adding foot lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Alexma, Apr 18, 2011.
  1. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Has anyone tried to install foot lights to a prius that does not have it factory installed?
    I would like to do this if it is not too complicated.
    I'm assuming the wiring is already there and we only need to add the connectors, bulb, and harness.
    If it were only that simple.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You would probably have to tap into the harness at the ECUs or possibly tap into the wires running to say the current door foot lights. I have been thinking about doing this myself since I have an extra pair of LED bulbs.
  3. 2ZR JDM
    2ZR JDM Active Member
    106
    142
    Redondo Beach
    It would probably be easier to tap to the parking lights instead of tapping to the ECU
  4. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    I think the 4's and 5's come stock with footlights.
    I'm sure there some type of connection already there, so we would not have to "tap" or "slice" into any wiring.
    Anyone poke their head up in there to have a look???
    From the looks of it, there are already "holes" for the lamp bases on the plastic covers under there.
    I just don't have access to a gen 3 that already has them installed. This would be the easiest way to compare.
    I tried looking on the parts diagrams , but have not been able to find what I am looking for.
    I'm probably just not looking in the right place............;)
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    Yep - check out my mod from last summer (click below). Keep in mind these footwell lights are only for the front passenger and driver - and they only go on based on the door being opened. They cannot be turned on while driving or with the dome light control.
  7. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Phoenixgregg-does it auto dim like the oem ones?
  8. phoenixgreg
    1,157
    294
    66
    Phoenix
    They go on and off just like the courtesy lights in the door. In fact, they are on the same circuit.
  9. andino
    andino Senior Member
    746
    551
    San Jose, CA
    I was going to say, you can just tap the dome light wire and it'll go on an off with them. I wired my friends to a 12v source and then added a switch so he could turn them on and off as he pleased.
  10. phoenixgreg
    1,157
    294
    66
    Phoenix
    Is the switched dome light wire in each side kick panel (as shown in my mod)? If so, it would be a simple matter to change the wire tap to the switched wire and wala! Both footwell lights would come on with any door opened and behave just like the dome light. A "nice to have", but not a "have to have".
  11. andino
    746
    551
    San Jose, CA
    ^^ I think you'd need a relay since you need a 12v constant source if you wanted to turn them off while the dome lights were off and still have them light up and dim with the dome light.
