Help the new guy....Wheel fitment?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Blueranger, May 6, 2011.
  1. Blueranger
    Blueranger Junior Member
    25
    Albuquerque
    Need to know if I ordered the right size wheel... My concern is any rubbing or possible issues....
    Front: 18x8 offset 47
    Rear: 18x8 offset 35
    Prius 3 stock suspension
    Thank you... I appreciate any input :)
  2. Blueranger
    25
    Albuquerque
  3. macmaster05
    macmaster05 Senor Member
    4,050
    730
  4. Blueranger
    25
    Albuquerque
    I also want some Eibach Springs but I want to make sure I got the right size wheel since I can't return once they mount :(
  5. macmaster05
    4,050
    730
    Well then assuming all the timing could work out for you, I would install the springs before you touch the wheels, and then you could fit the wheels and return them if necessary. That eliminates some of the guess work.
    Or if you're absolutely sure you want these rims, you can lower your Prius on coilovers later and adjust the height as needed.
  6. murasaki
    murasaki New Member
    93
    oc
    I'm running 18x8+30 all around with a 5mm spacer in the rear.no problems
    SGH-T959V ?
  7. Blueranger
    25
    Albuquerque
    Is yours lowered.... If so how much?
  8. murasaki
    murasaki New Member
    93
    oc
    Df210
    SGH-T959V ?
  9. Blueranger
    25
    Albuquerque
    This wheel is also available in 17x7.5 any thoughts on this size and offset recommendations for front and rear?
    Thanks!
  10. randydid
    randydid New Member
    27
    Albuquerque
    Hello Blueranger. I have 225/40 R18's with a +35 offset and Eibach springs. I DO rub a lot in the front! Currently trying to find a +45 or better to see if this helps, the rubbing is not constant but sounds bad when it does and is more frequent when others are in the car with me. where in NM are you? I am in ABQ.
  11. Blueranger
    25
    Albuquerque
    Hey Randydid, I am in ABQ... Thanks for your reply, maybe the +47 offset I ordered for the front will be safe enough not to rub?
    Did you feel the car sluggish after the 18" wheel upgrade?
  12. Blueranger
    25
    Albuquerque
    Here is why I felt the 17" did not fill the wheel well that good... It just looks small to me even though I thought the 17" wheel with the 45 series tire would give a smoother ride.
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    An 18" wheel is not going to fit the wheel well either unless your change the overall diameter of your combo. The car just needs to be lowered to reduce the gap. The Geniii does look better with 18s though. :) I'd rather have 18s on my genii.
  14. randydid
    randydid New Member
    27
    Albuquerque
    Looks sharp. Glad your car is not Barcelona Red though....
    :D
    If I see you in the Q, I will flag you down.
    /randy
  15. Blueranger
    25
    Albuquerque
    Sounds good Randy I will do the same.
