Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. F8L
    19,011
    4,083
    Grass Valley, CA.
    With so many new LRR tires becoming available I decided it may be helpful to have a current list with specifications in one place. I am listing all of the available tires rated as LRR. If you notice any that I have missed please let me know and I'll add them to my list. I'm still sick so I'll make this first post more informative once I feel a bit better. Until then here is a short list of tire that I find to be most useful for saving money and fuel.
    When choosing a tire for fuel efficiency and economics it is important to take tire life into account. While some tires rate higher in LRR, others have extreme longevity. In some cases a tire that has to be replaced twice due to a low treadwear rating may cost you more in the long run. In other cases the tire with the lowest rolling resistance may be cheap enough that you can purchase 2 sets and still save money compared to a more expensive but longer lived tire. Other factors that may influence your tire choice is manufacturing process and tire material ingredients. Nokian and Yokohama stand out in this respect because their tires are made with less toxic materials and/or use less petroleum in the manufacturing process (80% less with the Yokohama). The Nokian plant is powered by hydroelectric power and the Yokohama plant is rated zero emissions.
    Another thing to consider when choosing a new tire is revolutions per mile. You will want to choose a tire that closely matches the revolutions per mile of your OEM tire. While in my experience the revolutions per mile has not had a dramatic impact on my speedometer or MPG, it is something to consider if the revs/mile are drastically different. Please see the link below for a better definition of revolutions per mile and how it can affect your mpg and speedometer. For information on the Prius v (Wagon) please proceed to the bottom of this post.
    Your tire choice is personal and should be based on your specific needs. If you live in a very wet climate then a good tire for you should emphasize wet handling and traction. If you live in a very dry climate then a LRR summer tire may be all you need. For those in snowy regions or those who desire traction and handling above allow else you may want to consider a tire that emphasizes those points even if you take a larger hit to mpg. The most important factor you should consider is safety. Without good traction any mpg savings you get from a tire can be wiped out in seconds due to an accident. Tirerack.com conducts tests on tires that attempt to rate tires based on traits like wet and dry braking and handling, mpg, noise, comfort, etc.. They also include web-charts to show how well a tire performs in a certain category. Use these charts to determine if a particular tire fits your criteria in that category. For example: I wanted a 17" tire that "was quiet, handled well and excelled in wet traction. Using the web-charts I was able to determine that the Primacy MXM4 was by far the best choice for me.
    One additional trait to consider is temperature and climate. At temperatures below 40 degrees, traction can be drastically reduced unless you are rolling on a tire designed for cold winter temperatures. This applies to dry traction conditions as well because summer and all-season tires lose their pliability in cold temps. In some northern states or countries, an all-season tire just doesn't cut it. Some all-season tires can handle light snow when temps are warmer but they will never compare to the traction and overall safety of a true winter/snow tire. for safety reasons I recommend purchasing a second set of wheels and tires dedicated to winter driving.
    For LRR tire test results performed by TireRack.com please click the following links or see my thread which includes winter tires:
    Testing Passenger and Standard Touring All-Season Tires: Which Are Truly More Than Just Round and Black?
    New Tire Tests from Tirerack.com | PriusChat
    Testing Passenger and Touring All-Season Tires
    When Round and Black Becomes Mean and Green
    Eco-Friendly All-Season Tires — How Does Performance Measure Up?
    Testing Eco-Focused Crossover SUV All-Season Tires in Real World Conditions
    Testing the Michelin Premier A/S: Is it the New Benchmark Among Grand Touring All-Season Tires?
    Testing Grand Touring All-Season Tires with a Sporty Edge
    For a better understanding of what LRR means and how new tires can affect MPG please click the following links:
    Low Rolling Resistance Tires/Fuel Efficiency
    Part-1 Understanding Corporate Average Fuel Economy (CAFE)
    Part-2 Defining Rolling Resistance
    Part-3 Changes to expect when switching from worn-out to new tires
    Learn how tire price, treadlife and fuel economy can affect lifetime ownership costs:
    Total lifetime cost for fuel and tires over 150,000 miles | PriusChat
    For European tyre models see this thread: Low Rolling Resistance replacement tyres (Europe) | PriusChat
    Priuschat.com Favorites in North America
    Michelin Energy Saver A/S
    Michelin Primacy MXM4 (V-rated)
    Bridgestone Ecopia EP422
    Continental PureContact with EcoPlus
    Goodyear Assurance Fuel Max
    Hankook Optimo H727 (not LRR but a good tire)
    Pirelli Cinturato P7 All-Season Plus (available in 17" sizes)
    For those who just want to be told what to get here it is:
    Michelin Energy Saver A/S = The ultimate in mpg, good wear but lacking in performance. Good wet braking. not great in snow. Low noise and comfortable. The hypermilers dream tire! My personal favorite!
    Goodyear Assurance Fuel Max = Great mpg but behind the others in road noise, handling, and overall road manners and performance. Great tread wear but lacking wet traction. Good snow/ice traction but behind the EP422, barely.
    Bridgestone Ecopia EP422 = Great mpg! It is behind the Energy Saver A/S but higher than the Fuel Max. So-so wet traction, great snow traction, poor handling tire and lacking in dry braking and cornering ability. Comfortable and low noise. Tread wear average.
    Continental PureContact with EcoPlus = Very high tread wear, excellent wet braking and handling, great steering feel but rides a bit rough. A Grand Touring tire which should be compared to other tires in this category. I.e. it is likely less efficient than Standard Touring tires like the OE units.
    Michelin Premier A/S = Very high tread wear, excellent wet braking (best in category) and handling. A Grand Touring tire which should be compared to other tires in this category. I.e. it is likely less efficient than Standard Touring tires like the OE units.
    Pirelli Cinturato P7 = Very comfortable tire with great fuel efficiency for its class. Only available in 16" and 17" sizes. May be a good replacement tire for the OE 17" tires. Less traction and handling than the competition but by a small margin.
    *Tires are listed in the following format: UTQG Rating, Max Psi, Tread Depth, Tire weight, Revolutions per mile, Rim Protector, Price at Tirerack or other retailer.
    175/65/15 (Prius c OEM size)
    Bridgestone Ecopia EP422 (All-Season)
    UTQG=480 A A, 44PSI, 10/32, 17LBS, 869, $81
    Yokohama AVID Ascend (Grand Touring All-Season)
    UTQG=800 A B, 44PSI, 12/32, 18LBS, 866, $89
    Goodyear Assurance Fuel Max (All-Season)
    UTQG=580 A A, 51PSI, 10/32, 16LBS, ?, $104
    Continental ContiProContact (Grand Touring All-Season)
    UTQG=400 AA A, 51PSI, 10/32, 16LBS, ? $99
    185/65/15 (2004-2009 Standard U.S. OEM tire size)
    Grand Touring Summer
    Bridgestone Ecopia EP100
    UTQG=400 A B, 44PSI, 10/32, 17LBS, 857, $80
    Yokohama dB Super E-Spec
    UTQG=460 A A, 44PSI, 10/32, 18LBS, 848, $114
    Goodyear Assurance Fuel Max (Viva Authority Fuel Max at Walmart)
    UTQG=580 A A, 51PSI, 10/32, 16LBS, 855, $86
    Kumho eco Solus HM KR22
    UTQG=800 A B, 44psi, 11/32, 19lbs, 855 $68 (100,000mile warranty)
    Nokian eNTYRE
    UTQG=720, 16.8LBS, 11/32, 851, $113 (TiresbyWeb.com)
    Nokian H
    UTQG=320 A A, 17LBS, 11/32, 851, $124
    All Season
    Goodyear Integrity
    UTQG=460 A B, 44PSI, 10/32, 17lbs, 855 $73
    Yokohama Avid Ascend (T)
    UTQG=800 A B, 44PSI, 12/32, 20LBS, 847, $87
    Cooper GFE
    UTQG=540 A B, ?PSI, 10/32, ?LBS, ??
    UTQG=400A A, 44PSI, 10/32, 17LBS, 852, $81
    UTQG=480 A B, 44psi, 9/32, 17lbs, 851, $106
    Michelin Primacy MXV4 w/GreenX
    UTQG=620 A A, 44PSI, 11/32, 20LBS, 851, $98 (60,000mile warranty)
    Michelin Defender w/GreenX
    UTQG=? A B, 44PSI, 10/32, 18LBS, 851, $115 (90,000mile warranty)
    Michelin HydroEdge w/ GreenX
    UTQG=800 A B, 44PSI, 11/32, 856, $103 (90,000mile warranty)
    Kumho ecowing KH30
    UTQG=440 A A, 44PSI, 9/32, 17LBS, 851, $73
    Continenatal ProContact w/Eco Plus
    UTQG= 600 A B, 44PSI, 10/32, 848, $77 (80,000mile warranty)
    Hercules RoadTour655
    UTQG = 440 A A, 44PSI, 10.5/32, 18LBS, $57.27 Onlinetires.com
    15" Studless Ice & Snow
    Michelin X-Ice Xi2 w/ GreenX
    UTQG=None, 51psi, 18lbs, 851, $98
    Nokian WR D3
    Nokian WR A3
    Nokian All-Weather+
    Nokian W+
    Nokian WRG2
    UTQG=, 17LBS, 11/32, 851
    195/60/15 (2004-2009 non-U.S.A. OEM tire size)
    Bridgestone Turanza Serenity Plus (Grand Touring All Season)
    UTQG=600 A A, 44PSI, 12/32, 21LBS, 860, $98
    UTQG=800 A B, 44PSI, 12/32, 20LBS, 855, $87
    Yokohama YK580 (Grand Touring All-Season)
    UTQG=580 A A, 51psi, 10/32, 19lbs, 855 $96
    Kumho Solus KH16 (Grand Touring All Season)
    UTQG=440 A A, 44PSI, 10/32, 18LBS, $71
    Kumho Solus HM KR22 (All Season)
    UTQG=800 A B, 44PSI, 10/32, 19LBS, 862, $73
    Kumho ecowing All Season KH30 (Grand Touring All-Season)
    UTQG=440 A A, 44PSI, 9/32, 18LBS, 858, $74
    Hankook Optimo H727 (All Season) reported to be great in snow
    UTQG=700 A B, 44PSI, 11/32, 20LBS, 858, $76
    Pirelli P6 Four Seasons (High Performance All-Season)
    UTQG=500 A A, 44PSI, 9/32, 22LBS, $79
    Continental ProContact w/ EcoPlus (Touring All-Season)
    UTQG=600 A B, 44PSI, 11/32, 18LBS, 858, $
    Goodyear Asurance Fuel Max (All-Season)
    UTQG=580 A A, 51PSI, 10/32, 17LBS, $94
    Michelin Energy Saver A/S (All-Season)
    UTQG=480 A B, 44PSI, 9/32, 18LBS, 859, $97
    Michelin HydroEdge w/GreenX (All-Season)
    UTQG=800 A B, 44PSI, 11/32, 22LBS, 867, $97
    UTQG=480 A A, 44PSI, 11/32, 17.6LBS, 858, $
    UTQG=? A B, 44PSI, 10/32, 18LBS, 859, $115 (90,000mile warranty)
    Nokian H
    UTQG=320 A A, 17.9LBS, 11/32, 858, $125
    UTQG = 440 A A, 44PSI, 10.5/32, 21.3LBS, $57.27 Onlinetires.com
    UTQG=None, 51psi, 18lbs, 859, $94
    Michelin Primacy Aplin PA3 (Performance Winter/Snow)
    UTQG= None, 51psi, 19lbs, 859, $116
    Nokian WRG2
    UTQG= 420, 17LBS, 11/32, 851
    Nokian WR D3
    Nokian WR A3
    Nokian All-Weather+
    Nokian W+
    195/65/15 (2010+ OEM tires size and alternative to correct 2004-2009 speedometer error)
    Hankook Optimo H426 (All-Season Grand Touring) * T rated tire is LRR
    UTQG=440 A A, 44PSI, 10/32, 17LBS, 830, $72
    Cooper GFE
    UTQG=540 A B, ?PSI, 10/32, ?LBS, ?? $103.99 (Big O Tires)
    Michelin HydroEdge w/ Green X (All-Season)
    UTQG=800 A B, 44psi, 11/32, 21lbs, 842, $99 (90,000mile warranty)
    Michelin Energy Saver A/S (All Season)
    UTQG=480A B, 44PSI, 9/32, 18LBS, 832, $105
    Michelin Defender w/GreenX (All-Season)
    UTQG=? A B, 44PSI, 10/32, 18LBS, 832, $107 (90,000mile warranty)
    Kumho eco Solus HM KR22 (All Season)
    UTQG= 800 A B, 44PSI, 11/32, 20LBS, 834, $77
    UTQG=700 A B, 44PSI, 11/32, 20LBS, 831, $76
    Goodyear Assurance Fuel Max (All Season)
    UTQG=580 A A, 51PSI, 10/32, 18LBS, 836, $90
    Continental ContiProContact (All Season)
    UTQG=500 AA A, 51PSI, 10/32, 835, $87
    Continental ProContact with eco Plus (All-Season)
    UQTG=600 A B, 44PSI, 11/32, 17LBS, 831, $75
    Bridgeston Ecopia EP100 (Summer Tire)
    UTQG=400 A B, 44PSI, 10/32, 19LBS, 833, $86
    Bridgestone Ecopia EP422 (All Season)
    UTQG=400 A A, 44PSI, 10/32, 18LBS, 833, $94
    UTQG=600 A A, 44PSI, 12/32, 22LBS, 833, $94
    Yokohama Avid Ascend (T) (All-Season)
    UTQG=800 A B, 44PSI, 12/32, 20LBS, 828, $87
    Yokohama dB Super E-Spec (Summer Tire)
    UTQG=460 A A, 44PSI, 10/32, 19LBS, 831, $126
    UTQG=580 A A, 51psi, 10/32, 19.8lbs, 831 $96
    Firestone Affinity Touring (All Season)
    UTQG=500 A A, 44psi, 19lbs, $90
    Nokian eNTYR (All-Season)
    UTQG=700 A A, 18.7lbs, 11/32, 831, $116 (Tiresbyweb.com)
    Nokian H
    UTQG=320 A A, 19.4LBS, 11/32, 831, $130
    UTQG = 440 A A, 44PSI, 10/32, 22.2LBS, $58.85 Onlinetires.com
    Michelin X-Ice Xi2 (Studeless Ice & Snow)
    UTQG=None, 51psi, 10/32, 19lbs, 832, $104
    Nokian WRG2
    UTQG=420, 18.7LBS, 11/32, 851, $132 (TiresbyWeb.com)
    Pirelli Winter 210 Snowcontrol Series II
    UTQG=None, 44psi, 11/32, 20lbs,
    Nokian WR D3
    Nokian WR A3
    Nokian All-Weather+
    Nokian W+
    195/55/16 (2004-2009 Touring OEM tire size)
    Continental ProContact (Grand Touring All-Season)
    UTQG= 540 A A, 51psi, 10.5/32, 18lbs, 851, $103
    Bridgestone Turanza EL470 (All Season)
    UTQG= 260 A A, 51psi, 18lbs, $139
    Bridgestone Turanza EL400-02 (Touring All-Season)
    UTQG= 260 A A, 51psi, 9/32, 19lbs, 854, $118
    Bridgestone Ecopia EP100 (Grand Touring Summer)
    UTQG= 400 A B, 51psi, 10/32, 19lbs, 857, $96
    UTQG= 400 A A, 51psi, 10/32, 19lbs, 853, $100
    Yokohama dB Super E-Spec (Grand Touring Summer)
    UTQG= 460 A A, 44psi, 10/32, 19lbs, 850, $155
    16" Studless Ice & Snow
    Michelin X-Ice Xi2 (Studeless ice & snow)
    UTGQ= None, 50psi, 10/32, 21lbs, 852, $133
    Nokian WRG2
    UTQG=420, 44PSI, 11/32, 18.7LBS, 851,
    Nokian WR D3
    205/60/16 (OEM Prius v Wagon)
    UTQG=600 A A, 51PSI, 12/32, 24LBS, 812, $113
    UTQG=820 A B, 44PSI, 10/32, 21LBS, 810, $131 (90,000mile warranty)
    UTQG=480 A A, 51PSI, 9.5/32, 21LBS, 810, $148
    Yokohama Avid Ascend (H) (Grand Touring All-Season)
    UTQG=800 A B, ?PSI, 12/32, 22LBS, 808, $109
    Yokohama BluEarth S34 (Grand Touring All-Season) oem tire
    UTQG=320 B A, 51PSI, ? , 22LBS, ? , $148
    UTQG=580 A A, 51psi, 11/32, 20.7lbs, 809 $
    Nokian eNTYRE (All-Season)
    UTQG=700 A A, 11/32, 21.2, 809, $
    205/50/17 (A 17" alternative to correct 2004-2009 speedometer error)
    UTQG=560 A A, 11/32, 20.5lbs, 827, $
    Continental PureContact with EcoPlus (Grand Touring All-Season)
    UTQG=700 AA A, 51psi, 10/32, 22lbs, ?, $138
    UTQG=500A A, 50psi, 10/32, 24lbs, $126
    UTQG=480, A A, 50PSI, 10/32, 22lbs, 829, $153
    UTQG=600 A A, 50PSI, 12/32, 25LBS, 829, $139
    Yokohama AVID Ascend (V) (Grand Touring All-Season)
    UTQG=740 A A, 50psi, 12/32, 24lbs, 829, $152
    UTQG=580 A A, 50psi, 11/32, 24.1lbs, 826 $
    17" Studless Ice & Snow
    UTGQ= None, 50psi, 10/32, 22lbs, 828, $145
    Michelin Primacy Alpin PA3
    UTQG=None, 51psi, 10/32, 20lbs, 828, $161
    Nokian WR A3
    215/45/17 (2010+ Prius Five OEM size)
    Hankook Optimo H426 (All-Season Grand Touring) H rated tire is LRR
    UTQG=440 A A, 44PSI, 10/32, 20LBS, $119
    UTQG=400AA A, 51psi, 10/32, 21lbs 839, $136
    Hankook Optimo H426 (Grand Touring All-Season)
    UTQG=440A A 44psi, 10/32, 20lbs, $118
    Michelin Primacy MXM4 (Grand Touring All-Season)
    UTQG=500 AA A, 51psi, 10/32, 21lbs, 844, Rim Protection, $132
    Bridgestone Ecopia EP100 (Summer Tire)
    UTQG=400 A A, 51PSI, 11/32, 20LBS, 845, $194
    UTQG=480, A A, 51PSI, 10/32, 21lbs, 845, $162
    UTQG=580 A A, 51psi, 11/32, 23.3lbs, 844, $
    Yokohama Avid ENVigor
    UTQG=560 A A, 51psi, 11/32, 23.5lbs, 844
    Michelin X-Ice Xi2 w/GreenX
    UTQG=None, 51psi, 10/32, 23lbs, 844, $148
    Michelin Primacy Alpin PA3 w/GreenX
    UTQG=None, 51psi,10/32, 21lbs, 846, $173
    Nokian WRG2
    UTQG=400 A A, 21.8lbs, 11/32, 843, $215 (TiresbyWeb.com)
    Nokian WR A3
    215/50/17 (2012+ Prius v Five OEM Size)
    Michelin Energy Saver A/S (Passenger All-Season)
    UTQG=480 A A, 44PSI?, 9/32, 22lbs, 815, $144
    Bridgestone Ecopia EP422 (Grand Touring All-Season)
    UTQG=480 A A, 51PSI, 10/32, 22LBS, 817, $149
    UTQG=600 A A, 50PSI, 12/32, 26LBS, 817, $144
    UTQG=400 AA A, 51PSI, 10/32, 20LBS, 818, $139
    UTQG=500 AA A, 50PSI, 10/32, 23LBS, 815, $161
    Pirelli P6 Four Seasons Plus (Grand Touring All-Season)
    UTQG=500 A A, 51PSI, 10/32, 22LBS, ? , $143
    UTQG=740 A A, 51PSI, 12/32, 26LBS, 814, $131
    UTQG=580 A A, 50psi, 11/32, 25.2lbs, 813 $
    UTQG=580 AA A, 50PSI, ? , 22LBS, ? , $142
    UTQG=560 A A, 11/32, 22lbs, 814, $
    UTQG=None, 50psi,10.5/32, 24lbs, 816, $141
    225/40/18 (best size for 2010 Prius)
    Continental ContiTouringContact CW95
    UTQG=360 A A, 51psi, 23lbs, 10/32, 827, $195
    Continental ExtremeContact DWS (non-LRR tire but a great tire)
    UTQG=540A A, 51psi, 21lbs, 10/32, 825, $142
    UTQG=580 A A, 50psi, 11/32, 24.7lbs, 827 $
    18" Studless Ice & Snow
    UTQG=None, 50psi,10.5/32, 21lbs, 829, $218
    UTQG=None, 50psi,10.5/32, 23lbs, 829, $177
    Nokian WR A3
    235/40/18
    Michelin Primacy MXM4 (All-Season)
    UTQG=500 A A, 51psi, 9/32, 22lbs, 819, $155
    UTQG=500 AA A, 50PSI, 12/32, 25LBS, 820, $229
    Pireli P6 Four Seasons (All-Season)
    UTQG=400 A A, 50psi, 11/32, 23lbs, 818, $162
    UTQG=580 A A, 50psi, 11/32, 26lbs, 818 $
    Nokian WR A3
    Prius v (Wagon) Tire Selection: (Thanks to dhanson865)
    My list isn't purely LRR and it's sorted by rim then RPM sizes not xxx/xx/ sizes but here it is:
    Prius v (Wagon) OEM tire RPM and speedometer accuracy
    OEM 16" #1 811 205/60/16 Bridgestone Turanza EL400-02
    OEM 16" #2 8?? 205/60/16 Yokohama BluEarth S34
    OEM 16" #3 810 205/60/16 Michelin Energy Saver A/S
    OEM 17" #1 8?? 215/50/17 Toyo Proxes A20
    I don't have accuracy data yet so I'm listing tires in the range of 795 to 825 RPM until we have data.
    v (Wagon) ~810 RPM 15" Tires
    823 215/55/15 Michelin Primacy MXM4 with Green X
    822 205/65/15 Michelin Hydroedge with Green X
    821 205/65/15 Goodyear Assurance Fuel Max
    820 205/65/15 Goodyear Assurance ComforTred Touring
    818 205/65/15 Continental ContiProContact (Grand Touring All-Season)
    818 205/65/15 Kumho Solus HM KR22
    816 205/65/15 Hankook Optimo H727
    815 205/65/15 Yokohama AVID ENVigor
    806 215/65/15 Michelin Hydroedge with Green X
    797 205/70/15 Michelin Hydroedge with Green X
    79x 205/70/15 Goodyear Assurance Fuel Max (maybe 795 RPM?)
    v (Wagon) ~810 RPM 16" Tires
    824 215/55/16 Continental ExtremeContact DWS (Ultra High Performance All-Season)
    824 215/55/16 Continental ContiProContact (Grand Touring All-Season)
    823 215/55/16 Michelin Pilot Sport A/S Plus (Ultra High Performance All-Season)
    820 215/55/16 Yokohama AVID ENVigor
    808 205/60/15 Yokohama Avid Ascend (All-Season)
    814 205/60/16 Goodyear Assurance ComforTred Touring
    814 205/60/16 Goodyear Assurance Fuel Max
    812 205/60/16 Bridgestone Ecopia EP422
    811 205/60/16 Continental ContiProContact (Grand Touring All-Season)
    811 205/60/16 Kumho Solus HM KR22
    810 205/60/16 Yokohama AVID ENVigor
    808 205/60/16 Continental ProContact with EcoPlus Technology (Standard Touring All-Season)
    807 205/60/16 Hankook Optimo H727
    800 215/60/16 Michelin Hydroedge with Green X
    800 215/60/16 Goodyear Assurance Fuel Max
    797 215/60/16 Michelin Primacy MXV4 with Green X (make sure it's marked Green X)
    797 215/60/16 Bridgestone Ecopia EP422
    797 215/60/16 Continental ContiProContact (Grand Touring All-Season)
    796 215/60/16 Michelin Energy Saver A/S
    790 205/65/16 Goodyear Assurance Fuel Max
    v (Wagon) ~810 RPM 17" Tires
    825 205/50/17 Continental ExtremeContact DWS (Ultra High Performance All-Season)
    818 215/50/17 Continental ContiProContact (Grand Touring All-Season)
    817 215/50/17 Bridgestone Ecopia EP422
    815 215/50/17 Michelin Primacy MXM4 with Green X
    815 215/50/17 Yokohama AVID ENVigor
    807 225/50/17 Goodyear Assurance Fuel Max
    805 225/50/17 Continental ContiProContact (Grand Touring All-Season)
    803 225/50/17 Michelin Energy Saver A/S
    803 225/50/17 Michelin Primacy MXM4 with Green X
    803 225/50/17 Michelin Pilot Sport A/S Plus (Ultra High Performance All-Season)
    795 215/55/17 Goodyear Assurance Fuel Max
    RR is going to be all over the board with the varying widths and the occasional non LRR tire in the mix.
    Be careful if you are considering a Michelin Primacy MXV4 that it actually has the Green X logo on the sidewall if you care about LRR. Not all Primacy MXV4 tires are LRR.
    #1 F8L, Apr 17, 2011
    Eric SJ, sadie72, Gnarly and 64 others like this.
  2. Thai
    Thai Prius Neophyte
    1,197
    89
  3. bisco
    51,840
    this is excellent. thanks justin, hope you feel better man!;)
    pleasedpriusowner and F8L like this.
  4. Mendel Leisk
    41,310
    An addition for 215/45/17 category:
    Michelin Pilot HX MXM4 (Grand Touring All-Season)
    300 AA A, 44psi, 11/32, 21lbs, 844 $230
    These are the stock tire we got. FWIW, the Michelin Primacy is high on my replacement list. Interesting, the Pilot price at TireRack has the comment "closeout".
    BTW, I really like TireRack's option to pick your vehicle, and then only show LRR choices.
    Also, I think they should have some LRR index as published knowledge: LRR is not a simple yes/no. There's a wide gamut within the group.
  5. Thai
    Thai Prius Neophyte
    1,197
    89
    According to my Discount dealer, Primacy is the replacement of the Pilot HX.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Members have lauded a Nokian and Hankook (sorry, I'll have to track down specifics) for performance *and* fuel economy. Is LRR only part of the story for fuel economy ? I cannot guess what other variable is at play here. Maybe tyre weight ?
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks for the additions. There are more tires available. I'll be sure to add them.
    I'll also look for 18+ tires as well.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    I agree with you. There are indeed other factors which si why I added weight and revs per mile. Until manufactures start listing exact numbers for LRR these are about the only factors we can compare. I also added the warranty for some tires because even if they have a slightly higher rolling resistance, they could still be more affordable in the long run if they last say 100,000 miles vs. a tire warrantied for 50,000 miles. :)
  9. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
  10. Thai
    Thai Prius Neophyte
    1,197
    89
    Wow, great sounding tire...but not avail in Prius 17" size. :( Hopefully, they will have more tire size avail in the future.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    The Kumho tire has an even higher rating and its much cheaper. I wonder how much longer it would last vs. the fuel saved. One factor that favors the Nokian is that it is a greener tire and is manufactured in a carbon neutral plant much like the dB Super E-Spec. So for those interested in an eco-friendly tire, those would be good choices.
  12. jamesa53
    jamesa53 New Member
    74
    Indiana
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
  14. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Primacy MXV4 is listed as having Greenx on the Michelin site:
    Primacy MXV4 | Michelin Tires
    These are what I ordered since Energy Saver A/S have been unavailable and these tires are getting really good reviews and my Yokos have 39k on them...way overdue.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    If I don't have them listed I'll add them. Thanks! :)
  16. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Maybe you should create a google document or something to keep updated with the changes? I think a spreadsheet would work well for this information, actually.
    Clearly, things will continue to change, and you could even share the google document (I believe) and allow others to add additional items or even remove those which have become discontinued.
    I think this is definitely good to have. Too bad we can't get a rating of sorts from PC members to give an idea of how they like the tires and any comments during the course of their ownership.
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    I like the idea. It could then be shared between forums or list servers as well. I'll talk to Tony about it. He is pretty good with this sort of thing. Then I wouldn't have to update the page in both the GenII and GenIII section. :)
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Walmart sells a rebranded version of the Goodyear Assurance Fuel Max as the Goodyear Viva Authority Fuel Max in 185 65 15
    My mileage is better than the Integrities
  19. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    What happened to the Yokahamma 338 tires that came as orginal equipment on 2010 Prius? Are they discontinued already? From what I can gather on Yokahamma's web site, it sounds like the Envigor is the LRR tire now, is that correct?
  20. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    They were Avid S33s
    Just looked at the Envigor and it has the same tread pattern as the S33, did notice the tread rating is now 560 instead of 320 so it should be a much better tire.
    My only complaint is quick wear and hydroplaning, which is odd with the tread style.
