Enginer PHEV Test Pilots: Mpg reports and important data
Discussion in 'Prius PHEV Plug-In Modifications' started by plugmein2, Aug 17, 2009.
  1. kammssss
    kammssss Member
    287
    86
    SoCal
    Hey Everyone,
    I got about 176-180 charges on my kit. It still works, but I think the battery is already reached its maximum charging cycle. I checked the batteries individually, and they seem to be find, registering 3 volts or higher. I did it twice to double check--might do it again a third time. So, how many charges do you have on your kit before the battery faded? Thanks.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,414
    3,280
    Madison, Wisconsin
    What are the exact voltage of the cells after a full charge and a resting period (so the cells can settle).
  3. Floyd2
    Floyd2 progressio per sententia
    106
    Netherlands, Europe
    Today was a hot day (for our climate) and it turned out this place was the warmest of Europe with 28°C (82 F).
    To my surprise I was able to drive a stretch of 40.6 km (~25 miles) at an amazing 1.0 L/100km (214 mpg or higher) in normal blended mode but I did only drive at speeds of 50 km/h or less and did not use the AC.
    It seems that with high temperatures the current flow out of the batteries a lot more easy. I forgot to insert the SD card so I don't know what the average or highest current was but no DTC.
    I still have not attached the hose on the converter yet, but I better not wait any longer if the weather stays like this. Do I have to lead it out of the car or just away from the enclosure.? I also wonder if additional airflow (extra fans) are needed with these temps. In our climate these temperatures usually only last for a week or three to four a year but since it's so early in the season it could get a hot summer.
  4. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    You need to flow the hose out of the car. And in warmer weather the kit needs more cooling than kit comes with .90 deg F here today I made some mods to air venting of my kit today that turned out to be a failure :mad: case temp reached 116 deg F. Ill have to go back to the drawing boards !
  5. Floyd2
    106
    Netherlands, Europe
    I'll fix the hose first thing tomorrow. When you figured out how extra fans should be place please let me know.
    I had the car parked in a cool garage before taking off, and parked in the shade before the return trip. I guess I was really lucky today... :)
