48÷2(9+3) =
Discussion in 'Fred's House of Pancakes' started by Presto, Apr 13, 2011.
  1. 288
    18 vote(s)
    42.9%
  2. 2
    24 vote(s)
    57.1%
  1. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    That really changes it. I think you forgot a digit. :)
  2. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    That's what was bugging me. Mikewithaprius got it.
    4÷2(1+1)=1
    4÷2*(1+1)=4
    Without the "*", The "2(1+1)" is a single expression.
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Haha.. Hockey playoffs means there's a good chance I'm on beer no. 5 or 6 by that post.
    48*½(3+9) is what i meant :doh:
  4. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Speaking of hockey....(Fair to assume you're a Canucks fan?)...if you count the posts, it was a tie. :rolleyes:
  5. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    It's cases exactly like this that prove our [ame="http://en.wikipedia.org/wiki/Infix_notation"]infix notation [/ame]is lousy. We should use [ame="http://en.wikipedia.org/wiki/Polish_notation"]prefix [/ame]or [ame="http://en.wikipedia.org/wiki/Reverse_Polish_notation"]postfix[/ame] instead.
    Using prefix, if we said 48÷2(9+3) = 288, that would appropriately be represented as * ÷ 48 2 + 9 3. This directly tells you to divide 48 by 2, add 9 and 3, and multiply the two results.
    On the other hand, if we said 48÷2(9+3) = 2, that would be appropriately represented as ÷ 48 * 2 + 9 3. This tells you to add 9 and 3, multiply that by 2, then divide 48 by the answer.
    I won't get into postfix, since it makes things just as clear, it's only backwards from prefix. This removes any possible ambiguity or misunderstanding from the situation.
    I still remember when i first found out about prefix and postfix back in my high school computer science class... Completely enthralled by the idea, and it was a lot of fun writing a program to convert between the three while performing the calculation.
    PS. I learned it as PEMDAS, not BEDMAS...
  6. qbee42
    3,076
    No, it's not. Adjacent terms have an implied multiplication symbol. They are identical.
    4÷2(1+1)≡4÷2*(1+1)
    2 people like this.
  7. frodoz737
    frodoz737 Top Wrench
    4,509
    2,430
    33
    48/2(9+3)=
    48/2(12)=
    48/24=
  8. qbee42
    3,076
    48/2(12)=
    24(12)=
    288
    You took the operators out of sequence. Infix notation is evaluated left to right for operators of the same precedence. The parentheses do not mean to first multiply 2*12. For that to be true they would have to be inside the parentheses, as in the following:
    48/(2*12)
  9. frodoz737
    4,509
    2,430
    33
    Well my high school son verified you are correct. Answer is 288. This type problem is used as a tool by their teachers.
  10. bisco
    51,058
    and yet, we're losing in the poll. so much for improved math and science education in the u.s..
  11. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Using the logic that parentheses never imply multiplication first, I would solve the following question in the following way:
    Solve 6÷2x when x = 2.
    6÷2(2)
    3(2)
    In this case it's quite clear that's incorrect, though this is the procedure used to get 288 in the main example. Parentheses, besides coming first in PEMDAS, have a stronger case for multiplication than left to right. It is part of the simplification process.
    6÷2x
    6÷2(2)
    6÷4
    3/2 or 1.5
    The method directly above is the way to solve that problem, and with that same logic, you get 2 for original problem.
  12. frodoz737
    4,509
    2,430
    33
    The problem may be just how it written. I read 48 over 2(9+3)= Others read 48/2 x (9+3)= Sending this to school with the boy to see what the "Teachers" say for a laugh.
  13. qbee42
    3,076
    No, your first approach is correct. 6/2*2 is indeed 6. It should be very obvious by inspection that if you multiply and divide by the same number you get the original number. This particular case is commutative, so it doesn't matter what order you do the arithmetic:
    6*2/2 = 6
    6/2*2 = 6
    2/2*6 = 6
    You picked a poor example. You need to throw in some addition or subtraction to make a good example, but that is beside the point. Infix notation clearly doesn't work the way you claim.
  14. eagle33199
    5,122
    268
    2015 Prius v wagon
    i think the key point here is that infix notation sucks. Obviously people interpret it different ways depending on how they were taught (PEMDAS, BEDMAS, always go left to right when dealing with operands of equal importance, whatever), which leaves us in a situation where more than half the people in the poll don't pick the generally accepted (by the mathematics community) correct answer.
    But that's America for you... why teach a method (like prefix or post fix notation) that is clear, concise, and impossible to misinterpret like this when we have a method that isn't clear, requires additional information (parenthesis) to ensure correct order of operations, and generally just causes problems?
  15. qbee42
    3,076
    Why would you say that? Parentheses can easily force multiplication to come first. Here is a simple example:
    22+(4*7)
    Of course the parentheses are not really needed, since multiplication comes before addition.
    A better example would be this one:
    4^(2*3)
    In this case you would normally raise 4 to the power of 2 and then multiply by 3, but the parentheses force the multiplication to come first, so you get 4 raised to the power of 6.
    This thread is really silly. What happened to basic math skills?
  16. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Probably the same thing that happened to basic writing skills, and basic reading skills, and critical thinking.
    If sense were common, everybody would have some.
  17. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Hey, nobody told me there were going to be math problems on this site!
    The way I was explained to me, while attending Moore Science High,
    288.
    Just ask Peorgie Tirebiter, he's a spy and a girl delighter.
  18. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    You can't. He cut the soles off his shoes, climbed a tree, and learned to play the flute.
  19. johalareewi
    johalareewi Member
    393
    44
    uk
    Why not consider the general case?
    a÷b(c+d) is (a÷b)*(c+d)
    not
    a÷(bc+bd)
    Similarly,
    a÷b*c is (a÷b)*c not a÷(b*c)
  20. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    damn, y'all suck at math 288
    2 people like this.
