How do the brakes work when car is stationary?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by WRJ, May 2, 2011.
  1. WRJ
    WRJ New Member
    Norway
    I am in the process of changing my wheels – from winter to summer on my Prius III (4 disk brakes). As far as I understand are the rear wheels locked by the foot-brake. However I am not able to brake/ lock the front wheels. In fact I could turn them easily by hand when I was changing the front wheels. Naturally I don't feel comfortable jacking up the car at the rear to change the rear wheels. I have tried many possible combinations of pressing the “P†button & foot brake & brake pedal to no avail.
    Any ideas of what I am doing wrong?
    WRJ
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The front wheels turn when you are in park? There should only be a little bit of play in the front wheels. You won't be able to eliminate that completely. Block the wheels with a piece of wood or tire chocks.
    Welcome aboard by the way!
  3. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I always change wheels one side at a time, not the front and then the backs.
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Why don't you brake the lugs lose while the car is on the ground then jack it up and you wont have to worry about the wheels turning when you finish taking the lugs off?
    And lower the car back to the ground before you fully tighten the lugs. This prevents pressure on the drivetrain, and stress on the jacks that if not stable could fall if you are pulling really hard the the tire iron.
  5. fuzzy1
    10,335
    No wheel chocks?
    I never jack up any vehicle without blocking a wheel on the opposite side.
  6. macman408
    1,179
    367
    I've only had to rotate my tires once, but discovered this too - the ability of the front wheels to move like this is due to the differential. So the car is in park and the front wheels can't move forward or backward together, but they can move in opposite directions at the same speed thanks to the differential. I had my SO stick her foot on the brake pedal for a few seconds while I loosened all the lug nuts, since I didn't want to drop one side of the car back down off the jack stands. You can also loosen the lug nuts on the ground, as has been mentioned. That's probably what I'll do next time, assuming I remember.
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    +1 I've always done it this way!
  8. WRJ
    WRJ New Member
    Norway
    I didn't think about the differential... It makes sense that you can turn wheels individually but not together. My concern was not that I couldn't loosen the nuts wheel the back of the car was jacked up. I was worried about the car becoming unstable as the two (front) wheels on the ground appeared to be "spinning freely". Thanks for all the comments!
    WRJ
