Wheel Stuck on Car; Won't come off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Apr 10, 2011.
  1. cyberpriusII
    1,155
    1,763
    Mars Hotel
    The left driver's side wheel is "stuck." The car is up on the jack, the lug nuts are all off, but the wheel will not come off.
    I've hit the tire with my hands and have pulled and yanked, but being that it's on the jack, don't want to pull too hard.
    I can take it into the shop tommorrow, I guess, but is this a sign of anything serious?
    ***EKKK*** I just saw a recent post about a rusted on hub? Is this the same thing. All I am trying to do is change the tire???****
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That is usually a corrosion (Oregon Loctite:D) problem.
    Put the lug nuts back on, then loosen them several turns.
    Then drive the car back and forth a few times (3 or 4 mph is enough) and jab the brakes hard to stop each time. That should brake the wheel loose so then you can jack the car up and take it off.
    Don't drive the car on the road with the lug nuts loose:eek:
    When you put the wheel back on, wire brush away any corrosion and put a little grease or anti-seize where the aluminum wheel contacts the steel hub.
    Dael and WilDavis like this.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I had an 85' Maxima for my first car, same problem. I had to leave a rubber mallet in the trunk in case I had a flat, it was necessary to get the wheel off. If you hit the tire with the mallet from the 'backside' it should release.
  4. Mendel Leisk
    41,332
    I use xs650's technique, except I've not had to resort to rolling the car. Usually the wheel will break loose as you drop the car back down. One time I had to actually settle it completely on the floor, and then give a downward push or two on that corner, before it broke free.
    frodoz737 likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    They did that on my 07 after one year. Like the last poster said I just loosened the nuts up and dumped the jack and they popped off.
    I greased the tire/wheel mating surface real good with synthetic grease and after bolting it up wiped off the excess and 3 years later when I went to rotate the tires they came right off.
    When the tire is off the car push off the center cap from behind and leave it off. Mount the tire and fill that center cap well with grease and then pop the center cap back on. Keeps the hub nut from getting really rusted on. Did you see hoiw rusted that was?
    No grease leaked out to get on the rotor either.
    Big galvanic action there with disimilar metal.
  6. cyberpriusII
    1,155
    1,763
    Mars Hotel
    THANKS EVERYONE!
    Opps, sorry for the shout-out!! Just happy for the advice. I went to Portland yesterday afternoon to catch a concert and did not get back until early this a.m., so have not had a chance to try out the advice given.
    But, I have the day off, it's sunny -- sort of -- calm, and the temperature is nudging 43 degrees right now at 9 a.m. -- that's almost high summer:p
    Anyway, I'm going out in a few months -- opps minutes -- and give the "loose nuts" treatment a try (there are so many ways you can go with that phrase....:rolleyes:).
    I like the mallet suggestion, but just afraid to try any real force with the car being supported only by the little jack.
    And, yes, our weather does lend itself to auto-locking together any bits of metal. But here's the thing, I thought the wheels are "alloy." Doesn't that mean they don't rust?
    Ah, well, if this "rock and roll" idea doesn't work, I'll be back!:)
  7. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    When you do get the wheel off....and you will with a little sweat maybe,anyhoo,before you put it back on,use a wire brush to clean off around the hub and apply a little grease and give the inside of the centre of the wheel itself a rub,it'll help the next time especially if you're stranded on a motorway with a flat.
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Alloy just means that they are mix of two or more metals and possibly other elements. You will never find wheels made from pure aluminum, they would be too weak.
    The problem is that aluminum (the wheel) and iron or steel (the hub) have different values on the galvanic scale which is some 25 cent words for saying they form a battery when wet and that causes them to corrode and adhere to each other
  9. cyberpriusII
    1,155
    1,763
    Mars Hotel
    Huh, thanks for the clarification. My mountain bike has alloy wheels, just because they won't rust and they WILL -- usually -- stop in the rain...I really did not know that about the Prius wheels. Surprised Toyo didn't harness that bit of charge also. :)
    So, if anyone cares, I went out, froze as the temp dipped to about 34 degrees and hail came bucketing down and wind gusts hit about 40 mph. I was worried about the jack.
    But, followed advice, backed out hit brakes, speeded up and hit brakes again and I could "feel" it all break loose. So, all is good!
    Thanks again, everyone. Kristi
    Dael likes this.
  10. PH8
    PH8 Junior Member
    Loose nuts and hard braking usually loosen my wheels. But the last time I couldn't take off 2 stuck rear (alloy) wheels, I went to a tire shop. They hit the wheels out (no nuts) from inside with a 3-foot sledge hammer, while rear end was on a jack. I'm thinking of buying a sledge hammer so next time I can remove the wheels myself. I change wheels twice a year on two cars (summer & winter tires on separate rims). I worry about damaging my wheels with sledge hammer, but that seemed to be the only way that time. Any thoughts?
  11. Patrick Wong
    18,200
    6,500
    Use of a sledge hammer is really a last resort. You should first try more subtle approaches, like loosening the lug nuts and applying the brakes as previously suggested. Or raise up the corner of the car with a hydraulic floor jack, then drop it down with the lug nuts loose. Or kick the tire with your shoe-clad foot when the corner of the car is securely raised up with a jackstand.
    Once you have the wheels loose then it would be a good idea to lubricate the hub face and wheel interior with a small amount of high temp grease since you know that this will be an ongoing problem.
    WilDavis and dave77 like this.
  12. tv4fish
    tv4fish Member
    202
    46
    I also would NOT be using a sledge hammer to beat on your wheels (NOW - if you can hit ONLY the tire from the inside - maybe :) )!!! You WILL damage them.
  13. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I've used the big hammer on the inside to knock a stuck wheel loose, but I don't hit the wheel, that would really damage an alloy wheel, but it really works well if you hit the tire. I have had to rotate the tire and hit in several locations around the tire, but it always works.
  14. Joe Wilger
    Joe Wilger New Member
    2002 Prius
    Rubber mallet did the trick for me.
  15. Joe Wilger
    2002 Prius
    Also first block the vehicle from rolling.
    Release the emergency brake.
    And no one inside stepping on the brakes, either.
    Just wanted to be complete.
  16. Rich12
    Rich12 Member
    176
    29
    Haiku. Nice.
  17. williamjacobs
    williamjacobs Junior Member
    Thanks for this.
    The wife did what you suggested and it worked.... except the part about putting the lug nuts back on.
    *KA-CHUNK!*
    D'oh.
    Hopefully the cost of repairing the wheel will be less than the tow and taxi would have been. (i think the odds are good here in the DC suburbs.)
  18. ChapmanF
    18,076
    I often, at least if it's not super-ultra-eterna-stuck, get a pretty good result by grabbing something out of my toolbox that has a long skinny plastic-covered handle (so as not to mar the wheel), and sticking said handle between the wheel 'spokes' and against the caliper bracket (the part that doesn't slide) and prying. Gives a surprising amount of mechanical advantage, and often almost uneventfully pops off a wheel that was quite refractory to other types of persuasion.
    -Chap
  19. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    If you do use a sledge hammer, just have a friend hold a 2x4 in front to hit the tire with from behind. I've had good luck with this method. Of course, you want a stable jack (agree I wouldn't do this with the emergency jack that comes with the 2nd gen!). The loosening the lugs a few turns and doing a hard brake I never thought of. Good advice!
    Something I've noticed on my tires this year when switching over to winter tires is that when taking them off, usually the wheel will only move in one direction initially. I have to push on all different sides until I find a way in which it is loose. Then similar to baby teeth, I wiggle it back and forth and it slowly comes loose.
  20. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    Just happened the same thing to me. I called the insurance's travel assistance to take care of it. Took some time take it off with a couple on hard kicks but it finally popped. The strange thing, there was NO RUST. The operator showed me that at the previews service they put Locktite. Wth seriously what for?
