considering Eibach Pro Springs - but, what to consider?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pjam, May 3, 2011.
  1. pjam
    pjam New Member
    31
    Nashville
    I'm looking to both upgrade the factory 15" wheels to probably 17" and perhaps put on some stiffer springs to improve the handling and tracking of my Gen III Prius III. I'm actually impressed by what the car will do on the factory springs and stock 195/65/15 Yokos, but that is by 1990 standards.
    I hesitate to use the car as our roadtrip car due to higher-than-average wandering when crosswinds blow, etc. I just believe it'd have a more substantial feel, better handling/braking, etc. with these upgrades.
    However, I do not want to make the car more susceptible to damage. I've never lowered a car and the Eibach's seem to have a minimal amount of lowering, but is the car already quite low and even this 1.2"/0.8" of drop put me into a whole other world of issues?
    Thanks,
    PJ
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    That 1" front, 1 1/2" rear, drop is going to require different shocks, I put the Eibach's on an Audi I had and the increase in control was incredible, before them the car would bounce from left front to right rear it shuddered, after, with the proper shocks the car would lean over a tiny bit(in a sharp turn), grip and go.
    I suggest you hunt up an upper front shock strut bar, and increase the diameter of the lower rear sway bar.
    I run 17"(45 series) summers and just switched from Michelin P2's to Hancook V12 EVO's and love them, silent, 1/3rd the price;)
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    if you have reservations about lowering, how about getting rear anti-sway bar and strut brace?
    they will address your concerns while maintaining stock height.
  4. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Not true. They're designed with stock shocks in mind. Several of us are using stock shocks. Now, it is recommended that you upgrade your shocks to something like Bilsteins (does Bilstein even make Prius shocks though) at the same time you put on the springs, because the installation is the same.
  5. ocblackpriusii
    ocblackpriusii Junior Member
    56
    OC/So Cal
    I would not be too concerned. I have a set of Eibach's on order and can not wait to get them installed.
  6. wstevensiv
    wstevensiv New Member
    84
    Little Rock
    so should we expect to have to change out our struts prematurely if we have installed eibachs?
  7. macmaster05
    4,050
    730
    As long as you don't drive hard and take corners like a maniac, you shouldn't expect premature damage. As long as you have good driving habits and keep driving the same way, the life of your struts shouldn't be affected.
  8. wstevensiv
    84
    Little Rock
    :cheer2:
  9. andino
    andino Senior Member
    746
    551
    San Jose, CA
    Eibach drop isn't enough to really have to worry about scraping. Even htechs don't drop you to the point of where its a problem. I'd look into a rear sway and strut bar too. It'll help the loose steering sensation.
