calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. fuzzy1
    10,405
    From the article, it isn't clear to me whether this particular statement is limited to hybrids (including their Silverado), or covers the gamut of vehicles with MPG displays.
    But because it was published in early 2006, it cannot be including the Gen3 Prius.
    At 25k miles, the error in mine is 6.0%. This appears to be typical of Gen3 owners posting here, while Gen2 owners typically report better accuracy.
  2. Mendel Leisk
    41,305
    The Honda Civic Hybrid, second generation, errs on the conservative side: if the in-dash says (for example) 5.0 liters per 100 km, calculated usually turns out to be 4.9~4.8.
  3. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I completely agree. My ex-girlfriend had a 2006 Civic Hybrid, and I
    kept accurate records of true and computer generated MPG's.
    Alway the error was on the conversative side. If the mpg guage read 52 MPG; caluclated would be 53-54 MPG.
    Just the opposite of our Prius. Our Prius is off consistently 3-3.5 MPG since day one and now we have 46,000 miles and it is still
    off 3-3.5 mpg's.
    al
  4. PETEPRIUS
    PETEPRIUS New Member
    NEW YORK
    2010 Toyota Prius IV with Navi
    With close to 675 miles I have noticed the MPG guage is off usually 2-3 MPG in the positive.
    LAST FILL UP COMPUTER CALCULATE WAS 46.7 ACTUAL MPG WAS 43.7
    DOES GAS MILEGAE IMPROVE WITH TIME AND WARMER TEMPERATURES?
  5. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Warm temps and dry roads is Prius Heaven.....
    al
  6. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    My calculated mpg averaged 5% lower than the display over the first year. It is pretty typically a 2 mpg difference.
  7. OHSTATEBUCKEYE
    OHSTATEBUCKEYE New Member
    MO
    I'm consistently seeing 2MPG less between the computer and hand calculation. I'm running about 55 on the computer and 53 by hand calc.
  8. Canard
    Canard Member
    223
    Ontario, Canada
    My understanding is oil is changed every 8000 km in Canada.
    Thanks for the reply - I will monitor the error when compared to other fueling stations.
    -Iain
  9. seedypea
    seedypea Junior Member
    New Market VA
    2002 Prius
    2002 Prius
    155160 Miles
    3172.207 Gal
    48.9 mpg
    Diusplay averages 2.8 mpg High -
    But this is an average of an average
    seedypea
  10. tennisfreak
    tennisfreak New Member
    Had my Prius for just over a month now and have driven about 1500 miles in it (this includes a long road trip from DFW to houston).
    Last tank of gas mpg figures were this:
    Computer: 49.7 mpg
    Hand: 48.6
    Not too bad I'd say.
  11. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    With complete records, I consistently earn 50+ mpg for 89k mi. Gasoline will eventually go to $20 gallon ($5 Liter), driving the Prius is great. The problem are the wacko drivers who continue to substitute oil for knowledge, don't care about fuel efficiency and think oil and the road will go on forever with no consequences, and in the process let their egos endanger those around them.
  12. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Just refueled mine (Built 09/09) at the same pump/station as the previous time.
    MFD: 53.2 MPG
    Calculated at pump: 49.82
    Difference: ~6%
  13. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    24,000 miles and I'm consistently 2.1 generous on the MFD vs calc., GPS and Scangauge II. But in almost 2 years of hot and cold weather I'm still at 54.2 cumulative.
    Love it!
  14. robby3
    robby3 Member
    181
    24
    Switzerland
    Compared this the first time:
    MFD: 4.8l/100km (49 MPG)
    Calculated at pump: 5.2l/100km (45.23 MPG)
  15. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    A bit on the high side (8%), but if you average among several different tanks at different fuel pumps and consistently fuel up the same way, I suppose you will end up at 6% average, like most report here on PC.
    Thanks for sharing!
  16. mite66
    mite66 Junior Member
    36
    Bought it last november, don't know when it was manufactured.
    Added a PHEV kit in January (that worked on and off since then)
    Date calculated Prius diff.
    2010-12-15 5.49 (43 MPG) 5.1 (46 MPG) +7%
    2011-01-26 3.68 (64 MPG) 3.3 (71 MPG) +11%
    2011-02-16 4.79 (49 MPG) 4.3 (55 MPG) +12%
    2011-03-20 3.07 (77 MPG) 2.7 (87 MPG) +13%
  17. djfnw
    djfnw Junior Member
    27
    United States of America
    I’ve read through many of these posts and it has answered my question about the accuracy of the computer calculated mpg. The consensus seems to be that the calculated mpg is about 6% higher than the manual calculation. I’ll post my results as I get them.
    This discussion has led me to a new question. How do they calculate the 51 mpg city and 48 mpg highway ratings, that are stated on a new Prius? These are the mileage statements for the 2011 Prius. I hope they don’t get these ratings from the computer calculated mpg.
  18. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    I am going to imagine they do like mythbusters does and put in a seperate tank and measure the weight, drive it, measure again kind of thing.
    They couldn't use the computer because not all cars have them and that would be quite irresponsible (though it is a gov. entity).
  19. Mendel Leisk
    41,305
    Reminds me of mail-in rebates: Companies rely on customers procrastinating, giving up, losing the paperwork or just plain forgetting.
    Similarly, Toyota sets up the computer to lie about miles per gallon (liters/100km), relying on customers to get tired of calculating: just giving up and bask in the glow of falsely optimistic numbers.
    It would be really nice if they would 'fess up and fix it. If it makes them feel better, skip the 'fess up, just fix it.
  20. williebill1939
    williebill1939 New Member
    Barrington Illinois
    Gallons into miles the old fashion way,2011 III first half tank 319.3 mi.5.99 gal.i'm impressed,local and back roads 50/50.
