Forced Regen Button?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by blown240, May 21, 2011.
  1. blown240
    blown240 Junior Member
    53
    SoCal
    On my old 1st gen Honda Insight, I had a switch that made the car think you were braking. This would turn on the regenerative brake without actually using the hydraulic brakes. It was basically a momentary switch wired in parallel with the brake light switch.
    Is there something like this for a Prius II?
  2. qbee42
    3,079
    No, there is not. Why would you want it?
  3. blown240
    53
    SoCal
    You use it when you want to just slow down a little, instead of using the brakes, you just have the regenerative brake slow you. The prius already does it to a point, when you let off the gas. This would be a step more than that, more regen, and more brake, but not braking with your foot. Basically more of your kinetic energy ends up in the batteries, instead of heat from the brake pads.
    I am assuming that the prius has more regen when braking then when coasting, but I am new with these cars...
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Even with the foot pressure it will try to use regen first. Only if you go above the current limits, brake too fast, or are under 7mph will the friction brakes even be touched.
  5. bisco
    51,851
    ^ right. stepping on the brake pedal increases regen before using brakes. so it's probably a more sophisticated method than the manual switch in the honda.
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The Toyota HSD has more sophisticated regeneration brake than the Honda IMA.
    It applies the regen brake primarily unless it is a hard braking.
    However, if you want a forced regen button, the B-mode switching under 20mph works as desired.
    Ken@Japan
  7. qbee42
    3,079
    The Prius already does this, but you don't need a special button. Just step on the brakes and let it do its thing.
  8. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Hey OP,
    Here's another graphic with some key details from a Toyota publication regarding the 2004 Prius. The above graphic actually looks a little misleading, especially if you think of the unlabeled x-axis as time. You can see it's more a mix of regen and friction the more you push the brake pedal. A nice, light braking that gently slows the car is the best way to get all the energy available to you. As close to a regen button as you'll get. Still sort of a big button, you just need to push it with your foot :)
  9. blown240
    53
    SoCal
    Cool. I am glad that Toyota thought of this. The insight wasnt nearly as advanced. Thanks for the replies.
  10. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I want the opposite. A switch than lets the car coast without any regen.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    That would be nice but too many people would be confused at the lack of "transmission drag" and why the car isn't slowing down. So we will have to live with depressing the throttle just enough to make it a glide.
  12. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    It has one of those too. It's called 'N' (Neutral). You just have to switch back and forth between it and 'D' to get moving again.
  13. serialzombie
    serialzombie Junior Member
    IL
    That's fine to do? Also, what about "Brake?"
  14. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    B should only be used when you have reached 8 bars SoC and you are still going downhill. Useful when descending Pike's Peak, but nowhere in the Midwest should it ever be necessary.
  15. qbee42
    3,079
    Just a minor correction: B should only be used when you anticipate reaching 8 bars...
    If you wait until you hit 8 bars, there is no need for B mode; the Prius will do it for you. The idea behind B mode is to bleed off the excess energy early, forestalling the forced transition to friction braking.
  16. psusi
    psusi Junior Member
    68
    24
    Orlando, FL
    One problem with switching to neutral to coast is that the engine can not be started or stopped in neutral, so if you are over the magic 42 mph where the engine stays on when you shift into neutral, it will continue to idle until you put it back in gear and are under 40.
    Because of this, it is better to just ease off on the gas to gradually slow down instead of shifting to neutral when you are over 40. If the engine is running anyway, you may as well be using it to charge the battery.
