12v jumping info - pc is a lifesaver - few more Q's
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jqmello, Mar 22, 2011.
  1. jqmello
    jqmello Junior Member
    70
    DC
    I just wanted to say that when my wife called me, completely panicked because 'the car won't turn on', I was quickly able to diagnose the problem and walk her through the steps for jumpstarting, thanks to this site and judicious use of the Search function.
    It was driven to her work on Monday morning, then left until Tuesday afternoon. The 12v was not completely dead, as the driver's door unlocked with the (non-SKS) fob, and it turned 'halfway' on about the 5th time she punched the start button. The display came on and all the warning lights were flashing simultaneously. She punched the power button again and it went dark and wouldn't turn back on (like the initial 4 attempts).
    She sucessfully jumped it from an idling car, had to put some gas in first thing (2 gal) but left it on 'ready' while fueling. The gas guage is still blinking as if it were almost empty. Mileage was awful for the first 10 miles or so, <25mpg. She's on the phone driving home and watching the mileage climb.
    I told her to leave it in 'ready' and lock it up when she gets home, only a 20-minute drive. I'll go find a battery float charger (Search function, here I come) so we can lock up for real and not need to jump again in the morning. We have street parking, but running a cord across the sidewalk shouldn't be a huge problem. Leaving on 'ready' without sitting on the porch, though, would be.
    Anything else I'm missing? She'll be carrying around my portable jumper pack now, we only have one between our two cars, and mine's been less reliable. I'll have to monitor the voltage and check back in (there's at least a dozen threads on the correct at rest / on & charging voltages) as to the state of the battery.
    More info: 2005 base model, 94,000 mi, we've owned for 1.5 months, no idea on age of 12v. Recently had service and recall work done (pedal, inverter drain & pump repl., brake fluid flush).
    Anyway, I don't want this thread to turn into an 'everything you need to know about jumping / charging / what type of battery do I replace it with', but I'd be happy for pointers to the active threads where I can contribute my .02 as this saga unfolds.
  2. BrettS
    BrettS Active Member
    290
    136
    Orlando
    Sounds like you've pretty much got everything covered, but the only thing I wanted to add is that unless there was a good reason that the 12V battery died... the dome lights or the head lights were left on or something, then most likely the battery is just dead. Even if you charge it well now, I think it's a pretty good bet that it will leave her stranded again in the coming days or weeks.
    Assuming it's the original battery, 6 years isn't a bad life span and I think you might be better off spending your money on a new battery rather than a float charger.
    hope this helps,
    Brett
  3. Patrick Wong
    18,200
    6,492
    I agree that the OP should replace the 12V battery on his wife's Prius now. For that matter, it sounds like his car also needs a new battery.
  4. jqmello
    70
    DC
    Hmmm... well, I made a stop by the auto parts store and picked up a more sensitive DMM, to look at 1/10 volt. I also picked up a three-stage charger (10A, 6A, 2A) for $50, it has settings for "standard" or AGM.
    The car had been on or sitting in 'ready' for ~3hrs by the time I got back. Testing showed:
    "Ready" - 13.75V
    off (2-5 minutes) - 12.64V
    Charger, 2A 'trickle' setting - 12.97V
    The battery did look OEM, said "Toyota" on the top, so I suspect it is original.
    I'd probably do the elearnaid/Optima install I saw here, although I might hold off and monitor the battery (sans trickle charger) to see where its resting after normal driving and sitting overnight.
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Welcome, you are going to fit in just fine here!!! You have figured out the search function, got the right answers, and let us in on it!
    SWEET!
    Stick around, enjoy yourself!
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    It was in my owner's manual somewhere, the Prius needs at least 3 gallons to 'notice' it has more gas.
    You can fill it all the way up, 2 gallons at a time, and it will still claim to be empty.
  7. jqmello
    70
    DC
    This morning, after sitting on the 2A trickle charge, with the charger still connected the battery was at 12.45V
    I disconnected, and the voltage fell to 12.38
    From what I've seen here I've got less than half a charge and it's time to replace it with the Optima D51R and elearnaid kit ($180, ouch!)
    I've heard that the "R" for vented might not be made anymore? this true?
    Also - Jimbo, that's crazy! I guess they figure it's such a small tank who wouldn't fill it all the way up? I know I sure would - it's not like .05 or even .15 difference in price is more than about a buck all told.
  8. Patrick Wong
    18,200
    6,492
    The fact that the voltage was only 12.45V with the charger connected shows you that the battery would accept a considerably higher charging current, which means that it is substantially discharged. Usually the charging voltage will be ~13.8V or thereabouts.
    If you measure voltage on the 12V battery after you've given it several hours of resting time, you'll probably find that the new voltage is somewhat below the 12.38V that you had measured, perhaps 12.1V or so.
    I suggest that you call the Toyota dealer parts depts in your area to see what the local price for the correct Toyota 12V battery is, so you can compare against the $180 price that you cited above.
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    Santa Fe, NM
    D51R is not the Optima that you want. The R stands for "right side positive," which would put the positive terminal close enough to the back fender well to short out in the event of a collision. Plus, you'd have a difficult time making the connections. D51R is what would go into an 01-03, where the battery is on the driver's side. The elearnaid kit for 04-09 does come with the proper venting connectors as well as a D51.
  10. jdenenberg
    jdenenberg EE Professor
    3,919
    1,917
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The "R" stands for Reversed Terminals and both Optima size 51 models are vented. ElearnAid will sell you the correct Optima (The non-R - I believe).
    JeffD
  11. N.J.PRIUS
    N.J.PRIUS Member
    140
    Fort Lee, NJ
    2013 Prius Plug-in
    My '05 gave up the 12 volt battery about a week ago. (76,565). I went to start it and nothing, then I pushed again and it came on. Clock also seemed to start acting strange a couple of days before. Had to reset a couple of times! That should have been a tip off of what was happening. Then it was dead one morning. Had triple AAA jumpstart. Went to dealer-had the recall on the water pump done at the same time. Cost of new battery and labor $294.18.
    My only question is how do they change your battery and not lose all of your pre-set radio stations?
  12. jqmello
    70
    DC
    Maybe that should have been a warning? Although, ours is an aftermarket unit, so who knows what goes on there.
    Thanks everyone for the corrections on the "R" moniker. I just thought that was part of the name. Now that's one (expensive) mistake I won't make!
    elearnaid has the battery+kit listed at $205, on sale for $180. Hobbit's photo-tutorial looks like it will come in handy, but I'll probably shop around the dealers here first for the OEM.
  13. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi jqmello. A day and a half is not really a very long time for the battery to go flat. Can your wife remember if she she left anything on, like an interior light or a front door ajar for example.
  14. jqmello
    70
    DC
    Hi uart,
    It isn't very long, I agree. She says she didn't leave any dome or task lights on, checked after she jumped it. She always locks it with the fob, not the door button, so the doors couldn't have been open, really. Headlights turn off when driver's door is opened, so that's not it either.
    Clock was keeping time, mileage was pretty good - 52ish on our trip to the Poconos, 46ish around the mountians and trip back. We lost our radio presets earlier, but I'm not sure when, noticed on Sunday. The Kenwood head unit is a little wierd though without any prior epxerience or manual, so it's entirely possible I reset them trying to change the radio seek settings.
    One possibility is that: driver's door did not close completely, she thought she locked it but it didn't really, and the dome light stayed on, and she only thought she unlocked it when she got back? I tend to believe her though, she's pretty careful about locking up, especially if she's leaving it at work overnight.
  15. jqmello
    70
    DC
    Thanks for the advice!
    My car got a new battery a few months ago. Jump starter kit is in there more for the slow tire leak than the battery.
  16. uart
    uart Senior Member
    4,220
    1,209
    Australia
    That's a really common one, and it's easy to do. The problem is that there's a small door light (front doors only) right down low at foot level. If a front door is left ajar then this light stays on, and unlike the dome light it's not easily visible from outside the car.
    The car wont lock properly if the door is ajar (and from memory I think it beeps to warn you). However if your wife wasn't paying real close attention then she could easily have missed that and thought that it locked correctly even though it didn't.
  17. Paul R. Haller
    285
    Walnut Creek
    You can keep all your radio presets and clock time by adding a jumper battery to the car in front while you change the battery in the rear. It saves time and problems for the customer if you jump it while changing the battery. When I did mine, I used the jump method and checked on Toyota pricing on a new battery. 169 for a new Toyota battery. I went with the e learn aid battery kit.
    -Paul R. Haller-
  18. jqmello
    70
    DC
    Update:
    After all the advice here, decided to try to limp on this battery for a while. Trickle charged it overnight for two nights. Voltages seem to be back up, a little below what they're supposed to be but pretty consistent. No more starting problems, although my wife now has the battery jumper pack, rather than me. We just left it for 12 days on a trip and it started right up afterwards.
    We'll continue to monitor it and be careful about the dome lights etc. Hopefully we'll get some significant life out of this battery yet.
