nor can I find a way to turn the VSC off.
    Is turning it off suggested for the Prius and, if so, how do I do it? How about the Traction Control? Same questions.
    The car is a 2009 Pkg 2 and has both Traction Conrol and VSC according to the window sticker that was on it when I bought it.
    Thank you very much.
  2. qbee42
    3,079
    You can't turn off traction control or VSC. To be completely honest, traction control can be disabled from a special maintenance screen, but the car is not supposed to be driven in that mode.
  3. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    The Prius VSC and Traction Control systems have no problem running with the spare mounted. There is no reason to turn them off.
    As stated above, you can't just "turn them off".
    If you did use the maintenance menu to turn them off there is a good chance you could destroy the transmission (HSD) by over-spinning it.
  4. jsquareg
    jsquareg New Member
    31
    Williamsburg, VA
    Your first sentence is what I wanted to hear. :) I can see no reason to think about turning them off.
  5. tomguild
    tomguild smugmobile owner
    28
    Raleigh NC
    2021 Prius
    I beg to differ. My '09 Prius touring (pkg 3?) is awaiting replacement tires (I accidentally punctured one last week while parking; the new tires have to be ordered), so I'm driving with the limited-use spare on the front right wheel.
    The traction control (the light with the skidding car) kicks in almost every time I drive, even while driving straight. The result is a car that loses power and slows down no matter what I do to the accelerator. I thought the computer would "recognize" the situation somehow, but so far (about 4 trips) it hasn't, and I would love to temporarily disable this "feature" for a few days.
    But I agree, I don't want to mess with that diagnostic screen. Any ideas? I have a few more days of this before my new tires come in.
  6. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    The best suggestion I have is to put the temporary tire on the rear. That way the traction control system won't be an issue.
  7. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    If you care to read the manual, all front wheel drive cars have you put the mini-spare on the rear rather than the front. The reason for this is the smaller diameter tire will ruin the transaxle which costs a hell of allot more than a tire.
  8. Patrick Wong
    18,200
    6,501
    My idea is that you should verify that the tire pressure in the spare is 60 psi. If that is good, then my second idea is for you to move the spare tire to a rear axle position.
  9. tomguild
    28
    Raleigh NC
    2021 Prius
    I do "care to read the manual". The manual says absolutely nothing about which axle the tire should go on. Not arguing with you on the wisdom of that...just saying that this particular detail isn't in the manual for the '09 Prius.
  10. GasPort9
    GasPort9 New Member
    New York
    2009 Owners Manual Page 442
    If you get a flat frt tire on an icy or snowy road, put the temp on
    the rear & replace the flat frt with the tire rmvd from the rear.
    Not exactly 'absolutely nothing' . It tells you of possible traction
    problems in slippery conditions
    Page 444 mentions which systems may not operate correctly when
    using the temp tire: ABS, EBD, & VSC.
    The 2010 manual also mentions TRAC.
    The smaller diameter temp is rotating faster than the other tire &
    has less traction. This is triggering the TRAC warning.
    Putting the temp on the rear should solve your problem.
    Drive carefully with that temp.
