Help! Trying hard to remove the rear left/right side wing..
Discussion in 'Gen 3 Prius Accessories and Modifications' started by us_matrix, Apr 27, 2011.
  1. us_matrix
    us_matrix Member
    110
    I was having hard time to remove the rear seat left/right side wing. I tried but no success and did not want to damge what behind. Anyone got the instruction of how to remove it?
    Thanks.
  2. CivicSky
    CivicSky Member
    169
    71
    San Deigo
    I removed the B-pillar seat belt cover, I pulled down the weather seal around the front door frame first. Maybe you can try to do the same on the rear door frame started from the B-pillar edge.
  3. longhaul
    longhaul Junior Member
    25
    montgomery, il
  4. longhaul
    25
    montgomery, il
    Get a good grip on the bottom of the wing & slide it up. There are two clips built into the back of the wing one on top part & one on the bottom of part & they slide into part of the rear seat framing. Hope this helps. Longhaul
  5. EthanC
    EthanC Junior Member
    17
    SF bay
    Beside all the above, my V has a screw in the bottom of that piece. Yo need to remove that first.
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Remove the plastic piece on the carpet by the rear door. Push down the rear seat cushion by the "wings" there's a bolt I believe 10mm or 12mm that hold the "winds" down that you have to remove. Once removed, pull out the weather stripping like in CivicSky's pict, slide the "wings" straight up.
