Scots windfarms paid cash to stop producing energy
Discussion in 'Environmental Discussion' started by qbee42, May 1, 2011.
  1. qbee42
    3,079
    BBC News - Scots windfarms paid cash to stop producing energy
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Anybody doubt the coal plants kept on spewing ?
  3. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
  4. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    From what I gather, colorado suffers from this too. We have > 800 MW of wind up in the NE part of the state. If the wind picks up and those things are cranking, operators have to spin down other plants, and/or, shut down wind turbines.
  5. richard schumacher
    7,664
    1,046
    United States
    Yep. No good generating power if it can't be distributed.
  6. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    It reveal an upcoming problem with solar and wind. We must develop high capacity energy storage systems. The interesting part is that the storage systems do not have to be located at the plant, although in many case it makes sense to do so. The fuel may be free, but it does not dispatch on the schedule that matches our demand.
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Well, energy storage will be necessary for the long term, but more fundamental is having a grid capable of distributing the energy effectively. Effective distribution mean less storage being required due to flattening variations. Some places like Texas have been improving their grids and are quite good at distributing the wind energy. Kansas, on the other hand, dominated by coal, has plenty of potential for wind power but due to a poor infrastructure can't distribute that power.
    People with memories may remember part of Obama's campaign was the creation of a "smart grid". The first part is to create a "national grid" rather than the current lose connection of old infrastructure . It's currently stalled by state protectionism and fighting over payment. There's probably other crap like cronyism and lobbying in the mix too.
    2 people like this.
  8. qbee42
    3,079
    The second step is to design a giant penny that will fit into those big fuse boxes at substations.
  9. austingreen
    austingreen Senior Member
    13,677
    4,214
    Austin, TX, USA
    How about a bunch of BEV and PHEV vehicles on the grid ready to charge when power surges off peak. On peak shutting off gas power plants works fine. Research into storing the power in hydrogen and fuel cells on the grid. This also means as we add more wind, we need to remove old coal plants that can not be easily started and stopped. I would say this is a good thing. Kill the grandfathering of these under the clean air act and the problem will take care of itself.
    Yes having a modern grid is key, as is the ability to remove old coal.
    I"m not sure whether this needs to be "national". One problem is states argue about upgrades and costs. We do need the federal government to tell the bad acting states that coal is not the future and the grid needs to be updated. It will take political will, instead of pandering to coal interests.
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I seem to remember a solution for this that I read about a while ago and it was old tech then. Some sort of liquid battery tank storage systems. High energy density perfect for storing charge, and they need to be big, so perfect for big systems.
    Or we can go low tech, and just use the excess to pump water upstream over hydro below it.
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    this is typical. like the Pacific Northwest when we have excess hydro power which is essentially every night, we sell to other areas, but even that is not done efficiently.
    so water gets pumped into a holding pond, or held back as much as possible while other areas of the country are starved for the power we cant hold or use.
    all i know is the person that invents a cost effective, semi efficient method of large charge storage will rule the world.
  12. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Sun Catalytix :: Home
  13. tripp
    4,717
    79
    Denver, CO
    You've gotta have enough head for pumped storage to work. It's fine in some areas, not very useful in others (like FL for example).
  14. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The simple solution is to convert it into hydrogen.
  15. Rstaton
    Rstaton New Member
    60
    Watsonville, CA
    From what I've read, making hydrogen is problematic because hydrolyzers are expensive and/or inefficient.
    On the other hand, high voltage DC power transmission is supposed to be good for long distance power transmission. This can send energy from intermittent renewable sources to where it's needed.
    For example, a massive solar farm in Arizona could send power to California (or Texas) with very low loss, supporting the electric grid right when people are running air conditioners.
  16. richard schumacher
    7,664
    1,046
    United States
    A big redundant grid really is the best feasible solution. All existing storage methods are either inefficient or very expensive. Pumping is good but there are very few places naturally suited to it, especially any that are close both to sources and consumers, so you need the distribution system anyway.
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yawn.
    Make peak power expensive, and consumers will time-shift their use.
    I am so sick of every problem being something the 'gubmint' has to fix.
  18. icarus
    icarus Senior Member
    4,884
    976
    earth
    In the US, plug in 15,000,000 EVs into the grid, with the ability to both buy and sell to the grid, evening out peak loads, and presto, you have your battery storage.
    We buy ~15 million cars per year on average. If 10 % were EVs, in ten years we would have 15 million.
    Design and build a smart grid that uses electricity more efficiently.
    Icarus
  19. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    How come nobody has built a silo sized capacitor? ;)
  20. icarus
    4,884
    976
    earth
    Hydro is essentially a "storage"solution. Don't drop it through the dam until needed, pump excess back up. Not 100% efficient, but better than wasting idle spying capacity.
    Icarus
