Overinflated tires
Discussion in 'Gen 3 Prius Fuel Economy' started by Superdrol, Apr 3, 2011.
  1. Superdrol
    Superdrol Member
    399
    32
    I live in the Midwest and slightly overinflate the tires around Oct in anticipation of the winter and potential pressure loss. I wound up fillin the Prius with approx with 50psi which is higher than the max 44psi.
    I've kept it thus far and I've noticed the ride quality is more 'harsh' however my winter mileage was slightly better 1.5-2mpg compared to what I expect in colds weather.
    I am very mindful of severe potholes as the tires are slightly overinflated but I'm considering keeping them this was as the Middle East violence is likely to continue and crude will likely test 2008 highs due to the weakness in the USD.
    Anyone else keep the psi higher ?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If you do happen to hit a pothole, you could end up damaging something more than just the tire... rim, ,suspension, alignment. Chances are better with that higher pressure I would think.
  3. Superdrol
    Superdrol Member
    399
    32
    In theory that would make sense however I don't think it is likely that is the case because the standard side wall on the stock wheels (I have the hubcap version) is high and has more rubber vs the rim version. If anything damage would be more likely to be incurred from larger rims with thinner side walls like guys here who run 17s or 18s with 35 rated.
  4. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I run 44/42 normally as it is my wife's daily driver, and she wouldn't want the ride any harsher than that. When I take a solo trip, I am comfortable at 50 with my 44 max tires.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I had to check my calendar to confirm this wasn't an April fools post. :p
    If you did a search, you'd find lots and lots of posts/opinions on this subject. My guess is this is probably the most discussed topic on this forum. ;)
  6. ETC(SS)
    7,505
    I personally do not think that running your pressures up to 50psi is a very good idea. If you get a 1.5 mpg bump (no punn intended) over stock that's what?....about a 15 mile increase in tank range? That's if you can quantify a real 1.5 MPG delta. We'll presume that you can for the purposes of this post.
    Balance that increased range against the possibility of exacerbating an already rattle prone interior, and against an (albeit slight) increase in the possibility that you'll suffer tire and/or suspension damage from whamming into potholes with board-stiff tires.
    In my never to be humbled opinion, the increased fuel efficiency is pretty insignificant.
    The consequences of a catastrophic tire failure, and possible insult to other suspension (and interior) components are simply too great to gamble over this slight benefit.
    But hey…..I’m a live and let live kinda guy! As long as you’re not hauling crumb crunchers around…I’d say it’s your car and you should be allowed to do as you please.
    JMHO.... :)
  7. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Hi Chief: Crumb crunchers.......I like that !!!!!!!!!
  8. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Do overinflated tires cause more tire wear and increase stopping distances? I have read that the center of the tread will wear faster, requiring premature replacement. I would question the advisability of overinflating if this is true.
  9. ksstathead
    1,244
    245
    Kansas
    This is not true. Within reason, higher pressures increase tread life, improve handling and traction. The cost is in terms of NVH (noise vibration harshness). It is all in how you drive, where you drive, and what value judgments you make. By within reason, I mean max sidewall or slightly above.
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    +1:rockon:
    In addition, uneven tread wear from over inflation was a bigger problem with old bias ply tires. Most radials don't have that problem at reasonable pressures. Under inflated or normally inflated tires (and their wheels) are more likely to be damaged by hitting potholes or curbs.
  11. Superdrol
    Superdrol Member
    399
    32
    I used to keep the tires at 42psi. I just noticed the difference when I put more air in them. The ride quality is noticeably more harsh but that's about it.
    I don't buy into the premise that the tires being overinflated can damage the suspension. The vibration is absorbed into the rubber side walls. Large rims however like 17s or higher send the vibration directly into the suspension system due to thin side walls and larger alloy. As I said typically those run thin 35s.
  12. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    First, as a Priuschat moderator, allow me to make this point very clear:
    If you are old enough to buy and drive a Prius, you are old enough to take responsibility for anything you do to your Prius. This includes, but is not limited to, inflating your tires above the manufacturer's suggested psi and/or the sidewall ratings. Any damage to your vehicle as a result of your actions is solely your fault and your responsibility. Just because you read it here and thought it was a good idea does not mean Priuschat loaded a firearm, placed it to your temple and insisted that you act on something someone else wrote.
    (Sorry, but this is a very hotly debated issue. I have, personally and publicly (major Chicago newspaper), been accused of putting Prius owners and their vehicles in harm's way by suggesting that they consider over-inflating their tires.)
    Okay. I run 52 in the front and 50 in the rear. I have seen no significant improvement over 46f/44r. For this reason, when my psi drops from 52 into the high forties during the winter I'm not overly concerned. However, when I went up from 37f/35r to 42f/40r, my mileage increased. It was near the end of the summer and it was the first time my mileage improved as the temperatures dropped. Details in my mileage log and chart (see signature).
    There are engineers who own a Prius and other hybrids. They examine and evaluate everything to incredible details. If you are willing to believe what they have found, then you would be comfortable in the knowledge that over-inflated tires last longer, handle better and provide a SHORTER braking distance than tires inflated to the sidewall rating. The improved handling was most noticeable in rain and on winter-mix conditions.
    Over-inflated tires - modern tires - do not bulge like the tires of yesteryear.
    However, the tire is taken into consideration when manufacturers design the suspension of the car. The tires, shocks and struts all work together to provide the ride designed by the manufacturer. When you over-inflate the tires, you stiffen the ride. If your goal is purely mileage and you are willing to tolerate a stiffer ride, than over-inflating (up to a point) is the way to go. But if you want the riding experience designed by Toyota, inflate your tires to the recommended psi and no higher.
    In the end, NO ONE should be driving a car with under-inflated tires. There is simply NO EXCUSE for that.
    3 people like this.
  13. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Unless, of course, you take it on the beach for some dune romping. :D
  14. TonyPSchaefer
    14,816
    2,501
    66
    I know better than to use "no one", "everyone", "always" and "never" and yet I still do it. :)
  15. fuzzy1
    10,687
    When I was active at a different efficiency forum, a number of regulars would not publicly admit to their tire pressures, out of liability fears. But they did acknowledge exceeding 50.
    Some of them pointed to an outside article by a police trainer / stunt show driver, who used 100. But for liability reasons, his department stuck to sidewall max for patrol vehicles.
    Prii come with several different brands/models of tires, and I thought one of them has (or had) a sidewall rating of 51 psi. Mine have the same 44 rating as yours, so that is my limit.
    Center wear was a problem in the old days with bias ply tires, as they would bulge like a balloon. Modern radials have multiple steel belts around the tire circumference, just below the tread. These steel belts don't bulge out at anything close to reasonable pressure.
    Increased tread life is one of the common reasons for using higher pressures, at least up to sidewall max. After seeing it greatly reduce edge wear on a past car, I'm a believer.
  16. tochatihu
    tochatihu Senior Member
    9,954
    3,844
    Kunming Yunnan China
    2001 Prius
    In 2001 I bought a Prius. For the first 10k miles or so, I followed Toyota's pressure rec. The excessive tire edge wear was obvious. Then I went to the tire sidewall max pressure in front, and -2 psi in the rear. The reasons for that diff can be found in PC archives.
    Tread wear (edge to center) balanced out, mpg improved, and handing (subjective) also improved. For subsequent tires on that car, my guideline was on the tire sidewall, not the Prius doorframe.
    Over the years we have indeed beat this horse (perhaps not yet dead), but I find that the doorframe rec. tends towards "comfy". Not long tire life, not emergency handling, and not mpg. I don't know what the doorframes say nowadays; perhaps Toyota has joined me? Or not.
    But the major issues here are: Safety - if you feel that higher inflation gives you less control over the vehicle, reduce it! Tread life - but then of course you'd need to measure it. The $20 Asian digital calipers do this very well. Comfort - If the NVH gets to you, try lower psi.
    I have read, here and there, that high-pressure tires are more likely to kablooie through a pothole. evidence seems to be lacking. Correct me here please.
    Click and Clack are our vehicle gods, but they still seem to be behind the curve about center tread wear (for radial tires) under 'over infaltion'. Sad.
    If you are serious about tire safety, maintaining (whatever) air pressure is not the whole story by far. You should visually inspect your tires every few k miles, and certainly before any long high-speed flight.
    Cousin Tony suggests that exceeding the tire sidewall psi is a personal responsibility decision. I agree.
    (edit) Oh just one more thing. The wear bars on your tires are like 1.3 or 2 mm. Wet adhesion decreases rapidly below 4 or 3.5 mm. I would be happy if all my friends driving Prius replaced their tires before the wear bars show. Sorry about the rubber waste, but if your tires don't do what you ask, youse could die.
  17. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    My very first vehicle was a '91 Miata and I overinflated the tires to try and improve fuel economy. The center wear was painfully obvious after 10,000 miles which gives me pause to ever purposely overinflate again.
    For safety and liability reasons I maintain psi below max sidewall.
  18. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    When gas goes over the $5.00 per gallon mark
    every little bit of gas mileage is going to count.
    If you inflate your tires to MAX Sidewall Pressure, usually
    44 to 51 PSI, each tires is clearly marked on the sidewall.
    Once inflated to MAX Sidewall pressure your tires are still
    safe, and you will get a gain in MPG's over the recommended
    air pressure from Toyota.
    Your ride will be a little harsher perhaps, but its a lot better
    than walking the extra distance you will get with the inflated tires.
    al
  19. tochatihu
    9,954
    3,844
    2001 Prius
    J5A, one would want to know if those were radial tires, and how far 'over' you were.
    It is clear that xs center tread wear proves that your contact patch has become tiny. Not so safe.
  20. tow truck
    tow truck New Member
    I am pretty sure overinflation will DECREASE traction in winter in any car- I do like to overinflate the other 9 months thou
