106 mpg Enginer 4kw kit
Discussion in 'Prius PHEV Plug-In Modifications' started by stefano5777, May 4, 2011.
  1. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    I just had my Enginer 4k kit installed and had a 45 mile drive back to my house 80% of drive was at 55 mph 5 % at 40 mph and 15% at 35 or less and avg 106 mpg with my scangauge II!! As you can tell I am happy with my first taste of the Phev conversion and believe I can do even better with my normal daily commute.:thumb::thumb:
    51,781
    wow! all i can say is, wow!
  3. stefano5777
    stefano5777 Member
    380
    47
    Thanks bisco I will second that!! WOW:D
  4. mrbigh
    3,686
    699
    Long Island, NY
    And you can improve those numbers.......
  5. govind1
    govind1 New Member
    St Louis
    I am considering enginer for my 2004 prius do u recommend it?
  6. stefano5777
    stefano5777 Member
    380
    47
    So far I would say if you are in the market for a cheap kit and are willing to do a little troubleshooting then definitely. If you are looking for a 100% plug and play kit this is not the one. Also want to say my avg for today has been 118 mpg over 37 miles.
  7. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    report back when you've completed one full tank. if you're talking about daily trip. 106mpg is really not that impressive. my personal best in a single day drive is 195mpg for 35 miles. it took 2 charges.
  8. stefano5777
    stefano5777 Member
    380
    47
    106mpg drive was straight driving from installers shop to my house on 1 charge.
  9. bisco
    51,781
    how many kw's does it take to charge her up from zero?
  10. mynameisjim
    mynameisjim Junior Member
    4kw system plus any charging losses
  11. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Hopefully you never go over 80% depth of discharge. Your battery life will deteriorate pretty bad if you are able to use the full 4kw.
  12. 2 fas 4 u
    2 fas 4 u Active Member
    320
    353
    florida
    How much was kit, How much to install, How long did it take.
  13. stefano5777
    stefano5777 Member
    380
    47
    The kit cost me 3195.00 installed and it took them 6 1/2 hours from when I dropped it off till they called me to tell me it was complete.
    PHEV Conversions
    New Port Richey, Florida 34654
    Phone: 727-940-9046
    Email: [email protected]
    Website: www.phevconversion.us
    Bill is who did it
  14. PriusDIY
    PriusDIY Junior Member
    49
    Minneapolis, MN
    I'm just starting to look into this kit but the only shop that installs them around here charges $4995 + sales tax. However, they customize the kit for Minnesota winters...adding insulation and a heating unit. For $3200 I wouldn't even hesitate!!
  15. stefano5777
    stefano5777 Member
    380
    47
    If you know how to or are willing to self install they are selling kit on ebay for 2995 + 200 shipping.
  16. stefano5777
    stefano5777 Member
    380
    47
    Further update I have put 202 miles on car since installing kit. I have avg 101 mpg's but those numbers are slightly skewed. Had to make a road trip the other day and ran kit dry and only avg 56 mpg in rain remainder of trip.
  17. bisco
    51,781
    so, at .10/kw you're talking .40-.50 to charge er up? that's excellent!
  18. stefano5777
    stefano5777 Member
    380
    47
    have not calculated energy loss in charging but the other day i got a full charge from 15% soc and my kila watt said it cost me .65 to charge. Fp&L charges us .12 a kw here in Pinellas county.
  19. 2 fas 4 u
    320
    353
    florida
    Trying to figure out if it is worth me buying, maybe u could help. Kit at 3125, since im already getting 45- 50 on lets say 8 gallons at around 400 miles. How much are u paying to get a full charge and how far can u go. I heard it cost about a 1 dollar per lets say 25 miles, if thats the case since u are out 3125 How long will it take to make it back.
  20. stefano5777
    stefano5777 Member
    380
    47
    There are a lot of variables to the question with work I do and amount of miles I drive I figure 2 to 2 1/2 years if gas was 3.50 a gallon but again Fuel cost miles you drive etc... plus I pay roughly .65 cents to fill up and in mix driving get 45 miles before needing a recharge and my work allows me to recharge for free:D
