Engine, fuel system cleaning?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by justslappy, Apr 18, 2011.
  1. justslappy
    justslappy Junior Member
    29
    north carolina
    Took car in for 30,000 mile inspection and was asked if I wanted top engine cleaning ($70) and fuel system cleaning ($70). Are these needed? Thanks!
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    NO Toyota has all recomended services in the manual. These are not in their they are money makers for the dealer.
  3. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    Sounds like the Service Department is trying to clean out your wallet.
    Keith
    douglasjre likes this.
  4. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    ^^ A clean wallet is a lighter wallet, which should improve MPGs by weight reduction. Simple as that. See, the dealer really has your best interest in mind.
  5. mickey513
    mickey513 Member
    127
    Cali
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    Not needed. :)
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    By as much as 3.14% I hear.
  9. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I've never use fuel additatives, nor fuel cleaners and do not intend to; but I do use windshield washer cleaner. :)
  10. dinger_greg
    dinger_greg New Member
    86
    Brookfield, WI
    Not needed. The dealer is trying to add on to their sale.
  11. stereos
    stereos Junior Member
    Idaho Falls
  12. almypal26
    almypal26 Member
    101
    So Cal
    :eek:My service advisor stated the "mechanic" suggested the throttle body needed cleaning. I said no thanks.
  13. viclavigne
    viclavigne New Member
    76
    Georgia
    Actually, throttle body cleaning is likely to do some good, although maybe not measurably good. Lots of engine cleaning that can be done that improves things, although you may not see immediate improvement: MAF sensor cleaning, throttle body cleaning, and fuel injector cleaning. My usual plan for my cars has been to do MAF sensor cleaning about every 15k miles, and the throttle body cleaning about the same time (but only as DIY projects). I run a good quality PEA fuel system cleaner about every 5k miles.
    The fact that Toyota doesn't specify such things in its service guidelines doesn't mean that it can't help. DIY is much cheaper than the dealer would charge. Of course, I've also known some mechanics whose philsophy is to wait until it breaks, and then fix it. I just never liked that idea.
    Vic
  14. justslappy
    29
    north carolina
    Thanks for the great feedback. No liquid cleaners for me, at least not on a one-year-old car. Was suspicious of the dealer offer. Didn't know the right answer but knew a place where I could find out -- PriusChat!
  15. justslappy
    29
    north carolina
    How do you (or I) clean the sensor? Is this a simple process or something I request of the mechanic? Also, what do you use to clean the throttle body and fuel injector? thanks
  16. justslappy
    29
    north carolina
  17. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Hello, just curious. How much did the dealer charge for the 30K mile service? What did it include? Mine just crossed 30K. Thanks.
  18. frayz
    frayz Junior Member
    33
    Mobile, Al
    anyone use that stabil ethanol treament? I started using it in my bike and see a boost in performance. I see some peopel claim a boost in MPG..
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Track your gas mileage and pay attention to how you car runs. If there is no deterioration in either, fuel system cleanings are money flushed down the toilet.
  20. justslappy
    29
    north carolina
    Srivenkat, the 30k checkup was $99, but I didn't need an oil change with it. I was expecting a much higher bill. I think it was mostly "inspections," with just $25 for parts and the rest labor.
