Xgauge code Ambient temp in Fahrenheit?
Discussion in 'Gen 2 Prius Technical Discussion' started by Nortnarg, Apr 30, 2011.
  1. Nortnarg
    Nortnarg Prius~To go before
    83
    Blue Springs, Missouri
    Is there an Xgauge code for Ambient temp in Fahrenheit?
    I have the code for Celsius, but my brain don't work in Celcius.
  2. RRxing
    RRxing Senior Member
    2,553
    1,825
    NEPA
    Ambient Air Temperature (F)
    TXD 07DF0146
    RXF 04410546
    RXD 2808
    MTH 00090005FFD8
    NAM AIR
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Curious why you'd really need it? There's an ambient temp display on the MFD. I personally would like to be able to display >4 values at a time and don't need one of them being taken up by the OAT.
  4. Nortnarg
    83
    Thank you RR, I will plug that in.
    cwerdna, I guess it is a "because I can" thing.
    What I would really like is an X gauge for cabin temperature. You know the car has a sensor for that to regulate the auto A/C, but no info for the driver.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    IIRC, SG has multiply and divide fields you can use for unit conversions.
    F = 9C/5 + 32
    I cannot remember how you add the 32
  6. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    The ranges of C are from -40°C to 215°C. A byte can be from 00h to FFh so it must has an offset of 40.
    C' = C - 40
    F = 9C/5 + 32
    F = 9C'/5 + 32
    F = 9(C-40)/5 + 32
    F = 9C/5 - 72 + 32
    F = 9C/5 - 40
    -40 convert to hex. is FFD8 (2's complement).
  7. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    30's hot, 20's nice, 10's cold, Zero is ice. Celsius, a commonly used temperature measurement in the US system of measurement (SI) is based on units of 10. You probably use $US money, use a computer, listen to CDs and watch DVDs. Printer paper if 18 X 22 cm. Don't convert, it messes your brain up, just learn SI system of measurement.
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You just did .... incorrectly.:D
    I also question the judgement of someone from Fresno that calls 30C hot.:cheer2:
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    Skruse takes all his temp readings in 90%+ humidity ;)
