No service at 6 months?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobdrad, Mar 24, 2011.
  1. bobdrad
    bobdrad New Member
    Central Florida
    I just took my 2010 Prius into a dealer for service. I bought the car 6 months ago, but have only 1900 miles on it. The Toyota service schedule says to bring the car in at 5000 miles or 6 months, whichever comes first.
    But the dealer (not the dealer I purchased from, they have terrible service as I discovered when I had a flat tire a few days after I bought the car), told me not to bother ("it has synthetic oil, and all we do at 5000 miles is rotate tires") and to come back after 12 months or 10000 miles.
    If that's true, why does Toyota recommend service at 6 months even if less than 5000 miles? Should I ignore the times and just go by the miles? Or, if the 6 month service is really important, what should I say?
  2. jdenenberg
    jdenenberg EE Professor
    3,921
    1,918
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The 10,000 mile oil change interval was a late decision by Toyota so there is some confusion about the 6 month interval (12 months is probably OK). I am a bit old fashioned and always do an early oil change to handle break-in issues. So I would insist on the 5k/6month oil change even if I had to pay for it. I would then follow the 10k/12month that that dealer suggests thereafter.
    Since you are a low mileage driver, I suggest that you keep an eye on the little 12v battery as it may tend to slowly get discharged. The charging system in your Prius is slow and assumes longer trips to maintain the State of Charge (SOC) of the 12v (not the big one) battery.
    JeffD
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    There is nothing on the 6 month/6k mile list that can't wait 12 months with the low miles you are driving, assuming you are keeping an eye on fluid levels on the 6mo/6kmile check list.
    My other two cars (A Honda Product and a GM product) both say they should get maintenance when an oil change is required or 12 months, whichever comes first. There is nothing about a Toyota that makes it require scheduled maintenance more frequently than those cars.:cheer2:
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    With only 1900 miles on the car, wait for the 12 month service. As jdenenberg stated above, your 12v battery will need watching since you don't drive the car much.
  5. Spenumatsa
    Spenumatsa Junior Member
    77
    Nashua, NH
    I was in the same situation with my 2010 Prius. Toyota made a late change in service schedules that is not in the manuals. Any way, i had the oil change done at 5000K and paid for it. I know engine break-ins make the oil dirty and it is advisable to get it changed.
  6. vnhk
    vnhk New Member
    106
    san jose
    Ah, the Prius loves to be driven, and you don't give it enough love by not driving so much. :)
    On the other hand, just do 10k/1 year service, which basically is just oil change and tire rotation.
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Kudos to your dealer for giving you some money-saving advice! Don't let your oil go longer than a year.
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    In addition to the comments above, I'd suggest reading the warranty/maintenance booklet that came with the car. Your dealer's comments are not exactly accurate.
  9. RamRam
    RamRam Junior Member
    Saint Louis, Mo
    I might add that the manual addresses jump starting the Prius. There is a "dock" in the engine compartment for jump starting, but it can be used to slow charge (2 amp) the 12 v battery too. You can also easily check voltage there.
  10. Mendel Leisk
    40,513
    True, but they're mostly small potatos, especially considering the mileage:
    (I've managed to pry ours out once for a vacuuming: it is tenacious! This seems purely a concession to the unexpected acceleration issue. It's every 6 months in the States, never mentioned in Canada)
    (With the mileage, pretty safe bet that'll be just the windshield washer fluid)
    (They mentioned this. And yeah: pointless with the mileage.)
    (A little more significant, but: with the mileage, even "visual" inspection is near overkill. Toyota also uses the word "service", at least in the Canadian literature.)
    FWIW, Honda recommends a brake "inspection" every 12 months, and I'd speculate it's comparable to Toyota "service". Though, so far I've not discovered just what Toyota expects for "service". Honda's description for "inspection", in a nutshell, for disc brakes:
    Take off the bottom caliper bolt, rotate up and secure caliper, and pull off the pads/shims. Disassemble pads/shims, inspect (pad thickness/condition, shim condition), clean and re-assemble with anti-sieze compound (sparingly) on all points of contact. The main two issues: pads worn down near service limit (1~2mm remaining), and/or shims rusting out.
    Inspect caliper for signs of leakage, cracking. Check it's moving freely on pins. Check piston boot condition.
    Inspect all brake lines, for integrity, leakage.
    Check disc with micrometer and dial indicator for thickness, parallelism and run-out. (In practice this tends to get old pretty fast, ie: 12 months is overkill, especially for a hybrid)
    Pull off and inspect any anti-rattle clips, typically the clips at both ends of the pads, pushed into recesses in the caliper (check that they're solid, unbent, not rusting out), clean and re-install them. (This also get's old fast, I've never seen a problem with these, maybe depends on design)
    Reinstall pads/shims, with anti-sieze at contact points with caliper/piston/anti-rattle clips.
    Swing down caliper, re-install and torque bottom bolt.
  11. bobdrad
    bobdrad New Member
    Central Florida
    Thanks folks, but how does one "keep an eye" on the 12v battery? I don't have any indicators for it, do I? How does one charge the battery via the "dock"?
    BTW, I totally do give kudos to this dealer. Not only did they resist the temptation to charge me unnecessarily, but they even give me a free car wash to make up for the time I'd wasted going there! And it's not even the dealer I bought the car from!!! (I did get a quote from them when I purchased but it wasn't competitive, OTOH the dealer I did buy from is tiny and low-budget and has terrible service)
    They can be sure to get my (eventual) service business. In case anyone cares, it was Central Florida Toyota.
  12. twittel
    1,605
    148
    Mt. Pleasant, SC
  13. bobdrad
    bobdrad New Member
    Central Florida
    1900 miles over 6 months is > 10 miles/day, so I presume I'm good here for the 12v battery charge.
    Thanks folks!
  14. Mendel Leisk
    40,513
    Invest in a decent digital voltmeter and you can verify: should be around 12.6 volt or higher.
    Another worthwhile investment: a modest amperage, portable charger with intelligent charging, ie: you can leave it on indefinitely if you like, as the battery charges the charge rate goes down to trickle charge. I went with a CTEK 3300, but there are a number of choices. You can just hook it up overnight, periodically, say every month or two.
