Air horn installation... and the factory warrentee...
Discussion in 'Gen 2 Prius Main Forum' started by amm0bob, Apr 8, 2011.
  1. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    I am getting real close to installing an air horn.
    Before I do... is it going to void my warrentee???
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You came with a warranty?:D It must be expired by now.
    2 people like this.
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    If you fry the horn's electrical system yes you might have warranty problems. For the hybrid components, Toyota would need to "prove" that your changes caused a problem with the factory parts.
    Good Luck
  4. amm0bob
    7,730
    2,547
    Re: Air horn installation... and the factory warrant... and yes, Im expired according to the label
    Actually... according to the VA... I was supposed ta be a goner 25 years ago... :D
    Ima speckin bout what I be rollin in Bra... :D
    I like my little hybrid... I don't want to prematurely void the warranty, and all the extra coins I paid for getting it at the top of the hype, just because I want to alert a-holes on teh highway...
  5. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    Yes, it will void the warranty.......on your OEM horn. Toyota must prove that any other damage was caused by the horn change to void your warranty on any other systems.
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Relax. The horn system is very simple. There are two horns, a high pitch and a low pitch. Each has a single wire that carries +12V when the horn switch is closed at the steering wheel. There is no ground return wire, the ground is the physical mount to the radiator support. Using that circuit to power your air horn carries the least risk.
    I put Sequoia horns in mine. They are also single terminal and bolt right in. I have no problem at all getting someone else's attention!
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The safest and easiest way to install after-market horns is to put in a relay. The small black 1" cube type draw less than the stock horns. You run the contacts directly from the battery power through a fuse (say 10A) to the new horn and the other side of the horn grounds on the body. The relay coil runs to the stock horn wire and the other side to chassis. You can even put in a SPDT switch, so in one direction the car uses the stock horn (excuse please), and in the other direction your new horn (get the *#&%$ out of the way!!!). ;)
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I vote for Mr. Beales method. It's also uninstallable!, Just unplug stock horns, plug into existing horn wire to drive the relay. If ever a problem, simply plug OEM horns back in, pull new horn out, what problem?????
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That also has the advantage of getting nearly full battery voltage to the horns. Factory wiring is sometimes a little skimpy.
  10. DGH
    DGH Thread Terminator
    365
    94
    Wales, WI
    There is not a lot of room to work with.
    What air horn are you going to use?
    I put in a Wolo Bad Boy, it's compact and much louder than stock.
    Without the overkill of a true trainhorn.
  11. amm0bob
    7,730
    2,547
    I've seen those... even one in chrome... they are almost loud enough... maybe with a pair of em... hmmmmm...
